Consensus on HV Battery replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DobroJim, Aug 5, 2015.
  1. DobroJim
    DobroJim New Member
    Washington DC
    Newbie so I hope I have not missed the answer(s) to my query in my searches (I did try to look)
    Here is what's up.
    Wash DC Metro area
    2005 Prius bought used w/ 80,000 miles in Mar 2014. Driven extensively since then as it is our highest
    MPG vehicle in the family so it's the default car for most trips or especially for our longest trips. It now has
    somewhere over 120K miles.
    Until yesterday, I was lovin this car like none I've ever owned. My daughter(17) drove it to Frederick Md
    over the weekend and before she could drive it back, she got freaked when the triangle of death appeared
    and the message was take immediately to the dealer. So she did (DARCARS) and their diagnostic came back
    with the P0A80 code indicating the likely need for a new HV battery. OK so we know the dealer wants an arm
    and a leg for a new installed battery so naturally I began doing market research on a replacement.
    Found GreenTec with 3 levels of replacement batteries ($1K to 2.3K) with the top level coming with a 4 year
    warranty. Found the Hybrid Shop (Curry's) with diagnostic and reconditioning services the reconditioning
    costs ~$1900. Seems like not much of a bargain when you can get an after market topline battery for small
    amount more. Also contacted a place in Richmond VA Hybrid Battery Pros and they offered a remedy for
    only $1000 by replacing just the bad modules.
    I'm probably not the best person to do a lot of diagnostic on my own and have important needs that dictate
    towards a more immediate resolution.
    In the meantime, the dreaded triangle is no longer lit up. The dealer had said that it was impossible
    to predict whether the existing battery would last 6 days/weeks/months.
    So I'm seeing a lot of trade-offs in terms of what the best (cost-effective) solution might be.
    I would be particularly interested in the experience of the group with any of the particular vendors
    mentioned so far.
    Also of interest is the likely immediacy of need if it's possible to predict. I was reading some of these
    threads and was noting talk about recharging (while driving) the HV battery and how quick recharge
    is an indicator of troubled battery but was unclear which screen on the display to view. I typically
    used the screen that shows the 5 min bar graphs of mileage and not the power flow diagram. Is that
    the one I need to look at to evaluate HV battery charge.
    I like the car a lot and my inclination is to repair it. My wife and kids drive it a lot so I don't want
    them to be stranded.
    Why the term Tractor Battery I read in some threads?
    OK, sorry for all the newbie questions trying to get up to speed.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    OK Hi DC you're in my backyard.
    First of all, did DARCARs really check on your CARB warranty status for your VIN and give you high cost quote?
    CARB warranty is 10-yr and 150k miles so chances are your 2005 is just over 10-yrs.
    Apparently DC is not CARB but MD is CARB, but we really do not have experience to know how Toyota handles DC (special case).
    Apparently Toyota has a new software program where the dealer puts in the VIN and it tells the dealer if the car is under warranty...we've had a few pleasant surprises with the software.
    Assuming you are out of warranty, you have at least 2 options: (1) Ask Toyota for Goodwill Warranty coverage (see below) and/or (2) Go to (Greentec) for rebuilt. As for rebuilt, in our area Greentec is the popular choice lately. Our general preference here is however a new Toyota battery from the dealer.
    Here is the Link to our Goodwill Warranty tips. Sometimes this take extra time, so one reason to go Greentec if you need to get this show on the road. But if it was me I would probably tell Toyota you got Greentec quote for $xxxx but would consider Toyota replacement with warranty assistance. You generally gotta talk to Toyota USA about this, not the dealer. If Toyota will help then they will contact dealer with the offer they gave you.
    See this link:
    HV Battery Goodwill Warranty Listing - Toyota Prius USA | PriusChat
    It is your HV battery (High Voltage) also known as "Traction" Battery because it builds up power from traction (breaking). There is also a slim chance the battery is OK but the cooling fan is clogged.
    ursle likes this.
  3. ETC(SS)
    7,569
    ^ +1, except that I lean the other way where remanned - versus - OEM is concerned.
    Not worth quibbling about if Toyota Goodwill Warranty gets you within a few hundred bucks, in which case I'd go with the OEM unit.
    Good Luck!
    Let everybody know how it comes out!
