Consistently getting 35-37 mpg, nothing higher
Discussion in 'Gen 2 Prius Fuel Economy' started by guod, Apr 16, 2012.
  1. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    If your engine, after it has warmed up completely, runs when you come to a complete stop, and the battery is full, then something is not right. Normally the engine shuts off right away at a stop, or even before as you slow below 8 mph.
    If the battery is full, and you are descending a long hill, then the engine will eventually go into "B"mode, which is engine braking as in a normal car. You can also select this on the shift lever, which is a good idea. It does not "get rid of excess charge", it just keeps the charge current from being generated in the first place by taking the load off of the regen and friction braking systems. But this only happens at speed.
    If you find the battery gauge quickly goes through large swings from empty to full with normal driving then you might have HV battery problems, perhaps a bad cell or two. Using a scanner and software would allow you to read out the various module voltages and see how much variation there is.
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    That is incorrect. There are several circumstances that can cause engine to continue to spin after stopping, and top on the list is that exact thing that the OP mentions, excess HV battery charge.
    Anytime you have to stop with full 8 bars of SOC then this can potentially occur. (As well as the opposite situation of course, where the engine can continue to run if the HV battery charge is very low.)
    Another circumstance is the need for cabin heat, though as you say, if the engine is completely warmed up then it should be able to provide heat for some time without running the engine. Never the less, when diagnosing an "engine running when stopped" issue I'd say you should always turn off all heat to be sure that this isn't the cause. Turning off all heat on the gen2 prius isn't as easy as you might think. Unless you set the temperature all the way down to "max cold" then even if both AC and auto-AC are completely off the heat will continue to run, even if just the fan is blowing.
    The other possible cause is "hybrid stage 3a" which will cause the engine to run for up to 10 seconds after stopping.
  3. guod
    guod New Member
    24
    Los Angeles
    well i dont have heat on at all cause i do have it set to completely off and it has been set at max cold for the past few weeks, as it has been a little warmer the over here.
    On my last tank, i got 35 and that was with babying the throttle.
    I ordered the optima yellow top, so we shall see if that does anything, but i am not holding out much hope
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Don't baby the throttle too much. When you need to accelerate then it's almost always best to use the gas engine for that purpose (and hence save the battery for where it can have maximum effect, where you can glide).
    Acceleration is best done at a medium throttle, not flat out, but not too light either.
  5. guod
    guod New Member
    24
    Los Angeles
    well under normal acceleration, I was getting bad mileage, so I thought i would try a lighter touch.
  6. guod
    guod New Member
    24
    Los Angeles
    bump...car is at the dealer today. i have 149800 miles on the car so i figured i would take it to the dealer before 150 as if there is a problem with the HV battery, I want them to pay for it :) hopefully they figure somethin out
  7. Rm7pr
    Rm7pr New Member
    I just bought a 2012 Prius 3 with 3 miles on it. Funny enough I was getting about 40 on the Eco Mode and about 46 in regular mode. Not sure if the 2004s have the different mode but maybe u can try that. Could it also be that with all the miles on it it's performance has just gone down?
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The Gen2 does not have different modes. Performance doesn't "just go down", there's always a reason or two but it can be a bugger to find.
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    Make sure the optima is fully charged before installing.
    I have a gen2 and once it got mileage in the low 30's, tracked it down to a misfiring spark plug, didn't set off any alarms but definitely affected mileage, good luck with the dealer, get an estimate and think about the services they offer, even post it here, some dealers are great some aren't.
  10. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Are there any Prius specialists like Luscious Garage in LA?
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I would try a set of LRR tires (Energy Saver A/S or Ecopia EP422), cleaning/adjusting the rear drum brakes, alignment and replacing the 12v battery.
  12. guod
    guod New Member
    24
    Los Angeles
    so the dealer just told me that I need to do an EFI cleaning and that everything is good. but i got the battery and drove 9 miles and mileage seems to be better so hopefully it holds up
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
