Computer Calculated MPG and Scangauge II
Discussion in 'Gen 3 Prius Fuel Economy' started by Xterra72, Sep 21, 2017.
  1. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    I monitored my 40 minute, 25 mile commute to work today. Mixed traffic and average between 65-70 mph. After reaching my destination, these were my readings.
    The computer read 50.7 MPG
    The Scangauge II read 65.3 MPG
    Is there some calibration needed?
    I'm guessing the computer reading in the car is more accurate.
    Any thoughts?
    52,767
    the computer is usually a few percent high, resulting in lower mpg at the pump. not sure what's going on with the scan gauge. did you reset the trip meter on the car before starting out?
  3. Xterra72
    1,437
    1,684
    @bisco, That could be the case. So I have to reset the trip meter every time?
    52,767
    just to compare drives and meters. if you're looking at instantaneous mpg, the car is 3 seconds behind. if you want to compare mpg for a trip, or a tank, you would need both devices starting at zero.
  5. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    Is your ScanGauge setup properly (engine size, tank size, fuel units, etc...?
    WilDavis likes this.
  6. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Are you new to Scanguage? It sounds like you need to calibrate it.
    The next time you fill up, you should go to Fillup, then hit done, then save. Then at your next fillup, go to fillup and see how many gallons the scanguage thought you used. You adjust that figure to match how many gallons you actually put in your tank.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I've found that my SG-II tracks pretty much the same as the MFD in the car, but I also keep an accurate log of how much fuel into the tank, and how many miles the car is driven, and over time they all correspond pretty accurately (…at least to within amounts that really make no difference) ;) (…but as they say YMMV :rolleyes: )
