Considering a used prius with a dead battery
Discussion in 'Generation 1 Prius Discussion' started by adric22, Dec 19, 2009.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    Looking for some opinions here. There is a local used-car dealer who has a 2002 Prius with 160K miles on it and a dead HV battery. He said he bought it at an auction and discovered it wouldn't drive properly and eventually got a toyota mechanic to diagnose it as a bad battery. So he took the battery out of the car and tried to find a new one, but couldn't. Currently the backseat and battery and lots of trim panels for the rear area of the car are all taken out and laying in his shop. He is asking $3,100 for the car as-is. I offered him $2,500 and he took down my number and said he'd think about it.
    The car is in pretty good shape otherwise, from what I can tell other than it needs new tires.
    How hard/expensive would it be to get a new pack? Also, he said that he used a multimeter and found that there were just a few cells that were actually bad. Does this sound reasonable? Would it be possible to replace those cells?
    Also, are the cells in the Gen 1 and Gen 2 prius interchangeable?
  2. bwilson4web
    15,586
    1. Call Toyota but the NHW11 traction battery alone, new, has been reported to be about $2,400. Used is going to be 'luck of the draw,' $500-$1,500
    2. Having it disassembled makes it harder because you don't get the experience of seeing how it was put together.
    3. Include a set of Toyota repair manuals, $150-300 (new)
    4. NHW11 and NHW20 modules are either/or. All one or the other but a total of 38.
    It is entirely possible to rebuild the NHW11 and you'll learn a lot. But don't think it will be cheap. It will be interesting and you'll learn a lot.
  3. adric22
    642
    144
    Fort Worth, TX
    Well, this is where it comes in handy that my best friend is a prius-certified toyota mechanic. He can help me re-assemble it.
    I'm sorry.. I don't comprehend this statement. Can you re-word it or expand on this?
    You might be wondering why I'd even post on here with my friend being so Prius-knowledgeable. The thing is, from his standpoint he doesn't ever mess with individual cells or anything like that. They just pull out a battery pack and put a new one in. And as I'd obviously be looking for a cheaper way to repair the vehicle, I need to go a little beyond his expertise.
    I'm actually wondering if it might be possible to replace the original pack with an appropriate configuration of standard off-the-shelf NiMh batteries.
  4. orange4boy
    orange4boy Member
    231
    43
    Vancouver BC
    2003 Prius
    He means you can't inter-mix the two types of modules. They are slightly different. You have to build the packs with either all 2000-2003 (Gen 1) or all 2004-2009 (Gen 2) modules. The only problem is the newer packs have less modules than the earlier packs so you need two gen 2 packs to make one gen1 but the newer ones are much improved.
  5. adric22
    642
    144
    Fort Worth, TX
    I have seen several posts where people have mentioned using the Gen-II modules (by getting two packs) as a theory.. But has anyone actually tried this or confirmed that they will physically even fit?
  6. bwilson4web
    15,586
    I have not done it myself but I've measured the modules and it looks practical.
  7. adric22
    642
    144
    Fort Worth, TX
    Yeah, I actually I had already looked at these shortly before you posted. Unfortunately it is sort of an issue that I am not sure I will get the car, so I hate to place a bid. And I'm not sure I'd win the auction at a reasonable price in which case I'd hate to buy the car without knowing. So it is sort of a catch-22 scenario.
  8. bwilson4web
    15,586
    Check completed traction battery sales and you'll find they come and go. But it best to get the 'sick' horse before the cure.
  9. Patrick Wong
    18,200
    6,479
    The Classic Prius battery is composed of 38 rectangular modules. Each module contains six cells, so the battery is composed of 228 cells.
    It would not be very practical to attempt to replace this design with off the shelf batteries.
    I think it is a bad idea to buy the car, not knowing whether it has other problems that can be very costly to repair. Electric steering gear and transaxle are two examples.
  10. tochatihu
    tochatihu Senior Member
    9,070
    3,538
    Kunming Yunnan China
    2001 Prius
    This web site
    Car-Part.com--Used Auto Parts Market
    currently lists several. It is indeed a concern whether any other problems might be hiding behind this one, and what might be revealed by a carfax or similar check.
  11. firegirl
    firegirl New Member
    kauai
    2003 Prius
    Aloha. I have a 2003 prius and the battery was replaced by the dealer last year. The rack and pinion has gone out on it now and I am too remote an area to get it repaired. Maybe you could use the battery or the whole car since the 2002/2003 seems to be interchangeable. Great little car, worth getting it together if you can.
