Considering buying a Chevy Volt, any owners of both here?
Discussion in 'Gen 3 Prius Main Forum' started by Markdizle, Jul 26, 2020.
  1. Markdizle
    Markdizle Member
    110
    75
    Huntington Beach
    I like my Prius but the Volt with its 53mi electric range is enticing. I also like that it would have newer tech in it (looking at getting a Premier). I have a prius two and it’s pretty lacking on features.
    I’m looking at 2016+, I know they are no longer being produced. Looks like I can get a low mileage Volt for around $20k
    Thoughts, comments??
    #1 Markdizle, Jul 26, 2020
    51,087
    nice car from everything i've read. i don't think you can go wrong.
  3. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Previous to Current:
    2012 volt
    2013 Cmax Energi
    2018 Clarity
    Unless hatchback needs are critical, Clarity hands down. It's simply a much larger and more comfortable vehicle (cmax is too); heck I even loaded a boxed 50 inch TV in the back seat and didn't need the trunk pass through. If you only need it for single person commuter, volt is OK. Anecdotal viewing of related forums over a decade says its reliability is lowest of all.
    Warning: once you go plug, you won't want to go back!
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    @leeb18c has a 2017 and I know he enjoyed it;).
    Maybe he'll drop a line here and comment on any other observations(y).
    SFO, Markdizle and Grit like this.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,039
    775
    Virginia, USA
    Your title says Volt; first line of the thread, you write Bolt.
    I'd consider the Volt; I'd never consider the Bolt.
    GM was silly for naming them so closely.
    bisco, Merkey and Markdizle like this.
  6. Markdizle
    Markdizle Member
    110
    75
    Huntington Beach
    Haha volt not bolt!
    Johnny Cakes likes this.
  7. Tideland Prius
    16,443
    If you can find one in good condition, it's not a bad idea. You can take the Volt for short distances and take the Prius for longer distances. There is a thread somewhere (I can't remember if it's on PriusChat or some other forum or even a car article) that did the math for the crossover distance where a Prius is more efficient than the Volt (EV + gas mode).
    But otherwise, I don't see why the Volt isn't a good idea.
    Markdizle likes this.
  8. Rmay635703
    Rmay635703 Senior Member
    2,646
    1,668
    Somewhere in Wisconsin
    2013 Chevy Volt
    You should easily get a used volt similar to what you describe for around $15,000 or less
    The Gen II Volt is reliable but not rock solid like the Gen I
    It should get real world economy similar to a Gen II Prius (at least in warm weather)
    It’s generally the ultimate PHEV,
    if you get one with a 6.6kw charger you can have nearly 100% EV operation on all trips,
    There is also slow progress being made on mods and DIY repairs.
    If I didn’t already have a Gen 1 and didn’t need to spend mega bank on license and registration I might have traded my old 1999 Insight up for one
    Good Luck and Enjoy
  9. Johnny Cakes
    1,039
    775
    Virginia, USA
    This thread caused me to look into the Volt a bit more. The interior looks smaller, although I didn't compare actual specs. The idle engine turns off after 150 minutes, which prevents overnight camping without a hack. It was been discontinued after this year, if that bothers you. And premium fuel is recommended, with this quote from a GM Engineer:
    Premium gas will maximize the fuel economy when the engine is used, GM powertrain spokesman Tom Read said. In an emergency, regular gas can be used on the Volt, but fuel economy will be compromised, and the engine may become noisier. The Chevy Volt’s engine computer will detect the octane change and retard ignition timing. Still, Read highly recommends refilling the Volt’s tank with premium fuel as soon as possible to avoid damaging the engine.
    Bay Stater and Markdizle like this.
  10. Markdizle
    Markdizle Member
    110
    75
    Huntington Beach
    Thanks everyone for the feedback, will let you know if I pull the trigger on one! Def some pros and cons. One major pro is my mon- fri commute (and most weekend usage) would require 0 gasoline.
  11. bettergolf
    bettergolf Active Member
    476
    359
    Sanford NC
    That premium fuel requirement is for the gen1 (up through 2015 model). 2016 and after doesn't require premium. I'm considering getting a G2 volt also for the 50+ (G2) mile plug-in range. I haven't measured but I did sit in one and it appears to be a bit smaller than the G3 Prius...a little less head roon (I'm 6-2) the "trunk" area also seems to be a bit smaller and it's recessed , not good for those who may have back problems. The biggest negative for me is if there is a problem nobody knows how to work on it. Even the Chevy dealerships will have to hold the car until the "volt mechanic" can come there to take a look. At least that's what they say over on the Volt forum.
