Consumer Reports initial test of Model S in winter chills
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cycledrum, Feb 15, 2013.
  1. david_cary
    david_cary Junior Member
    47
    17
    spinnaker - why are you so bitter??
  2. John H
    John H Senior Member
    2,208
    558
    he was shocked as a child :)
  3. spinnaker87
    spinnaker87 Junior Member
    95
    los angeles
    haha...
    now where's those degradation numbers and affect on range?
    that's what I thought.
  4. John H
    2,208
    558
    I guess you don't know how to follow a link or how to use google.
  5. spinnaker87
    95
    los angeles
    I have and guess what.. Tesla hasn't disclosed those performance numbers and affect on range. I bet your bottom dollar they have those numbers in internal documents.
    1. battery degradation and range loss by year.
    2. range loss by temp and hour when unplugged.
    but they want everyone to smoke the hopium that this battery on wheels is a road trip car. it ain't.
  6. John H
    2,208
    558
    Seems to be working well for road trips, despite your protest.
  7. spinnaker87
    95
    los angeles
    what happen to those google searches.. that's what I thought.
  8. John H
    2,208
    558
    I can't google for you, it would be useless to provide you any information since you don't seem to have any processing capability anyway. I provided links for you earlier and you don't seem to be interested in doing anything except being a troll.
  9. spinnaker87
    95
    los angeles
    post the numbers... why are you so bitter?
  10. John H
    2,208
    558
    trolls have that effect on me. I will be "ignoring" you now.
  11. spinnaker87
    95
    los angeles
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Inquiring minds want to know....
    "People considering a plug-in vehicle have a legitimate concern about how long EV batteries will last before they need to be replaced. The answer depends on how you use (or abuse) your vehicle’s batteries. With proper management—and following the tips in this article—the batteries in a modern EV could last decades, allowing plenty of time for the technology to go mainstream and for economies of scale to bring down the price."
    "EV drivers are often asked, “How far can you go on a charge?” But if you can help it, avoid trying to personally find out for yourself by driving all the way down to an empty battery to test your electric car’s full range."
    Tip 6: If your EV has thermal management and the weather is extreme, plug in whenever you can.
    This will, of course, charge your batteries, but more importantly, it will engage the thermal management system continuously without draining the batteries. Remember that lithium batteries like the same temperature ranges that you and I do. If you had to sit in the sun in a hot parking lot, would you want the AC turned on? Yes, you would and so would your vehicle’s batteries"
    The Tesla Roadster has a “storage mode.” This makes it easy: plug in the car, set it to storage mode and the vehicle’s firmware takes care of the batteries.
    "To maximize battery life, minimize use of DC quick charge.
    I have saved the best for last. DC quick chargers can dump about 80 miles of range into the Nissan LEAF’s battery pack in 30 minutes. Fast charging is very useful if you need to drive more than the vehicle’s single-charge range in a single day. However, the batteries pay a price for this convenience.
    Regular use of fast charging will cost you about 1 percent of capacity per year. For example, if you avoid fast charging, you may have 80 percent capacity after 10 years of normal use. However, if fast charging is your primary fueling method, then your capacity would be 70 percent after 10 years. While the cost to the battery’s lifespan may not be as much as you may think, fast charging still takes a toll that should be avoided when possible."
    "With modern plug-in vehicles, you can simply plug them in anytime and drive it any way that you see fit and you should still have batteries that perform well in 10 years."
    Eight Tips to Extend Battery Life of Your Electric Car | PluginCars.com
    "...As the EERE predicts, this means cars like the Nissan Leaf based in Phoenix will reach 75 percent of original capacity some five to ten years sooner than cars in cities like Minneapolis, where summer averages hover in the low 70s.
    The solution, as many analysts and industry insiders have said in the past, is to use active liquid cooling (like Model S) to keep battery packs operating within tightly-controlled temperature zones.
    Take Ford, for example. With liquid cooling of its Focus Electric battery pack, the automaker should enjoy a very long lifespan for its battery packs.
