Consumer Reports Pegs Prime EV Range at 28 Miles
Discussion in 'Prime Fuel Economy & EV Range' started by iplug, Aug 4, 2016.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Toyota,
    put 4 seats in a Prime instead of 5.
    When they test for fuel economy, they don't load the car to the max. They do it with just the driver only, maybe with someone riding shotgun. The whole 4 passenger vs 5 passenger in the name of EPA rated MPG is irrelevant. No one expects to get EPA rated MPG with 5 passengers. If they did and came here to complaint about it, All of us will jump at the guy and say "What do you expect? You got 5 passengers" Drop 4 of them off and your mileage will go up.
    Maybe I didn't make myself clear. I meant to say that pretty much all the sports cars that does have backseats are only able to sit 2 people in the back. I'm talking real sports cars like the 911, 924, 944, 928, 300ZX, RX7, Supra, none of that FWD crap like the Integra GSR or Civic Si or some Family crap that can go fast like TMS P90D or Hellcats.
    I'm fully aware of that. Given that the Ioniq PHEV and the Volt 2 are about the same interior size, the winner is clearly the Ioniq because it has 5 real usable seats, not 4 seats with 5 seat belts.
    Tideland Prius likes this.
  2. inferno
    inferno Senior Member
    1,072
    405
  3. Trollbait
    12,831
    As pointed out, those high end cars are marketed to people that can have a hireling drive them around.
    Toyota designed the Prime for the Japanese market with features that we simply aren't getting. The solar option has a NiMH battery that if it isn't as large as the one in the hybrid, it is close. That sits under the rear seat with the charger. Which excludes having a portion of the traction pack being placed there. We aren't getting the solar option because of its cost, but we still have to pay the design cost for it.
    Torsion beam does not make for poor handling alone, and what it lacks can be compensated for in other areas.
    52,863
    personally, i think toyota miscalculated the entire gen 4 market. all the magic they packed into gen 4 isn't impressing enough people. i believe their focus groups mislead them. now we're stuck with a prime that has to work with all the new magic.
  5. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Well it's a small car (in the public's eyes) anyways which aren't in big favor right now. The biggest deals right now from Toyota are on their cars, not their trucks or SUVs. Even FCA cancelled the last of their domestic cars to focus on vehicles that can seat five, six and seven people comfortably.
    Back to the OP, I'm thinking they got their 28 miles EV without climate control. I personally think the gas injected heat pump will be the biggest surprise. It may also account for loss of room as well in the Prime.
    Unsupervised!
  6. bisco
    52,863
    what is a gas injected heat pump?
  7. Trollbait
    12,831
    The gen4 is doing great in Japan.
  8. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    It's AKA a vapor injected heat pump that utilizes a two stage compression technique to help the compressor and gives about a 20% increase in efficiency. It's a little more expensive to implement but will cost less in the long run (maximizes range).
    Unsupervised!
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    No, you aren't on ignore. In fact, I value your feedback. However, I won't engage in any vague discussions anymore. If you want to talk about something related to quantities, please include the actual numbers.
    That being said, it makes quite a bit of sense for Toyota to first rollout options in their own market, observe how they are accepted and used, then adapt them for our market afterward.
    The dynamic approach is better than having to wait for all to be settled first, like in the past... which is the paradigm most people are use to.
  10. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    And gas in Japan is what, twice as expensive or three times? I can't keep them and Europe straight. The Gen4 should be doing great.
  11. bisco
    52,863
    is this going to be on the prime? where did you get the info, i missed it.
  12. Tideland Prius
    16,683
    No but the IIHS and NHTSA test for vehicle safety. I believe it's the requirement of a 5 passenger vehicle of that weight class to have certain crash-safety items designed into the vehicle to ensure the safety of all occupants. As a result of that, Toyota believes they can't hit 52mpg combined.
    Ohh.. In that case, you know the extra seats are for insurance purposes.
    Yes there's the chassis, the weight distribution, the suspension settings themselves etc etc.
    But you know it was chosen for it's low cost and compact size (your advantages there).
    But that doesn't change the fact that I get rear suspension hop (both Gen 2 and Gen 3) on a particular offramp. (they didn't smooth out the joints and because it's a curve, I rarely hit it straight on with both rear wheels at the same time).
  13. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    In the original presse release under Looks Marvelous, Feels Marvelous
    Jan
  14. bisco
    52,863
    thanks! i see 'heat pump'. can anyone elaborate on the gas injection?
    also, what is the 'electric compressor' they speak of?
  15. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    bisco and Trollbait like this.
  16. Trollbait
    12,831
    Never experienced that with any of the torsion beam rears I've had. Did enough times with an empty bedded Ranger to learn how to avoid it. Axle hop with RWD can really jack up the excitement level of the commute.
    The compressor for the heat pump. They are just clarifying that the climate system is still electric, and doesn't need the ICE running to cool or heat. A heat pump is basically an air conditioner that can also work in 'reverse'; moving heat from outside to inside.
  17. bisco
    52,863
    interesting. they're making an educated guess of course, but it will fun to see how close they come to the real thing when toyota reveals it.
    when you said gas, i was thinking gasoline.:p
  18. bisco
    52,863
    but, 'the climate control system is quieter, thanks to an electric compressor' makes it sound like gen 3 and 4 don't have an electric compressor.
  19. john1701a
    12,840
    5,312
    58
    VAPOR injected is the best way to refer to it.
  20. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    I believe the electric compressor has been around since Gen2. It makes the compressor operate with less stress and therefore less noise.
    Unsupervised!
