Condensation in windows
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cutter44, Dec 14, 2020.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    You can rule out the classic hatch or tail light seal leaking by getting in the hatch closing the hatch door and have someone hose the car down with a hose outside while you watch inside with a flashlight. That's how I found out my after market pos taillight was leaking real bad.
    Not sure what your talking about drilling a hole in the OEM tail lights for draining. Shouldn't have to do that.
  2. cutter44
    cutter44 Member
    213
    MA
    Apparently it's not uncommon. Standing Water in Tail Light Lens | PriusChat
    Drilling may not be the best solution, but it's probably the quickest. I certainly wasn't the first to do it. ;)
  3. edthefox5
    10,096
    4,834
    Clearwater, Florida
    That's awful 4 inches of water in the tail lights yikes.
  4. PriusCamper
    PriusCamper Senior Member
    13,086
    5,308
    Pacific Northwest, USA
    While I'm not the one to drill out tailights, pulling the drain plugs in battery compartment and wheel well while you go after the leaks is wise.
  5. cutter44
    cutter44 Member
    213
    MA
    Can you be more specific? Like, which battery compartment 12v under the seat or hybrid under the hood? And where are the drain plugs? Likewise with the wheel wells. Are there any diagrams I can find online? I've never had to hunt down stuff like this before with any other vehicle I've owned.
  6. PriusCamper
    13,086
    5,308
    Pull out your spare tire and you'll see two rubber plugs that are near 2" wide.
    Pull out your 12v battery and you'll see one rubber plug that's 1/2" wide.
    It's super fun to pull the plug once it's full of water and watch the whirlpool spin...