  4. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Right and also since your PA080 code is clear, you probably have to wait until the code goes off again. Could consider $200-300 job to clean cooling fan to see if that helps extend batt life. Also tell me 2005 date car first bought if you know it.
  5. DobroJim
    DobroJim New Member
    Washington DC
    Many thanks. That's helpful. The previous owner of the car had actually died. I'm not sure how long the car sat
    or how often it was driven before we purchased from the estate of deceased (added information). We had
    driven the car a lot since we bought it though.
    Traction battery. I get it. That makes sense.
    I will check the link for Goodwill warranty with fingers crossed. And good to know that one of the places I found
    (Greentec) has a reasonable reputation.
  6. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Maybe wait for a few more posts for input
    merged
    One thing is do not be too thrilled with the 3-4 yr warranty at Greentec, although you made need it as the rebuilds are less reliable.
    Toyota will only give 1-yr warranty but we are expecting 8-10 years life like you just got.
    #6 wjtracy, Aug 5, 2015
  7. strawbrad
    953
    1,007
    Just to be clear. There is no such thing as an "after market top line battery". Toyota sells new batteries. Everyone else sells batteries reassembled with used battery modules. Some re-builders claim they can "recondition" modules to like new performance. Others believe that there is no way to regain lost capacity. That school of thought believes the best that can be done is to test modules remaining capacity and assemble a pack with well matched good capacity modules.
    Too bad you are not in MN. I install batteries with tested well matched good capacity modules for $700.
    Brad
  8. DobroJim
    DobroJim New Member
    Washington DC
    OK. I spoke with someone at the Goodwill 800 number and politely grovelled for some assistance. They were nice enough but
    due to the fact this is our first Toyota and I'd never had it serviced at a Toyota dealer, 2 factors they told me they looked
    at when assessing how much assistance to give someone, the most I was told they would be able to offer me was $500
    towards a new Toyota battery and installation. So I gotta say thank you to the PriusChat for that.
    I was thinking of going in the GreenTec direction but Brad/wjtracy's post has me wondering about that potential choice. GreenTec's website makes the claim that their batteries are actually better
    than a (new) Toyota battery. I take from your post that you would take considerable issue with
    that claim.
    Too bad MN isn't closer, I'd consider a roadtrip.
    I still have not actually driven the car since this all went down. I also want to test the 12v battery although I assume
    the diagnostic the dealer performed would differentiate problems with one battery vs the other.
    I will post more later when I get to the point of actually doing something.
    PS merged - I do not know the date the car was first purchased/driven since that happened long before I owned it.
    Presumably Toyota does.
    #8 DobroJim, Aug 6, 2015
  9. ETC(SS)
    7,569
    There are two reasons that I lean away from using an OEM battery pack for a ten year old car with 120,000 miles.
    Reason # first: Expense and ROI
    I'd probably just toss the least expensive battery pack with a two year warranty into the car and drive the crap out of it for 2 years and see what comes. From what I can tell, $1200-$1500 seems to be the industry average for this.....and two years from now there will probably be more---not less competition in the traction battery refurbishment field.
    Reason #2:
    I like companies that are looking to expand their customer base.
    I would have thanked the nice people at the weirdly misnamed "Goodwill" place for their time, and told them that this was my first----and last Toyota. ;)
    I dig the repeat customer reward thing, and I think that 10 years and 100,000 miles is a darned good warranty on a battery...but there's just something a little distasteful about being advised that a car that being serviced by the customer is in a different 'goodwill' bucket than one who makes an appointment with a service manager every 5,000 miles.
    If I'm Toyota.....I'm going to throw you a bone and try to get you to be a REPEAT customer.
    Holding a bone juuuuuust out of reach and advising you that it's too bad that you're not a repeat customer seems to be going the other way - especially when you were just outside the warranty period.
    Toyota has ROI to look at as well.....but here's the thing.
    A G2 with 120,000 miles is going to be needing some long periodicity maintenance....like coolant and transaxle fluid replacement....plugs...TB maintenance....etc.
    They've just given you a very powerful incentive to do what many people (like me!) are already doing which is DIY or outsourcing.
    Bad call Toyota!
    DobroJim likes this.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    OK there are diagnostics here for the 12v, and for sure you want to make sure 12v is good.
    Also if codes clear up, consider a job to clean the batt cooling fan. If the car ever sees dogs hair, that's one issue.
