Confused about my motor
Discussion in 'Gen 3 Prius Technical Discussion' started by Ahmad8020, Oct 5, 2018.
  1. Ahmad8020
    Ahmad8020 New Member
    Jordan
    Hello
    I have Prius 2010
    My motor is broken its consuming so much oil
    So iam confused about replacing it with used motor and warranty period month..or to replace the parts inside the motor and repair it....so what should i do?
    And thnx very much
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    danlatu likes this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I believe the growing consensus is that if the motor is guzzling oil - it's cheaper to replace with a used one rather than pay a tech to rebuild it.
    danlatu likes this.
  4. ChapmanF
    19,007
    Rebuilding one yourself takes a significant amount of time, a good workspace and engine stand, numerous painstaking measurements and specialized tools. It can be fun if you have the time to spend and want to learn (and, ideally, someone with experience to help out).
    Swapping in one that works is a lot simpler, and may have better long-term reliability than your first rebuild job.
    -Chap
    danlatu and jerrymildred like this.
  5. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    How many miles/kms on your car now?
    danlatu likes this.
  6. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I would like to ask what is the price of a low mileage prius engine in Jordan? Another point here. 5k oci will extend the life of your next engine. If the roads you drive on are hot and dusty/sandy, I would also look into changing your air filter sooner than 15k. Maintenance is key to keeping a car running well for a long time.
