Concerned over gas going bad
Discussion in 'Gen 3 Prius Main Forum' started by Cyen, May 16, 2020.
Tags:
  1. Cyen
    Cyen Junior Member
    Hello all,
    Wasn't sure where to post this... With the current situation in the world, I'm hardly doing any driving except maybe 2x a week to the local grocery store and back again (less than a mile). I filled my tank back in about April and needless to say I still have a mostly full tank of gas (I think it dropped one bar). I did some searching online about gas going bad and found several warnings that it may be good for only 1-2 months. There's some sort of additive you can add, but I got the impression that was mostly for like lawnmowers and chainsaws, etc, tolls that may sit for long periods of time.
    Is anyone else concerned about this?
    I'm about to go for a longer drive this afternoon, just going to get on a highway and go, with no destination, turn around and come home. I feel stupid doing that, but short of going to a mechanic and asking them to drain my gas tank.. I'm just not sure. Any advice?
    Eht-Ostäf likes this.
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    top of the tank with fresh gas after your drive & get a bottle of sta-bil (~$9.-) from walmart or ne automotive shop; works perfect for me in my other car since like 15 years /
    5 oz for the prius tank & you're on the safe side /
    frodoz737 and Cyen like this.
  3. Mendel Leisk
    42,253
    That seems short, maybe 6 months. Look at all these plug-in owners here, they don't seem to be sweating. I wouldn't bother with stabilizer for a few months, just a heads-up: it too has a shelf life, and then whadya do?
    I've got a bottle of the stuff that's about a decade old. I've found a local place that'll take it, only issue: you need to drop it off in an approved gas container. You can get a cheapie gallon one for about $10.
    Cyen, ice9 and fuzzy1 like this.
  4. fuzzy1
    10,687
    Some people are, some are not. You'll hear a very wide range of opinions.
    But that 1-2 month claim is on the extreme short end, and likely applies to small engines with openly vented gas caps, from the hardest core gas stabilizer proponents. Modern cars have emission control requirements that don't allow such venting, so evaporation is much slower.
    Plug-in hybrids are very intentionally designed to go longer between refills than are regular hybrids, so the rest of us can't use them as a guide. Somewhere in the PC archives a few years ago is an article describing GM / Toyota / others' cooperative efforts with CARB to jointly develop standards for evaporation emissions, which drives this fuel longevity issue.
    Toyota's flagship plug-in hybrid, the Prime, is intended to go a year before ~5 gallons should be burned off and replaced with fresh. So a regular older Prius must be shorter than that. With all the snowbirds leaving cars behind for the seasons, without piping up about troubles, 6 months does seem doable. Though certain people here are going to dispute that.
    Each of my household's cars commonly goes 3 months between refills sometime during the year. For my Prius and Subaru, that is seasonal. For the spouse's near-daily driver, that can be any time of year, especially when it overlaps our longer trips. It's typical trip distance is just 2 or 3 miles, and she runs it down to nearly fumes, so it goes a long time between fills. It is now more than 30 years old, and has been in this use pattern much of the past 15 years, and we haven't yet been hurt by a problem from it.
    Cyen and Mendel Leisk like this.
  5. bisco
    52,767
    take her for a scenic ride once a week or so, you'll both feel better. no need to feel stupid, it's actually smart
    fuzzy1, Cyen and Mendel Leisk like this.
  6. Mendel Leisk
    42,253
    That's us, Sunday Drivers. :)
    fuzzy1 and Pluggo like this.
  7. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Two year old fuel seems to be ok in a plugin.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Don't feel stupid.
    Through this crisis, I have wondered just the opposite. Not just gasoline but also threads where people have let their Prius sit so long, their 12 volt has died.
    I think starting your vehicle up, going on a point A to point B and back drive, with limited or no stopping is a good idea. Don't know why more people aren't doing it.
    If you are using the vehicle weekly...even for those short trips to the grocery store, and you add a longer scenic drive maybe once or twice on the weekend, I'd think you'd be fine. The gas is being burned off.
    Quick Google search asking how long can gasoline sit in a car returns 12-15 months.
    #8 The Electric Me, May 16, 2020
  9. Cyen
    Cyen Junior Member
    In a time of mostly staying at home under "quarantine" this makes it sound like I have "someone" to go on a trip with. Thanks for phrasing it that way! :)
  10. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    A couple of weeks ago I started up our Honda-engine generator for the first time in more years than I can remember. I had run the carburetor dry, and I *think* I had put Sta-Bil in the gas tank. Didn't add any new gas, but it started on the second pull.
    Tips and Mendel Leisk like this.
