Featured Conditions best for Eco, Normal and Power mode
Discussion in 'Prime Main Forum (2017-2022)' started by Bobdski, Mar 13, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    If I understand you correctly, when you hit 'Auto' the fan and the A/C are both on.
    Now, if you then press the A/C button, does it not shut-off A/C leaving only the fan on?
    If yes, then you can compare estimate drop with and without A/C compressor (with the PiP there is no change, both gives a drop of about 10-12%). That is IMO what @bisco was stating.
    51,945
    yes. auto doesn't come on with the fan, unless you have been using it and don't shut it off. at least on pip. still can't speak for prime.
  4. priuscatprimeguy
    2,730
    2,640
    Here's the pic's of Climate one with A/C on (notice the thin vertical blue line) and with it off ( no thin blue vertical line) As you can see the fan shown in the third pic shows electrons going from the battery to the fan in both cases. I tried to take a picture of the HUD but it was too dim to show up on my phone's camera with Auto off EV range was 15.9 miles, with Auto on (both with A/C on and off show the same 14.7 miles EV)
    #64 priuscatprimeguy, Apr 7, 2017
    Prius from Dad likes this.
  5. bisco
    51,945
    ck and jt, does it get any better than that? oh yeah, tigers won, congrats!:p
  6. priuscatprimeguy
    2,730
    2,640
    it was a close one but in the end only the best win:D
  7. bisco
    51,945
    maybe you were smart to get rid of dd.:rolleyes:
  8. priuscatprimeguy
    2,730
    2,640
    dd? who?:confused:
    Google
  9. bisco
    51,945
    @davedombrowski
  10. priuscatprimeguy
    2,730
    2,640
    ahhhhh, gotcha, lol, yup:LOL::ROFLMAO:
  11. bisco
    51,945
    hmm, i guess he's not a member.
    priuscatprimeguy likes this.
  12. CharlesH
    2,797
    1,163
    Roseville, CA
    A "heat pump" and and "air conditioner" are the same piece of equipment. Take an "air conditioner", add valves so that the compressed, hot refrigerant liquid is directed to the coil in the cabin and the cold low-pressure refrigerant gas is directed to the coil under the hood, and you have a "heat pump". Just changing the direction that heat is being pumped.
  13. bisco
    51,945
    so does that mean you only get warm or cool, no fresh air if you want it?
  14. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
  15. bisco
    51,945
    no buts about it.:)
    HPrimeAdvanced likes this.
  16. mdhare
    mdhare Member
    59
    33
    Madison, WI
    In another thread someone suggested setting temperature to Lo (below 55F?) and disabling A/C. I've tried this and it seems to do the trick, I advise disabling auto fan if you do this too.
    It's a lot of taps on the screen to do this and doing this also throws a wrench in premium based cabin pre-conditioning. Wish there was a single tap to enable outside air temperature intake mode.
  17. priuscatprimeguy
    2,730
    2,640
    how do you disable auto fan? other than selecting off, which kinda defeats the purpose of having the fan blow outside air in the cabin
  18. Mendel Leisk
    41,463
    Set a fan speed?
  19. priuscatprimeguy
    2,730
    2,640
    I just checked my pic's that I posted, maybe selecting the car icon with the re circulation symbol inside the car icon, I will try that tomorrow.
  20. Tideland Prius
    16,559
    manually adjust the fan speed, that'll kick the fan speed out of AUTO mode.
