Consumer Reports Drives Touring Edition
Discussion in 'Gen 2 Prius Main Forum' started by Prianista, May 25, 2008.
  1. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
  2. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Who? Me? I posted some pics of my new ride here: http://priuschat.com/forums/newbie-forum/42188-newbies-lets-see-some-pics-23.html#post628802
    Thanks for the link! The picture shows pink and white but I looked with my eyes and saw pink and red! So I guess I have the touring struts at least.... Now to measure the sway bars... :)
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  4. Boo
    5,051
    488
    97
    Flushing, NY
    Rear Strut Stripes: Touring Pink & Red /Standard Blue & Red
    Michael,
    Probably your flash made the pics of your Canadian Prius rear strut stripes appear white and pink instead of Touring Prius pink and red. But I can still see from your pics that the stripes are indeed the Touring Prius pink and red.
    For comparison purposes, here's a photo of my United States Standard Prius rear strut. I took it without a flash, so you can more clearly see the colors of the strut stripes. The stripes are the Standard Prius [light] blue and red:
    [IMGLINK]http://priuschat.com/forums/attachments/gen-ii-prius-main-forum/9570d1212274702-consumer-reports-drives-touring-edition-084.jpg[/IMGLINK]
      File size:
      149.6 KB
      1,237
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    So basically, the major difference between the Touring score and base score is the OEM tires. No huge surprise. I wish CR would slap a decent set of tires on a base and come up with a score. Then it would be nice if Toyota would provide some decent tires as standard OEM. Imagine, an overall score of 68 vs 80 primarily because of the cheap tires!
    A couple of years ago, my wife's cousin wasn't too happy with his new Prius. I asked why, he mentioned the TC. Slipping, especially getting into traffic quickly from a parking lot (he lives where it is more congested than here). I told him to put some real tires on it. He did and has been a very happy pup ever since.
    This would be an incorrect statement. Both the AX and BG had VSC, which is why they were the only 2 packages I listed as acceptable with the dealers I contacted.
    Of course this wouldn't be the first time CR had misinformation. They continually reported in the April car issue that the original Honda Odyssey (1995 to 1999??) mid row captain's chairs were not removable. Either they were wrong or I am super-human because I took mine out all the time. The fact that there were latches on the back of the seats and the owner's manual showed how to remove them plus the fact that they were listed as 40 pounds each (a big plus compared to pulling the 3rd row seats out of other minivans) suggests I am just a normal human being :)
  6. Boo
    5,051
    488
    97
    Flushing, NY
    I think the wider Touring tires is the major reason for the Touring's better braking.
    But as to the Touring's better handling, I think it's a combination of the Touring's tires and suspension.
    That misinformation was my fault, not CR's. Thanks for the catch. I've since corrected my post by deleting the incorrect parenthetical.
  7. GatorJZ
    GatorJZ Member
    285
    17
    I doubt it that is correct. If Toyota could have obtained 95% of the Touring's improved handling and braking performance by merely swapping tires, they would have done so. I suspect there is a bit of touring-envy from the base owners in this thread.
  8. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Actually, suspension almost always effects braking distance substantially more than tires. In the Prius's case, the touring models front suspension does not compress as far or as quickly as the base models due to it's stiffness. A vehicle braking cannot actually begin stopping until the front suspension finishes compressing. It would only take a few milliseconds difference in compression speed to make a 10 foot difference in stopping distance.
  9. Boo
    5,051
    488
    97
    Flushing, NY
    Interesting. But in the Prius' case, the Standard Prius and the Touring Prius have the same front struts and springs. The Touring has a different front stabilizer bar though. Under your thinking, could the Touring's different front stabilizer bar account for that 10 - 12 feet shorter braking distances?
  10. rigormortis
    1,340
    26
    san jose, ca
    i wonder if us prius owners are going to have troubles getting the shocks replaced
    when they wear out. i mean if you go to sears you will ruin the whole tuned suspension thing
  11. Boo
    5,051
    488
    97
    Flushing, NY
    You Touring owners might. Right now, I think that no one but Toyota makes the Touring's rear shocks. But KYB makes the Standard's front struts and rear shocks.
  12. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Neato, I wondered exactly what the differences were. Now that I read this, I understand. I was wondering about the possibility of upgrading a base prius, but I am not sure it would be worth it. People way underestimate the power of suspension. That includes the springs, but of course making the entire car stiffer. By stiffening it up, the brakes are well applied and distributed throughout the car. The weight doesn't lurch forward, and of course, a little bit more surface adhesion helps too. Very neat. If the VOLT isn't everything it is cracked up to be, then I will get a touring Prius. :)
  13. Stefx
    Stefx Member
    336
    FYI my 2008 Prius (Special Edition Premium) has Bridgestone Turenza all-season tires on 16" rims.
  14. rigormortis
    1,340
    26
    san jose, ca
    mine doesn't anymore because they were shaved down to practically nothing in less then 2 years, ive never seen tires wear down that fast
  15. Boo
    5,051
    488
    97
    Flushing, NY
    Full Road Test Report of Touring + Comparison Chart of Base v Touring
    If anyone is interested, attached is a Word file with Consumer Reports - online edition's full road test report of the Touring, together with its handy comparison chart of the ratings and specifications of the Base (Standard) Prius vs. the Touring Prius.
    On the comparison chart, I've highlighted the differences in bold red:
  16. gilmore753
    gilmore753 New Member
    22
    Illinois
    "You Touring owners might. Right now, I think that no one but Toyota makes the Touring's rear shocks. But KYB makes the Standard's front struts and rear shocks."
    Do you guys know if anyone besides Toyota will make the shocks for the Touring? If not, do you think the Touring is still worth getting if that is the case?
  17. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Keep in mind that this is a comparison to the base model without stability control, not to the #2 package and up (standard.) This probably doesn't effect much more than the avoidance maneuver though.
    Seems that to isolate the differences between Touring and non- suspension one would need to have the same package (stability control) and the same model of tire. I would recommend leaving the wheel size's different however--since the tires are a wear item.
    I'll bet most of the difference is coming from the different tires. The Integrities are low rolling resistance which is favorable for mileage, & acceleration times, unfavorable for braking. It would also effect slalom which favors the Turanza.
    The larger wheels and suspension differences will still have an impact, but I suspect the tire is accounts for at least half the difference.
  18. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    It also mentioned that the standard model the comparison is made to is the 2004.
    I think that the newer standard models are a little better. I don't actually believe the stopping distance thing, as my Prius has incredible brakes that would fling me through the windshield (if I weren't wearing my seatbelt) if I need to stomp them (I did it once).
  19. turboboy
    turboboy New Member
    29
    upstate ny
    i noticed a large difference in in the rpm at 60mph, not sure if this is a typo, or a change in transmission gearing between touring and regular or a change in the gearing between 04 and 08. too large to be explained by tire diameter difference. anybody?
  20. kazots
    kazots LifesaBeach
    262
    CALIFORNIA
    Thanks for the info, it is nice to know I paid extra for something. I like the way my touring handles, but it still could take corners better.