    If you are not satisfied with Toyota quote try again. You are shooting for $2000 OTD for the batt job. Maybe a little more.
    Some go to different dealer and start over just to get a second opinion.
    When you start car, give it a few minutes to warm up. This takes some stress out of it,
    You generally want A/C on to help cool the battery, but I might leave it off during first couple minutes warm-up.
  11. DobroJim
    DobroJim New Member
    Washington DC
    Thanks ETC(SS). Appreciate all the points of view. The place I called in Richmond VA, Hybrid Battery Service,
    had offered a battery for the low low price of a thousand, IIRC. I'll call them back to confirm that. The one question
    to that approach is obviously the hassle factor with potentially having to deal with the same issue in 2 years or less.
    That and their location, relative to me, is not great. GreenTec's low end option is 'only' $1100. The saleswoman I
    spoke with was clearly trying to steer me towards the pricier choices.
    merged
    One other point I came across in my research was a couple of dire warnings against DIYers which I understand could be
    totally self serving. I actually do have reasonable mechanical skills and tools. Electrical things tend to be my weaker
    area however. One warning was against potential electrocution, which is obviously scary but not sure how real.
    The other thing was the reported weight of the battery if I were to attempt removal and replacement myself. I'm told
    the thing weighs 400 lbs. Pretty heavy to lift if true, especially if you're trying to lean into the hatch area and
    don't even have a good angle to lift from. But doing a fan cleaning doesn't sound like something that ought
    to be that difficult for a DIYer. That said, sometimes things such as dis-assembly in an older care that ought to be
    straightforward encounter roadblocks due to the age/corrosion with various connectors/nuts&bolts.
    #11 DobroJim, Aug 6, 2015
  12. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    No its not that bad to DIY if you have skills...not 400 lbs maybe 120lbs I think. Many threads here.
    Electrical safety is important but much on YouTube and here.
    One good option is get new batt from Toyota and DIY install.
    If you're heading to Richmond the historically reputable place is MACs in Ashland but he probably $2000.
    merged
    See the Goodwill Warranty post for a new case today he got $1300 OTD
    #12 wjtracy, Aug 6, 2015
  13. ETC(SS)
    7,569
    I haven't looked, but I'm betting that there's a Youtube vid on replacing the traction battery.
    I think I'd watch it and see.
    I haven't seen it, but I'm thinking that the pack is connectorized, and I'm betting that it weighs less than a buck fifty.
    If punk kids are stealing them out of cars in some of the demilitarized zones in big cities?
    I'm thinking that a person with a hundred bucks worth of tools and a good internet connection can replace one.
    As far as the PITA factor....yes, I get that but I'm thinking that a two year guarantee on a ten year old car is enough for me to toss $1200 at it. It depends on what other problems you might encounter with this car during the next two years, and how much you depend on it.
    My daily commuter is an 06 Envoy with 160,000 miles...but I have another car, 2 motorcycles, a golf cart, a bicycle and my commute is 3 miles. My commuter car doesn't have to be as dependable as a single parent with a 50 mile ride to work and a crumb snatcher to drop off and pick up from day-care.
    Your financial depth band is also important to consider.
    If you can stroke a check for $1200 without wincing, then it's going to look a little different than somebody who will have to eat Ramen noodles for a month after spending that same amount on a car repair.
  14. gdanner
    gdanner Member
    140
    53
    Central Illinois
    I did DIY repair on my 2005 Prius HV battery. I replaced 2 modules with used/tested modules that I bought on ebay.
    Regarding getting the HV battery pack out of the car, it is essential to have 2 people to do this. It's much much easier to handle it with 2 people. The HV battery pack is too heavy for one person to handle it easily.
  15. DobroJim
    DobroJim New Member
    Washington DC
    Video on You tube makes removal appear not too difficult but the author admitted re-installation was harder and took longer
    than he anticipated. GreenTec only charges $150 to install a new battery, $450 for mobile service. $150 seems pretty fair.
  16. JC91006
    16,936
    8,647
    Anybody can remove and install a battery, as long as you don't open the case. That process is no harder installing or uninstalling, it's the same thing. If you have basic socket tools, this should take you around 2 hours. A pro can do it in 30 minutes
    Here's the best video I've found, from Dorman
    ftl likes this.
