Featured Conditions best for Eco, Normal and Power mode
Discussion in 'Prime Main Forum (2017-2022)' started by Bobdski, Mar 13, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    In my opinion, there's no reason to ever change them, unless you get used to one besides the default and change it every time you get in the car. It doesn't change vehicle performance, just "pedal feel".
  2. Mendel Leisk
    41,475
    When we got our 2010 I played around with ECO, vs Normal, vs PWR, for maybe the first 6 months. I found the pedal travel in ECO maddening/tiresome. I believe with the 4th gen (and Prime) the pedal travel in all modes has been shifted, so that ECO is about where Normal was on 3rd gen? Anyway, getting back to my point:
    After about 6 months, I got tired of the excessive pedal travel in ECO, set it in Normal mode, stuck with that since. As the other responders have said: the main difference is just pedal travel. There's a few hvac tweaks as well, don't much care. There is no under-the-hood variations, say valve lift, torque, horsepower: it's the same in all modes.
    breakfast likes this.
    51,961
    the 'ev/ev auto/hv buttons are the ones that require easy access. horrible on the pip.
  4. Primeinmountains
    Primeinmountains New Member
    Las Vegas
    I find eco mode great for city driving. It makes it easier for the slower energy efficient starts from a stoplight. On longer trips on a freeway...it's not so nice. It's more work holding your foot down farther over long periods of time, which is really tiresome if you're not using cruise control. That's when normal mode comes in handy.
    HPrimeAdvanced and jtv like this.
  5. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I no that acceleration 0-60 in eco,normal or power mode result in about the same time in the end,at least with gen. 3,but I read somewhere that in power there is slightly more energy of the battery granted from the get go in power mode but smoothes out in the end,at least in gen. 3.
    Maybe similar to the acceleration 0-60 in EV-mode with the Prime,which is faster than in HV-mode at the beginning,but in the end takes a about 2 seconds longer .
  6. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    Okay I've read through most of this thread and this feature being new to me, I did not notice it on my 2010 for the heating and cooling system.
    So when I have only the fan on and no heat and no cool and just wanting ventilation air movement what does the system provide. Is it actually consuming more energy because something else is happening I'm not aware of.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    It will draw heat if cabin is less than set temperature...if you have AC off and heat is less than interior temperature
    You will have only fan running ...
    I have similar question and with my probes hooked on various cable connections blower is only that is running
    And you are like me...I still didn't even look in my passenger door compartment to read anything....
    Chat is much faster and here are many great people that answer almost anything you are looking for
    P.S be careful with trunk light...
    Bottom right side....another thing that is only on advanced model
    Handy in the darkness.
    #27 Samprocat, Apr 6, 2017
  8. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    be careful with what? does it just come on or something?
  9. bisco
    51,961
    if the fan is the only thing on, then that is all that is pulling power. if you're wondering why the ev estimate drops when you turn the fan on, join the club. we have been wondering the same thing since 2012.
  10. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    not me, my opinion is you don't get something for nothing. The fan draws electrons, electrons consume energy, thus the EV estimate drop.
  11. bisco
    51,961
    but it doesn't change if you turn the a/c on. so what toyota is saying is: 'if you use the fan, you're going to lose x amount of ev miles, but if you also turn on the a/c, it won't affect anything'.
  12. Mendel Leisk
    41,475
    Still, the reality of the losses will be what it is, regardless of Toyota's prediction.
  13. priuscatprimeguy
    2,730
    2,640
    I don't see that to be true, when I turn on Climate to Auto I lose about 1.5- 2.0 miles of EV
  14. bisco
    51,961
    turn the fan on and see how much it drops. then hit auto, and tell me how much more it drops.
  15. priuscatprimeguy
    2,730
    2,640
    I will when I go out to my car tomorrow, but right now I'm watching Tigers Baseball, Opening day tomorrow we're playing your team bisco.
  16. Mendel Leisk
    41,475
    Does auto turn ac on? It doesn't on our Canadian 2010, might depend on country tho. That's actually just the way I like it, btw.
  17. bisco
    51,961
    2-0 baby, bring it on, we've got big dave dom!:p
    priuscatprimeguy likes this.
  18. priuscatprimeguy
    2,730
    2,640
    Ok @bisco I went out to my car, didn't find any way to just turn on A/C and not have the fan turn on, please correct me if I'm wrong
  19. Samprocat
    491
    297
    Lincoln, NE
    There is a switch to to turn on...i didn't play long enough to see if have three way switch....
  20. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    As you know, auto refers to fun speed and vent outlets with relation to temp difference between actual and set temp. It will be with or without A/C depending on how you left it last auto session (at least in my area).
    #40 giora, Apr 7, 2017
