Constant ticking noise while braking (not related to brake calipers)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by charlie_rivera1, Jan 23, 2013.
  1. alwaysthirteen
    alwaysthirteen Junior Member
    50
    Has anyone determined the cause of this? I have the same issue. Car went to the dealer today and while they could hear the sound, they couldn't determine what was causing it.
  2. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Wow, after 21 posts no one has posted the correct answer.
  3. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
    Has anyone figured out a solution to this?
    Mine also seems to start clicking switching to "B" from "D"
  4. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I took mine in 2 weeks ago. They replaced the drivers side axle shaft and the noise went away. I hear it intermittently on the passenger side but not enough to warrant replacement per the dealer. This was going through the shop foreman since it was my fourth visit for it
  5. sdtundra
    1,314
    193
    Sacramento, CA
    Per the foreman it appeared that the shaft was not lubricated properly during assembly which was causing a metal on metal contact
  6. 2ZR JDM
    106
    142
    Redondo Beach
    Did it sound like this?
  7. sdtundra
    1,314
    193
    Sacramento, CA
    Yes, very similar but more constant
  8. Former Member 68813
    3,524
    983
    US
    OK, I'll bite. What is the "correct" answer.
  9. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    It's the one that is right, silly. :D :p
    SCH-I535
  10. Former Member 68813
    3,524
    983
    US
    Right, you're right.
  11. charlie_rivera1
    charlie_rivera1 Junior Member
    Palmetto, FL
    I finally had my car checked at the dealer. Even though they heard the noise they could not tell what it is causing it. They checked everything and told me the car is perfect. They do not have a clue of this noise.
  12. ryankokesh
    ryankokesh Junior Member
    33
    Anyone else figure this out? Was replacing the cv a long-term solution?
