Confusion on 2012 used Prius C three Master Cylinder break replacement
Discussion in 'Prius c Main Forum' started by thefyn, Jun 14, 2024.
  1. thefyn
    thefyn Junior Member
    33
    Treasure Coast
    I was told my 2012 prius c three needs master cylinder re breaks. I'm seeing two different looking items pop up.
    See attached. Symptoms are break pressure issue where the pedal seems sticky and breaks intermittently fail when pushing down.
    So which one would I need to get to solve the pump issue? Mine has the 15" wheels if that matters.
  2. ChapmanF
    19,060
    The one with a plunger attached to the brake pedal that's pushed in when you brake is the master cylinder. Of your two pictures, it's the shinier one. :)
    It's also probably the one you need.
    You were told, by whom? Are there any warning lights showing on the dash?
  3. thefyn
    33
    Treasure Coast
    Thanks man. Off the top of my head the lights (along with beeping) are the attached. I'm not near the car now for my actual dash but I think this image is it. Initially I told the Toyota dealership of the problem and they said it passed their tests. The warning was intermittent and not happening when I took it there the first time. Now there is a whirring sound every 20 seconds like it's trying to engage whatever failed. I took it there when it was lit up like a Christmas tree on the dash but the breaks worked and then they told me (despite the breaks working) that the master cylinder needs replacing soon and I trust them. I just want to get a used one as the new price is nuts.
  4. thefyn
    33
    Treasure Coast
    Image attached
  5. ChapmanF
    19,060
    The whirring is the normal sound of a pump that makes up your braking pressure. The not-normal part is the pump having to run so often; when the system is tight the pressure will hold up a long time (hours-ish, if you're not using the brakes) before the pump has to run again.
    The master cylinder probably is what you need. For future situations (and for other readers), when you have those brake warning lights on, you can get the trouble codes right away, like this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    That can save precious time on waiting for somebody else to tell you what's wrong.
  6. daffodilistic
    daffodilistic Junior Member
    Malaysia
    2015 Aqua
    Based on my recent experience, your brake actuators (which have the pumps on them) are about to fail. You should get ready spares, money and time to get it fixed.
