Confused: Why does estimated EV miles keep dropping?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Den Hare, Oct 29, 2012.
  1. bisco
    52,855
    how about 'i'm getting X actual ev miles in my pip', or, ' why is my pip not going as far in ev as it used to?'.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    The OP didn't mention tire pressure. Hmm. ;)
    52,855
    mine is 37 rear, 39 front.
  4. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Today. Down to 8.7. Does it even pay to plug it in?????
  5. John H
    John H Senior Member
    2,208
    558
    Do you garage your PiP? I think the battery works best in the 70's. Doing scheduled charging that warms the battery up just before departure should help a bit as well.
    babybird likes this.
  6. Zythryn
    Zythryn Senior Member
    6,412
    4,414
    And yes, it does pay. Weather it's payoff is worth it to you is the question.
    All EV and PHEVs have a range that is dependent upon weather and driving behavior.
    How the battery system and drivetrain are engineered will affect how much of an impact those issues have.
    It is critical for all manufacturers to educate consumers on what type of ranges they can expect. However, because this varies so much with regional weather, trip distance, trip route, number of trips, and driver behavior, they can't give you a set number.
    The best everyone can do is to be aware of what impacts range, be aware of your own driving habits and distance needs/wants and buy the vehicle that best meets your wants.
  7. hill
    9,038
    With gas at a premium the PiP sales are excelent. In fact, the Prius is the best selling car in the largest populated state (CA): Toyota Prius best selling car in California - Oct. 23, 2012 - So, it would seem that no one is listening to the OP regarding 'don't buy a prius' . . . . . . and thus it follows no one understands the OP's wisdom regarding "fixing" the PiP traction pack, either. :D
  8. Adam Leibovitch
    498
    102
    EV mode only has 50 hp while HV has a combined 108 hp
    Have you checked your tire pressure? Do you begin your drive on the freeway? uphill? Not sure why people refuse to check their tire pressure.
  9. benalexe
    benalexe Member
    198
    30
    Commack, New York
    I do park in the garage but have not used the schedule feature
  10. benalexe
    benalexe Member
    198
    30
    Commack, New York
    I will check tire pressure today. What is it supposed to be at?
  11. Adam Leibovitch
    498
    102
    The schedule feature will not fix what your unhappy about. Leaving my car charged for over 24 hours on Sat-Sun, my EV range discharged by only 0.1-0.2 miles.
    EV mode only has about 50hp available to it. If you try to drive 50 mph, or climb a hill you are going to be pushing that poor little engine so hard, its going to use a lot of battery to not move you that far. In HV mode you have 108 hp available, so high speed and uphill portions of your commute may be better to use HV mode.
  12. Adam Leibovitch
    498
    102
    Inside the drivers door is a sticker that tells you Toyota recommendations: 35 front, 33 back. The tire max PSI is 40. Some people like to go a little higher than recommended, maybe 39 front, 37 back.
    I resisted checking mine. Not sure why its a source of pride not to check your tires, I guess its like not wanting to ask for directions, lol. Anyways I finally did and I was at 27-29 psi.
  13. John H
    2,208
    558
    Adam,
    The suggestion for scheduled charging is aimed at "pre-warming" the battery pack just before using it more than trying to squeeze the highest state of charge. Charging warms up the battery. Not as big an issue in LA, but those folks in colder climates are suffering from lower battery outputs because of the temperature.
  14. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    No, the max tire pressure is 44 psi.
    Adam Leibovitch likes this.
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Are you driving at higher speed in EV mode? Using heated seats? They will use more electricity and reduce your EV range.
  16. bisco
    52,855
    anyone know how many watts each seat draws?
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    A quick search said aftermarket heated seat draws 36-45 watts each. Headlights are 110 watts (55 each).
    If you have the headlight and a heated seat on, that's about 150 watts. PiP owners are getting 200-300 watts per mile, so 150 watts extra draw is significant.
  18. John H
    2,208
    558
    I think you might be mixing watts with watt hours. :)
    usbseawolf2000 likes this.
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Watching the election... can't think straight now :)
    An hour of headlight and 2 heated seat would cut down about 1 mile EV range.
    Tracksyde and John Hatchett like this.
  20. bisco
    52,855
    thanks usb. so if i was getting 16 miles on a 2.7 kw charge, that's about 170 watts per mile? i'm trying to get to headlamp cost and i guess the balance is cooler weather.
