Connect charging cable to 240V outlet?
Discussion in 'Prime Main Forum (2017-2022)' started by EVnovice, Sep 1, 2019.
  1. GKL
    GKL Active Member
    543
    265
    South Carolina
    2020 Prius Prime
    Thanks, that is interesting to know, so Toyota including that reason also for having a charge timer would indicate too long on a full charge could have an effect if done on a regular basis. I wonder if Toyota actually specifies a recommended time limit for having a full charge while just sitting unused.
    I had heard another reason was some people get cheaper electric rates during certain times, so you would have to hope the time you get cheaper electric rates is close enough to the time you will next drive your car that would car would not sit long after finishing charging, and since some people work 2nd or 3rd shifts and might need to charge during the day I wonder how that works out for people with unusual schedules.
  2. fuzzy1
    10,723
    Occasional instances are not an issue. If they were, the car makers simply could not put a warranty on the battery.
    But absent warnings and guidelines, numerous customers would immediately top off the battery after every single use, for the full life of the battery. Numerous commuters with free charging at work would have it fully topped up 163 hours a week, year-round. The accelerated aging would then be quite noticeable.
    Unlike home recharging, most braking and coasting isn't prolonged enough to be amount to a full charge. There is a difference between deep and shallow charging.
    On the few long downhills that do produce full charges, the car is getting back 'free' energy that has real value. If properly controlled, this value received should exceed the cost of accelerated battery aging. Home charging is not free, it costs real money, so the value tradeoff is different.
    And if the battery is too hot, the car does reduce the regenerative recharge rate.
    mveras1972 likes this.
    52,904
    unfortunately, toyota does not recommend anything specific. likely, the vague instructions are legalese to keep them out of the 'the manual said to do this and that's what i did' lawsuits
    GKL likes this.
  4. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I would think that if 240V promotes premature battery aging, then it would void the traction battery's warranty.
  5. Gokhan
    Gokhan Senior Member
    6,718
    2,672
    Paramount CA
    Level 2 charges cost $150, not $350. I wouldn't mess with homemade adapters.
    https://www.ebay.com/itm/EVSE-Electric-Vehicle-Charger-EV-Level-2-220Volt-16A-for-Leaf-Volt-Prius/263387254095
  6. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I owned that exact Chinese junk, it fail the first day I had it...
    Knowing what I know, I wouldn't plug my lawnmower into it.
    The American Toyota OE 120v EVSE is the EXACT same unit as the European model, the only difference is the 240v country plug. Once the American version gets 240v it operates just like it's in Europe.
    I build one of the finest adapters available today, right here in the USA.
    Rob43
    mveras1972, jb in NE and Gokhan like this.
  7. Gokhan
    6,718
    2,672
    Paramount CA
    Thanks for the info!
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    The US OEM EVSE is limited to 12 Amps. Is that also true in Europe? That is why using a third-party EVSE (like a public charging station), which can provide the 16 Amps that the car's internal charger will accept, will deliver a full charge in 2 hours, whereas pushing 240 V into a US OEM EVSE takes about 2 and a half hours for a full charge.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    That's correct, the OE EVSE is limited to 12 amps.
    If you need to charge up a bit faster than 2:27 minutes when at home, you will need to spend the $$ to buy a chinese built EVSE or spend the $$$$ for a better built (ClipperCreek LCS-20) EVSE unit.
    Rob43
  10. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Just curious, why would that “Chinese junk” linked in the earlier post uses a 14-50 plug if it only uses 16 A?
    iPhone ?
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    NEMA 14-50 is a common receptacle. Very common in RV Parks, where you could park next to one away from home.
    Ideally you want an adapter that fits what you encounter while traveling.
    One of the 'Chinese junk' has 5 plugs
    #31 JimboPalmer, Sep 12, 2019
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Right now, installing a 240V outlet just for my PRIME is cost-prohibitive, and not needing multiple charges in a day, faster charging time is not something I need. However, if I am to install a 240V outlet in the future, I want L2 EVSE with a smartphone app that I can record and control charging session. That functionality alone is worth $$$$ for me.
