completely new to prius, need help on buying please
Discussion in 'Gen 2 Prius Main Forum' started by octobersongs, Jun 12, 2014.
  1. cipsaz187
    cipsaz187 Member
    148
    42
    Every Prius is different, but I would stay away from the 2004 just for the piece of mind.
    With that kind of budget, I would look at 2006 and above.
  2. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    It is listed in the "for sale by owner" section but is clearly a dealer. There is no plate on the car, it is professionally detailed and has no personal belongings in it and if you search that area for the phone number listed or google it, you can see tons of other cars and motorcycles for sale by that user.
    If they will lie about that, what else will they lie about?
    Be cautious.
    octobersongs and usnavystgc like this.
  3. octobersongs
    octobersongs New Member
    What is the best route to get a diagnostics done once I find one I'm interested in? Taking it directly to Toyota? I wonder the costs of a diagnostics through them? Any other options?
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Are you talking about an inspection by a technician? The reason I ask is that the car does diagnostics continuously so theoretically, any problems will trigger a check engine light or hybrid DTC. You will find many on here say to take it to the dealer for an inspection but, the problem with that is they have biases and they're out to make money. The two most common things they do is, 1) find things wrong that aren't (hoping you or the seller will fix them there) or 2) talk down about the car (hoping you will buy a car from them). There are also some technicians that have no idea what to look for on a Prius.
    The cost of one of these inspections vary greatly but I would give an estimate of $150-$200.
    There are two other options
    1) Buy from a reputable source that really knows or specializes in hybrids.
    2) Do the inspection yourself
    There really isn't much to do different when you inspect a Prius. Brakes, oil level and color, exterior condition, interior condition, maintenance records, drive belt, etc. The test drive is really the key. Start by resetting the MPG readout on the consumption screen. Test it over a wide range of driving situations (city/hwy/intermediate/freeway etc). Monitor the "Energy" display for sudden changes in battery state (like from nearly full to nearly empty in 30 seconds). Drive it for at least 20 min. And finally, observe the MPG readout on the consumption screen. You should at least see 38 mpgs (likely more).
    tanglefoot and octobersongs like this.
  5. Patrick Wong
    18,210
    6,510
    I disagree with this. There are many problems that will not trigger a warning light:
    1) a suspension issue such as failing front struts/rear shocks
    2) brake front pads or rear shoes that are almost worn out
    3) mechanical issue with the transaxle such as a failed bearing
    4) an electrical issue with a power window, power door lock, power mirror, etc.
    5) a non-functioning multi-function display
    6) an engine that has been poorly maintained - clogged air filter, engine oil change past-due, etc.
    7) worn tires
    8) an air conditioner in marginal condition
    An alert driver can figure out all of these issues. However many prospective owners are not as alert as they could be. This is why you pay for an inspection by a qualified tech.
  6. David S
    David S Junior Member
    Fort Lauderdale, FL
    I looked for months at used Priuses. (Most all were ruled out as soon as I opened the door and got a whiff of that strong Prius smell) I too was looking at a 8k budget. I ended up bumping that up 10-12. I also use Edmonds as my pricing guide but using the Research Trade-in Tool to get the "trend selling" price of the Prius. You can save hundreds or thousands. Just chuckle when they tell you the Kelly Blue Book price and tell them you use Edmonds. You can watch the expression on there face change.
    I had decided to give the non-Dealers a miss. Too much at stake with these cars to purchase a vehicle sent off to auction. I used AutoCheck and wasn't too surprised by how much bs I found in the private and small dealers. Plus, after shopping at the small dealers I found 80% of the cars were doctored from some problem that was undoubtable the reason it was traded in.
    So I started sticking to Toyota dealers. I figured they would be more likely to backup the car and they have the knowledge and recourses to do so.
    That said, you still have to be cautious. One car at a dealer made a strange sparking sound while I was standing next to it. I asked the salesman about it. He said they would have the car checked out. Next time I talked to him I learned the car had been sent off to auction. hmmm.... I wonder who will end up with that one.
    Another time the car tended to wander all over the lane. The salesman told me that was normal. LOL
    Finally, after months, found a 2008 Standard (not a leather seat fan) with 56k miles on it for 11,300 from a Toyota Dealership. Oh.. and amazingly enough, no bs dealer fee at this dealer.
    Good Luck!
    octobersongs likes this.
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    I disagree with this. For one, the OP was asking specifically about diagnostics so, I answered her question about diagnostics. Then I went on to tell her other things to look for. Taking a car in to have diagnostics read when its showing no DTC's or trouble/warning lights is ludicrous. All the things you pointed out have nothing to do with diagnostics.
    There are hundreds of "qualified technicians" that could not find some of the things you pointed out. If one can't roll a window up and down to determine if it works, or look at the tires, something must be wrong with them.
    And I love how you conveniently didn't quote part of my post that virtually said to check most of these things.
    Its really frustrating every time I post something that I think will help someone, you come in and disagree with me to seemingly make yourself look good. I don't know what your motivation is but, I think you could exercise a little better tact. I understand you like bringing a car to the dealer to have it checked out. I don't, lets agree to disagree. There's no reason to continually quote and contradict my posts as if I don't know what I'm talking about and your are somehow superior. I personally would appreciate it if you would give your advice and let the OP decide. My advice is not bad and neither is yours.
