Considering 2011 Prius with 100K miles
Discussion in 'Gen 3 Prius Main Forum' started by FlyBoy68, Sep 9, 2015.
  1. FlyBoy68
    FlyBoy68 New Member
    I'm considering purchasing a 2011 Prius with 100k miles on it. The vehicle looks like it has been properly maintained. Questions:
    - what mpg should I expect?
    - what maintenance should I do?
    - what repairs should I expect?
    - how many more miles can I realistically expect to get out of the car?
    thank you.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    At 100 k new plugs (they ain't cheap) other than that I would follow the maintance schedule in the owners manual. Expect another 50k with few problems, after that it is a crap shoot, you might get lucky to 200, you might not.
  3. tv4fish
    tv4fish Member
    202
    46
    Since you are in a warm climate- you should get 45-50 mpg (It WILL depend on how you drive it, however)
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    695
    269
    Maine
    I have a 2011 Prius with 100k miles on it.
    At the 100k servicing, I was told that it will need a brake job soon on the rear brakes [$350], and the valve cover gasket is leaking and will need to be replaced [$1200].
    Otherwise it has not had any problems.
    I spoke with the Service Manager, about his thoughts on trading it in. He told me that he routinely sees these coming in with 200k and 300k on them, and in the same condition as mine is in. He urged me to keep it and not trade it in. [I am sure the sales staff would advice otherwise].
    We are still getting mpg in the high 50s.
    I take it in every 10,000 miles for synthetic oil change and tire rotation. I will keep doing this routine as we go toward 200k.
    The car body is mostly plastic. Roads here get pretty bad at times with frost heaves and potholes. Various pieces of body work attach to one another via plastic/rubber tabs. Those tabs let loose sometimes, as they age and fatigue. I have hit frost heaves that caused the front tire to bump the wheel well and knocked that plastic loose. So that needed more holes drilled and zip-ties hole it together now.
    As plastic and rubber age they slowly get brittle. Don't freak out if you see a part of the under-body splash-guard hanging loose. Just ask your service tech to re-attach it.
    breakfast likes this.
  5. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    I went 230,000 miles in a 1996 Subaru Legacy with zero problems. It used a quart of oil every 3000 miles, but even brand new cars can't get repaired under warranty for that. My point is that expecting only 150,000 trouble free miles seems unimpressive. Needing a valve gasket at 100k is absurd.
    Heck, I have 100k on my 2006 Acura TSX, and it has needed absolutely nothing. Still on the original brakes, and it doesn't even benefit from regenerative braking.
    All modern cars should go 200k trouble free miles. The Prius, having no belts of any kind, should be even more reliable.
  6. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    $1200 to replace a valve cover gasket seems like an awful lot to me. I would get someone else to look at the need for both jobs and if they think the work is needed give you a price. You could also get some cost feedback on the maintenance forum.
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I would expect a 2011 to deliver mid to upper 50's if it isn't a Five. If you are going to drive it like you stole it or only on short hops then low 40's. Enjoy.
