Featured Conditions best for Eco, Normal and Power mode
Discussion in 'Prime Main Forum (2017-2022)' started by Bobdski, Mar 13, 2017.
  1. bisco
    51,883
    the only thing you're doing wrong is reversing my question. the fan has to be on to turn a/c on, or adjust temp.
    but my question again: why do estimated miles drop with just the fan, and then no subsequent drone when a/c is turned on?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    turning the fan on puts it in Auto mode
    51,883
    okay, i didn't realize they changed gen 4. i am able to turn the fan on with nothing else for fresh air in nice weather.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This needs verification IMO.
  5. priuscatprimeguy
    2,730
    2,640
    yup, they added a heat pump to the traction battery in the Prime, when you want heat the heat comes from the traction battery via the heat pump. I'm assuming that A/C (refrigerated air) comes also from the traction battery.
  6. bisco
    51,883
    i don't have one to check.:unsure:
  7. priuscatprimeguy
    2,730
    2,640
    hmmmm, you need to resolve this:D
    HPrimeAdvanced and bisco like this.
  8. bisco
    51,883
    what do you mean, they added a heat pump to the traction battery. the heat pump is electric, like the a/c compressor, no? or it might even be one unit, but why would that prevent you being able to access fresh air?
  9. priuscatprimeguy
    2,730
    2,640
    On the 2012-2015 PIP the only way you could get heat was having ICE kick in. The Prime get's it's heat from the heat pump via the traction battery
    I don't know the answer to that @bisco
    #49 priuscatprimeguy, Apr 7, 2017
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    According to the EU manual, auto works exactly the same as in the PiP and you can get fun only (non auto) and change its level and the outlets to your preference.
    EDIT @bisco
    One improvement is the below
    :■ Blower customization
    Fan speed setting during the automatic mode operation can be customized.
    To change the fan speed setting mode, press Auto . Each time is pressed, the fan speed setting mode changes as follows. “NORMAL”  “ECO”  “FAST”  “NORMAL”
    When “ECO” is displayed on the air conditioning screen, the air conditioning is controlled with low fuel consumption prioritized such as reducing fan speed, etc. When “FAST” is displayed on the screen, fan speed will be increased.
    Bolding is mine.
    #50 giora, Apr 7, 2017
  11. bisco
    51,883
    must be different in the u/s i guess.
    priuscatprimeguy likes this.
  12. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I doubt it.
  13. bisco
    51,883
    well need someone to check it out.
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Checked for you the US online manual, it is the same as the EU one on this subject (start page 488).
    Americans need fresh air as well:)
  15. Tideland Prius
    16,553
    That is different in the EU because you have dual-zone automatic climate control. Your AUTO button has, in small font, "ECO/Fast". Ours doesn't. We have a separate "ECO Heat/Cool" button.
    priuscatprimeguy and giora like this.
  16. priuscatprimeguy
    2,730
    2,640
    It still drops the estimated EV range by about 1.5 -2.0 miles
    Tideland Prius likes this.
  17. Tideland Prius
    16,553
    I was trying to stay out of you guy's discussion lol. I just wanted to clarify the differences in EU and US HVAC controls. Carry on. :)
  18. bisco
    51,883
    i think i've run out of bullets...
    HPrimeAdvanced likes this.
  19. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  20. bisco
    51,883
    yes, absolutely on gen 1.
