Confused: Why does estimated EV miles keep dropping?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Den Hare, Oct 29, 2012.
  1. bisco
    52,861
    this morning, my range said 13.3, but with three in the car, i only got 12.5.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    dump the other two:D
    lensovet likes this.
    52,861
    we're all dieting starting tomorrow. as soon as i finish this hot fudge sunday.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Personally, since this thread has a very misleading title, I think we should let this thread die instead of having it continually being bumped to the top. If people want to discuss their GOM (guess-o-meter, the MyNissanLeaf name for theirs) values after charging, perhaps it should be done in a better titled thread.
  5. bisco
    52,861
    probably a good idea, i think the op left the house a long time ago.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ahhhh......a sundae on a sunday.....kool:LOL:
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Closing a thread after it has run its course is appropriate.
    With so many misunderstandings about the estimate value and misconceptions about capacity in general already being addressed in other threads, this one is proving counterproductive.
    It should be closed.
    cwerdna likes this.
  8. bisco
    52,861
    i just wish when they lock a thread, they would post the reason why.
  9. lensovet
    2,615
    496
    Burlington, NJ
    We have like 5 of these threads. But we should just get a mod to rename the title. Going to report that post now. Cheers.
  10. lensovet
    2,615
    496
    Burlington, NJ
    Well, that's now fixed :)
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Interesting... I guess one of the mods changed it since the OP's last activity was on November 1st...
  12. lensovet
    2,615
    496
    Burlington, NJ
    Lol read my previous post. I specifically asked them to change it. In fact, ONLY a mod can change the thread title, even the OP can't :)
  13. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  14. lensovet
    2,615
    496
    Burlington, NJ
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Try Edit > More Options. I just changed the title of the BSG thread again.
  16. lensovet
    2,615
    496
    Burlington, NJ
    tried that.
    apparently, it depends on which forum you're in. fred's house of pancakes is a free-for-all, so you have permissions to do just about anything there. in this forum though, you can't do it. just find a post that you've started here and try it for yourself.
    anyway, this discussion has gone way off the rails. and like into the ocean. lol.
  17. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Maybe so... I tried editing one in Other Cars and that worked too (Cars.com: Automakers to Scrap Thousands of Sandy-Damaged Cars - title test | PriusChat), but it did put on the "Last edited" text.
  18. Den Hare
    Den Hare New Member
    Hi there, I am Den, the one who started this whole thread. On a full charge using 115 VAC, I have dropped down to 9.5 miles now and holding at that range. I have 2500 miles on the car. My over-all milage for that 2500 is 75 MPG.
    I did start out at over 13 miles after a full charge and now with the 9.5 miles I cannot go as far. I wish I had built a Chev Volt.
  19. Den Hare
    Den Hare New Member
  20. John H
    John H Senior Member
    2,208
    558
    75 MPG is not something to just walk away from. You are doing better than most non-plug in Prius.
    You can trade in for a Volt. If you have some questions, maybe start a thread on the Volt sub-forum and a few other Prius/Volt owners will answer.
