Connected Leads Wrong While Jumping Prius...
Discussion in 'Gen 2 Prius Technical Discussion' started by Friendlyx, Mar 30, 2020.
  1. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    The simplest and most direct thing you can do is to use a meter or test light to verify that you are getting 12v power on both the constant and switched lines. No power there means trouble upstream in the car- either a burnt out fuse that you haven't found yet, or possibly a burnt wire.
    From your description I think you're going to find that the switched power works, but the constant power does not, but you'll want to prove this out properly.
  2. james909
    james909 Member
    107
    Leeds, U.K
    Hi. Did you ever fix your stereo. I have the ncon on my car. Stereo won't turn on.