    Compared with a similar battery pack without liquid cooling in hot climates like Arizona, a liquid-cooled battery pack will retain 10 percent more of its original capacity after 10 years than a non-cooled pack. "
    How Long Will Your Electric Car Battery Last? It Depends Where You Live
    Because of all these variables, "if the manufacturer says 100 miles of range, it could be 60 miles or it could be 130 miles," Edmunds says. And if the manufacturer says 100 miles, you're going to want to allow a buffer, he adds.
    Further, Edmunds notes, "You can't tempt fate with the low fuel light like you can in a gasoline car, because the only place to fill up may be your own garage. So if you're wrong, you're walking." And that's why there's so much talk about range anxiety.
    Electric Car Battery Basics: Capacity, Charging and Range
    Electric vehicle battery - Wikipedia, the free encyclopedia
    "Battery service life should be considered when calculating the extended cost of ownership, as all batteries eventually wear out and must be replaced. The rate at which they expire depends on a number of factors."
    "In real world use, some fleet Toyota RAV4 EVs, using NiMH batteries, have exceeded 100,000 miles (160,000 km) with little degradation in their daily range.[53] Quoting that report's concluding assessment:
    "The five-vehicle test is demonstrating the long-term durability of Nickel Metal Hydride batteries and electric drive trains. Only slight performance degradation has been observed to-date on four out of five vehicles.... EVTC test data provide strong evidence that all five vehicles will exceed the 100,000-mile (160,000 km) mark. SCE’s positive experience points to the very strong likelihood of a 130,000 to 150,000-mile (240,000 km) Nickel Metal Hydride battery and drive-train operational life. EVs can therefore match or exceed the lifecycle miles of comparable internal combustion engine vehicles."
    "Lithium ion batteries are perishable to some degree; they lose some of their maximum storage capacity per year even if they are not used"
    Jay Leno's 1909 Baker Electric (see Baker Motor Vehicle) still operates on its original Edison cells. Battery replacement costs of BEVs may be partially or fully offset by the lack of regular maintenance such as oil and filter changes required for ICEVs, and by the greater reliability of BEVs due to their fewer moving parts. They also do away with many other parts that normally require servicing and maintenance in a regular car, such as on the gearbox, cooling system, and engine tuning. And by the time batteries do finally need definitive replacement, they can be replaced with later generation ones which may offer better performance characteristics, in the same way as you might replace old batteries from a digital camera with improved ones.
    "The predicted market for automobile traction batteries is over $37 billion in 2020.[2]
    On an energy basis, the price of electricity to run an EV is a small fraction of the cost of liquid fuel needed to produce an equivalent amount of energy (energy efficiency). The cost of replacing the batteries dominates the operating costs"
    "Most other EVs are utilizing new variations on lithium-ion chemistry that sacrifice energy and power density to provide fire resistance, environmental friendliness, very rapid charges (as low as a few minutes), and very long lifespans. These variants (phosphates, titanates, spinels, etc.) have been shown to have a much longer lifetime, with A123 expecting theirlithium iron phosphate batteries to last for at least 10+ years and 7000+ charge cycles,[7] and LG Chem expecting theirlithium-manganesespinel batteries to last up to 40 years."
    "Battery professor Poul Norby states that lithium batteries will need to double their energy density and bring down the price from $500 (2010) to $100 per kWh capacity in order to make an impact on petrol cars.[
    "According to U.S. Energy Secretary Chu, costs for a 40 mile range battery will drop from a price in 2008 of $12K to $3,600 in 2015 and further to $1,500 by 2020.[62][63]Li-ion,Li-poly,Aluminium-air batteriesandzinc-air batterieshave demonstrated energy densities high enough to deliver range and recharge times comparable to conventional vehicles.