    #27 usnavystgc, Jul 3, 2014
  8. ETC(SS)
    7,160
    One advantage in going to a Toyota dealership for a full inspection is that they might be able to access the vehicle's history.
    They will be on the high end of the cost range for inspections, but an independent might not be as knowledgeable about Priuses.
    Depending on your location, there might be a shop that specializes in Hybrids.....especially if you're on the left coast.
    That's a hit and miss benefit, since the vehicle that I drove to work today has zero maintenance entries in 150,000 miles and I wouldn't hesitate to drive it across the country right now.
    Priuses are very reliable cars, but if you're new to the wonderful world of hybrids, and you do not do your own maintenance I would recommend that you start shopping in the Toyota dealerships.
    You're going to pay a little (lot) more but you'll lessen your chance for getting a problematic car.
    Good Luck!
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    She has Tampa Prius very close to her.
  10. ETC(SS)
    7,160
    Ha!
    The Left Coast!! (of Florida) :)
    usnavystgc likes this.
  11. octobersongs
    I've been eyeing tampa prius daily. I'm keeping an eye out and also emailed Todd too. Hopefully there will be a couple more options in the next 2-3 weeks. I've found a few "private sellers" on craigslist that I don't believe to be fake dealers (other than the link I posted a few days ago). BUT...still don't know of red flags other than what I've been told in this thread...I'll be honest. I am not a car enthusiast at all. I'd much rather pay someone to tell me if there's something wrong with the car, but at the same time, it's so frustrating to have to fork over that $$$. This is becoming more stressful than I wanted. Along with Tampa Prius, I'm also looking at
    The owner told me the AUX battery has not been replaced, but the cells in the HV battery were repaired and she has the paperwork to prove it. Also her husband did the routine maintenance (oil changes)
    2006 Toyota Prius
    thinking these next two is a dealer posing as private seller...
    http://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?zip=34771&endYear=2015&modelCode1=PRIUS&showcaseOwnerId=1071538&startYear=1981&makeCode1=TOYOTA&sellerTypes=p&sellerType=p&searchRadius=200&maxPrice=9000&mmt=%5BTOYOTA%5BPRIUS%5B%5D%5D%5B%5D%5D&listingId=371006358&Log=0
    http://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?zip=34771&endYear=2015&modelCode1=PRIUS&showcaseOwnerId=1071538&startYear=1981&makeCode1=TOYOTA&sellerTypes=p&sellerType=p&searchRadius=200&maxPrice=9000&mmt=%5BTOYOTA%5BPRIUS%5B%5D%5D%5B%5D%5D&listingId=372858251&Log=0
  12. usnavystgc
    3,159
    990
    Tucson, AZ
    The last one is listed as a Prius III but judging by the steering wheel controls, it looks like it has NAV and BT. That one seems like a really good deal but the pics are limited. Some things I use to judge are the wheel rings (are they present and what kind of condition), the seats, are the floor mats original, what does the engine compartment look like, are there a bunch of small dings and scrapes etc. This car appears to have all the right stuff and less than 100k on a pkg 4 or 6 for less than $8k. Def worth looking into. IMO
    Here is the dealer service history for it.
    #32 usnavystgc, Jul 3, 2014
  13. octobersongs
    Thank you! How did you find that? I see the vin but duno how ya got the rest.
    Should I be concerned about the recent repair work...electrical problems/won't start? and TPWS malfunction last year?
    #33 octobersongs, Jul 4, 2014
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    I registered for an account with toyota.com/owners then added the vin as a new vehicle then downloaded the service history. :)
    I personally would not be concerned about the electrical problems/won't start. That was likely the 12v battery. Just find out when it was replaced.
  15. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The tire pressure sensors run on batteries. Sooner or later they will fail. If you can live with a constant idiot light and without the tire pressure monitoring system (like we all did in older cars) then the sensor doesn't have to be replaced. Those who run a set of snow tires don't have a functioning TPMS for the season.
  16. octobersongs
    I have several that I'm looking at. One of them appears to have been in an accident back in 2010, but the owner, who states he is the 3rd owner, is claiming a clean title. Is that a red flag? Forgive my ignorance, I really have no idea about this stuff.
  17. TampaPrius.com
    461
    300
    Tampa, Florida
    A minor accident would not effect the title status. Only a major event like total loss, flood or fire damage that was not repairable , TMU(true mileage unknown), NAM (not actual miles) or salvage title would be branded on the title.
  18. octobersongs
    IDK how minor it was...the service history report is extensive but I don't see anything on there about it being totaled.
  19. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    It must have been a repairable situation. Mine is a clean-title accident victim as well. Some repairs are great. Some aren't. I'm happy with mine.
  20. Keri Weeg
    Keri Weeg Junior Member
    Fort Myers Beach, Florida
    I live in Fort Myers Beach (Lee County). Once I got my heart set on a Prius, I literally babysat CraigsList for almost two months before finding my 2008 with 131,000 miles and all the upgrades (Bluetooth, nav screen, etc) for $8,200. You are fortunate to live in a big city that's only an hour and a half from Tampa because I saw lots of postings in Orlando, Tampa and Miami but hardly any in my area unless they were crazy priced (<10k for a 2005). My advice is to keep looking and be ready to leap when one becomes available - mine was posted on Monday and I bought it the next day. Good luck - you will be very happy! I LOVE my Prius :)