  17. ChapmanF
    19,038
    Somewhere on PriusChat is a post by a resourceful elderly gent who did it solo with a couple of 2x4s and no muscle strain. He laid the 2x4s over the back edge of the trunk/hatch opening and ramped the battery up them. As it passed over the edge the 2x4s seesawed down and he continued ramping it right down onto his (cart or whatever).
    -Chap
  18. aaronlife
    aaronlife Junior Member
    66
    Massachusetts and Florida
    My dealer said his mechanics are extremely careful with the battery as the voltages are high; they don't let anyone else near them when they are working, so if you do DIY, take all safety precautions (linesman gloves, etc.).
    With $500 from Toyota if you shop for the best dealer price you'd be out the door around $2000 (dealer battery prices start around $1950 plus tax and labor), which is similar in price to the top of the line Green Tec, if not less. If Green Tec is convenient to you, either solution should cover you for the next four years, and at around $500 per year battery cost broken down, if the battery goes in 4 years, that's a minimal expense (if you still have the car)
    The $1500 installed green-tec solution gets you through the next 18 months at a reasonable price too, you're basically gambling the cost of fuel savings on the battery (at least with my average fuel savings vs a regular car). If you plan to drive another 40,000 miles in that time, the warranty is worth it.
    The issue though is whether other costly problems will arise if you keep up the high mileage driving. I recently spent $3000 on an uncommon brake actuator failure at 110,000 (plus new front pads and drive belt which were due for replacement). I went with new parts at the dealer because I had a 1000 mile drive a few days later. Could have saved a bunch doing used parts. Then my traction battery started to fail, after the trip, and Toyota graciously offered goodwill assistance on the battery, which I accepted, but i have to say, at about $4500 spent on the car in the last two months, i am now gun-shy on driving older Prius cars. You can buy them used for $4500 in perfect working condition... replacing might be the better cost effective option. I'm starting to think new (or recently or certified used) again...
    I'm starting to look at the per year cost of ownership as a new ownership model, whereas I buy newer cars and replace them more frequently, losing money on depreciation vs repairs. That way my money is spent enjoying a newer car, rather than fixing an older one that is starting to feel it's age (seat leather, etc..).
    My best case on my Prius would have been to sell last year under 100,000 miles when everything was working great... now, in the last 5-10,000 miles I've got a sqeaky strut noise (not a big deal right now), the brake failure, and now the battery failure.
    If you love the Prius, you may want to trade it as-is (sell it cheap with known prior error code to someone not afraid to replace battery), or replace the battery with used, and drive it until you find a nice 2008 Prius with fairly low miles so you have another few years of battery warranty and newer, low mileage parts. Compare costs on future repair bills for your existing Prius vs. sales tax and depreciation loss on a newer low mileage model... if you are putting 40,000 miles on per 1.5 years, you have to consider how many more miles you want to put on the Prius you have now.
    merged
    Top of the line green tec contains all new cells from what I understand, so it may be comparable to OEM battery with better warranty, though it's an unknown product at this point long-term.
    #18 aaronlife, Aug 7, 2015
    wjtracy likes this.
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Actually sell it to someone in MD which is CARB state and maybe they get lucky on free batt replacement.
    One idea is to get Toyota batt say $2000 and pay $150 to Greentec to install (if they would).
    But I am not sure Toyota would not do that.
    I am not quite sure OP situation, but I am thinking he has car at home with PA080 code not currently active.
    Unless he is at Toyota dealer with PA080 lit up, Toyota is not quoting on the total job.
    merged
    We are not aware of that it had been called false advertising in some threads so we need to be careful. I don't think we have any rebuilds based off new cell right now. If we did I agree it could be equiv to new batt. Lucious Garage in CA is the gold standard and they have stopped using rebuilds and just go with Toyota batts. Check with Lucious garage to see if they had a changed policy. I guess nothing stops Greentec from buying a new Toyota batt but in that case OP can get new Toyota batt.
    #19 wjtracy, Aug 7, 2015
  20. JC91006
    16,936
    8,647
    You have to read the fine print very carefully with Green Tec. They do not give you new cells, they just describe it as such. But if you pay close attention to their wording, you would then know it's a rebuild.
    All their claims are questionable, as their claim of their rebuilts being essentially better than "new". Also just because they offer a 18 month warranty, it does not mean you'll have 18 months of trouble free service. It just means if it fails (which it will), you'll be covered. And you better read the fine print on who covers the shipping and reinstalling of the covered part.