    Battery-operated vehicles (like the Nissan Leaf) are projected to have annual sales in 2020 of 100,000 units in the U.S. and 1.3 million worldwide — 1.8 percent of the 71 million cars expected to be sold in 2020. Another 3.9 million plug-ins and hybrids will be sold worldwide, bringing the total electric and hybrid market to about 7 percent of all cars sold in 2020.[64]"
    "Vice President Biden announced in Detroit over $1 billion in grants to companies and universities based in Michigan. Reflecting the state's leadership in clean energy manufacturing, Michigan companies and institutions are receiving the largest share of grant funding of any state. Two companies, A123 and Johnson Controls, will receive a total of approximately $550 million to establish a manufacturing base in the state for advanced batteries, and two others,Compact Power and Dow Kokam,[69] will receive a total of over $300 million for manufacturing battery cells and materials. Large automakers based in Michigan, including GM, Chrysler, and Ford, will receive a total of more than $400 million to manufacture batteries and electric drive components. And three educational institutions in Michigan — the University of Michigan, Wayne State University in Detroit, and Michigan Technological University in Houghton, in the Upper Peninsula — will receive a total of more than $10 million for education and workforce training programs to train researchers, technicians, and service providers, and to conduct consumer research to accelerate the transition towards advanced vehicles and batteries"
    That's a little bit for starters. Lot more out there.
    John Hatchett likes this.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    There is no way to show definitive numbers for battery degradation. There are many variables that can affect that.
    Range loss when unplugged seems silly. Tesla has a thermal management system, so I think it is much wiser to keep the car plugged in to help power the system instead of using battery charge to do so. Hopefully a Model S owner can tell us what the OM says
    see this about extending battery life -
    btw, I think you (spinnaker87) ought to start contributing more information instead of demanding it from others.
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    You can't just go around making stuff up. Where have they marketed the Model S as a "road trip car"? Show me one ad. It is highway capable. And when the supercharger system is complete (with stations ~140 miles apart as planned), traveling across country will be practical. But nowhere have they said it would be ideal for everyone and certainly not for someone who needs to do so frequently. Guess what, neither is it the ideal car for someone who needs to haul firewood..should they have a disclaimer and stop talking about the 32 cu ft of cargo room too? It's also not ideal for hauling a football team, should they stop talking about cargo room.
    Apparently you don't give people much credit for having basic intelligence. The information about cold weather performance is available...not in the ridiculous and impractical detail you somehow feel entitled to demand, but none the less there are many years of EV experience out there and anyone bright enough to seek out the Tesla Motors forum or the Tesla motors club forums will find many threads on the subject of cold weather behavior.
    Likewise, the batter degradation information is available and has been published by Tesla, they've long stated that you can expect approximately 70% of the original capacity after 10 years. But, as with gas cars, YMMV.
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I think the below sums up spinnaker87 best:
    I think he's going to end up on my ignore list real soon as it seems he's unwilling to listen to or use logic.
    ftl, austingreen and John Hatchett like this.
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I think one of the more interesting questions for Model S would be projected resale value in 5 or 10 years. Maybe the industry doesn't project that, but over time, KBB and others will put out numbers.
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I think instead of focusing on 'how much will the battery degrade', better to look at 'how to maximize lifespan of the battery'.
    Rav4EV drivers have told me they've been using original packs for a loooooong time, because there are no new packs for it.
  19. efusco
    19,891
    1,196
    Nixa, MO
    Here's something else for you spin, the cold weather energy loss will change with time and with software updates. The current version of software doesn't allow the car to go into a deep sleep when shut off, the previous version did, but b/c of a few unexpected and annoying software glitches they removed that feature with statement that once they've optimized the software that the feature will return. With that parasitic losses will decrease. I wouldn't be a bit surprised if cold weather battery management also improves in future software updates as well.
    As has been repeatedly pointed out and you refuse to hear is that there are FAR too many variables to provide the specific data you want. Buyers understand that cold weather negatively impacts performance...you adjust for it. They also understand, though no NYT "journalist" has yet shown it, that very hot weather also has a negative impact. Buyers also understand that 300 ideal miles means "ideal". And Rated means EPA, and projected means what they can expect under the status quo driving conditions. These are not advanced or difficult concepts and you learn them in the first 24-48 hours with the car even if you did no research on the subject matter before getting the car.
    I think that we'll see someone post some degradation numbers. In fact the roadster forum has some information, but the ideal range loss seen is pretty small on most of those cars, so it's hard to extrapolate. Roadsters are seeing around 10% at 50k miles: What does the battery degradation curve look like?
    It's shocking to me that someone who has not purchased one of these cars seems so self-rightously demanding of the data...and yet those of us who own one are comfortable with the data that's available.
    austingreen likes this.
  20. spinnaker87
    95
    los angeles
    where's the data? that's what I thought.