  12. Rmay635703
    2,646
    1,668
    2013 Chevy Volt
    Your information is out of date/inaccurate and only applies to the 2015 and down Volt,
    Newer Gen II Volt is designed specifically for regular fuel only
  13. Johnny Cakes
    1,039
    775
    Virginia, USA
    I've never really researched the Volt until this thread. What I found really interesting is that its HV battery must have much more capacity than the Prius. The Volt camping threads I saw indicated that it could run the AC all night up to 12 hours without starting the ICE. In the Prius, you are lucky to get an hour before the ICE starts.
    It also has a very cool "Mountain Mode" where it runs the ICE until the HV battery is completely topped off.
  14. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    My pastor and his wife have a Camry hybrid (2013, I think) and a Volt(not sure of the year). He thinks the Volt is rather small, and he is disappointed in the range in winter.
  15. Rmay635703
    2,646
    1,668
    2013 Chevy Volt
    Reminds me of the guy across the street that complains that his Prius only gets 16-19mpg in the winter and that the seat is too horrible for a long drive.
    I did look at his HID once and sure enough.
  16. hill
    8,630
    I was thinking of that thread too. I hate when I can't find stuff. It might have been @bwilson4web that calculated that out. & IIRC, it's somewhere in the mid 200 miles range.
    Corrections for some of the above "facts" (my neighbor and I swap cars frequently - so I Drive His volt quite a bit, hopefully so that each of us can make our next buying decision) .
    #1 the volt chargers at 3.3 k w. Only the last year, the 2019, is different. On the low end model, it had an option for 7.2 KW. The premium was standard width 7.2 KW - not the slower 6.6kw.
    Between plug-in clarity and the volt, the clarity is bigger, heavier, with more room, so it's electric range isn't as far. Volt has more electric range because it's lighter and less volume space inside. So, owners have to decide between the two different benefits/burdens.
    it's the gateway drug, once you fuel on electrons, you want more and more and can't kick the addiction.
    Some of the first-generation volts have 200,000 and 300,000 miles and more. .
    Also - Unlike the 1st gen 4 seater prime, the Volt technically squeezed a 5th in there, which is useful for little kids. Anywho -
    Considering we've had one of these;
    I would give equally high marks - after putting 1,000's of miles on one of these -
    ... and as you can see - one of 'em put a smile on my face.
    Correction on Mountain mode also. I drove the volt through 7 thousand feet mountains thru New Mexico early last spring. Still patchy snow on the sides occasional dusting of snowflakes. What mountain mode REALLY did, was let you keep the amount of battery capacity reserved, roughly, where it was - when you turned Mountain mode on. The reason that was great - was because now the battery's coolant gets to be warmed up - making subsequent EV mode all the more efficient). Also - if you're really having to put the pedal to the metal pulling a grade, the electric motors can deliver, without having to cause the ICE to really rev up. That was a benefit with Gen 2, where as gen 1 would really be noticeably revving. If you drop back down to level City street driving, Mountain mode well almost invariably go back to EV operation - as speeds under 40 mph take a lot longer 4 battery capacity teardrop.
    #16 hill, Jul 30, 2020
    Markdizle and Tideland Prius like this.
  17. Markdizle
    Markdizle Member
    110
    75
    Huntington Beach
    Thanks for your input I appreciate it! I use to love my Prius but now it’s more of a like. Great car but I want something (EVish) that’s fuel efficient, more fun to drive, and doesn’t cost as much as a model 3. Going to test drive a Volt tomorrow, we’ll see if I still want one!
    Merkey likes this.
  18. bisco
    51,087
    any thoughts on the prime?
    Raytheeagle likes this.
  19. Markdizle
    Markdizle Member
    110
    75
    Huntington Beach
    I can’t stand how it looks and it’s EV range is well below the Volt. Still a great car I’m sure!
    hill, bettergolf and bisco like this.
  20. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I have gotten 140 mpg with our Prime at over 24k miles:).
    25 miles EV is the EPA estimate and I typically get north of 30 miles;).
    So I'd consider it(y).
    Bay Stater, Grit and Markdizle like this.
