Compressor not kicking in during refill
Discussion in 'Gen 2 Prius Technical Discussion' started by Chrizoroer, Apr 21, 2026.
  1. Chrizoroer
    Chrizoroer Junior Member
    TX
    Hello everyone,
    I had a slow leak in the AC system which I fixed. It was a loose schrader valve on the high side gauge port.
    Pulled a nice vacuum which was still good after about 1 hour of waiting, so I'm very confident the leak has been fixed.
    However, when I slowly introduce fresh 134a the gauge just goes up and up without the compressor ever kicking in. It stops at around 80 since that's what the pressure in the can is I assume. Every other car I ever had to fix the AC on, the compressor would have kicked in at around 40 to 60.
    I tried keeping the car in maintenance mode (ICE engine on) and also just in READY mode. No change. As far as I know the compressor runs off of the 200VAC converter right? So the ICE engine doesn't have to be on at all?
    AC is on in the car on full blast all doors open and on recirculation.
    I know the compressor might not come on because it senses low refrigerant but that makes a refill impossible. How can I "make" the compressor come on and do it's job? Is there an override of some sort for Priuses? Or the compressor is dead? Is there a way to check that without getting a new/refurbished one?
  2. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    It should come on making a racket or not . Do now check fuses and inverter ac cabeling . Pressure switch unplugged? It's built into the metal line.
  3. PriusCamper
    PriusCamper Senior Member
    13,471
    5,438
    Pacific Northwest, USA
    Prius AC is a variable pressure system. You can't accurately fill the system based on pressure; standard is filling the system based on weight.
  4. Chrizoroer
    TX
    Checked cabling and besides a bit of road grime looks intact. Cleaned it off and looked at contacts they look clean.
    Checked all the fuses related to the AC system. Inside fuses are all ok. Engine bay fuses are all okay. There are 4 relays that are related to the AC system. Pulled them and visually inspected the pins and they look ok. Is it worth it to test the relays? How likely is it that a relay is shot?
    Thanks, I am aware and had a scale ready to fill it to the right weight. The problem though is that it won't suck in ANY refrigerant since the compressor wont kick in and do it's job.
  5. ChapmanF
    19,045
    There are some relays responsible for other things, like the cooling fans behind the grille, but not really for whether the A/C compressor runs. That runs on 3-phase AC fed to it from the inverter, doing what the HVAC amplifier tells it to do.
    If the HVAC amplifier isn't telling the compressor to run, it probably wants to tell you why it isn't. Have you read any trouble codes?
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  6. Chrizoroer
    TX
    I did the flash codes procedure and sadly it came back without any problems. All the light are just flashing, no code just flashing.
    I have a suspicion that the gauge set which I loaned from O'Reilly's might have been defective. My own will arrive this saturday and I will try to recharge it again. Wish me luck. I'll keep you posted
  7. ChapmanF
    19,045
    On that blink-codes page, you would want to scroll down to the "codes from the heat/air conditioning system" part. The gen 2 HVAC doesn't actually blink codes; it shows two-digit codes on the MFD.
  8. Chrizoroer
    TX
    Problem solved.
    I finally got around to give it another go with my own new gauge set. Lo and behold it worked flawlessly.
    Thanks for everyone giving pointers what to do and look out for even though it was an unrelated issue :D
