computer MPG never changes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nbaker, Mar 21, 2008.
  1. nbaker
    nbaker New Member
    Houston TX
    My wife owns a 2006 Prius which she is in love with.
    For the last three gas fillups the computer showes that she is getting 41.6 MPG constantly. It never changes. No mater if you have gone 1 mile or 400 miles. The MPG is going back to zero when the car is filled up and I have manually reset it. Yesterday she had gone 2 miles and the MPG was showing 41.6. I know that this is impossible. Is this a computer problem or something I can correct? I need help soon as the warrenty is close to running out.
  2. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    It does sound like that there is a problem with the mpg MFD display if it keeps showing the same number. Does it go to zero automatically after a fill-up or do you press the reset button. If you haven't already done so press the reset button and see if the 41.6 showing goes to 0 and maybe the press of reset fixes it. Keep trying this a few times if it doesn't reset properly and if it still doesn't then take it to the dealer.
    If it was my car I would let the dealer know either way since you are so close to the expiry of your warranty. That way you registered the problem with Toyota and have some leverage if the problem persists after the warranty expired.
    Best of luck,
    Gabe
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    With the 2006 the mpg does not reset automatically when you fill up. You have to press reset.
    Tom
  4. Patrick Wong
    18,200
    6,472
    If you want to experiment, you can try disconnecting the 12V auxiliary battery for a few minutes, to see if you can clear the mpg memory that way. If that doesn't work or if you don't care to experiment, a dealer visit would be warranted.
  5. Anniee
    Anniee Junior Member
    Maryland
    How about the newer models? 2007 and 2008. do they reset automatically?
    Anniee
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Maybe the missus is just really consistent?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    No. Not my 07.
  8. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    my 2007 resets after about 1.5-2 miles, after a fillup.
