Consumer Reports "The mpg gap"
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jul 13, 2013.
  1. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Fuelly does give a recap on how well one can do with better mpg's, and for the Prius it does not make sense to chase - see attached - this was after a 567 mile tank.
    Not sure how to address why here in the US we don't use a gallon/100 mile model - other than to get us forget just how much our driving here in the US is costing us. My lifetime Fuelly is showing that I am getting 1.9g/100 miles. With my 100 mile weekly commute,I know easily that it costs me between $7 and $8 a week to just get to work based on $3.50 to $4 a gallon. The only simpler way is for mpg ratings to show actual $/100 miles or km...
    My fiancé loves it when we take and drive one or the other in to work our jobs are just 10 miles away from home. His car is a Yaris - so based on Fuelly the cost is between $9.50 to $11 based on 100 miles. While $2.50 to $3 per 100 miles does not sound great based on our miles driven per a year - we are learning that it adds up.... We are trying to see how we can make things work between our jobs in order to commute together.
    In the end I believe that making car owners aware of costs per 100 km or mile will have a positive effect....
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I still subscribe to CR but I too sense an issue on auto reporting. For me, I originally wrote CR and EPA a letter/email (neither responded) re: MPGe as a misleading metric. CR kept saying 100 MPGe means Plug_ins sip very little fuel/energy, I was trying to say no, they use lot's of energy, 100 MPGe just means sipping less gasoline. The thing is, it's Consumer Reports...I am (mistakenly?) expecting impartial assessment getting to the honest truth of the matter, and not USA-centric politically correct attitude.
    usbseawolf2000 likes this.
  3. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    With all the stops to document every detail and border crossing I'm sure their average speed took a big hit. 25-35mph is probably well below the minimum speeds on those roads. Their road speed would probably be nowhere near that low.
  4. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Historical reasons are normally the best guess for why we measure a certain way, and it is true here. When the car came out what was important? That you had enough gas to get to your destination. If you got 13-20 mpg in your model t, and wanted to go 150 miles you might have to carry extra gas if there wasn't a station.;) Prohibition stopped you from just stopping and picking up some ethanol to pour in the tank. In Europe they picked a different convention. Neither is better than the other, unless you can't do division. Remember YMWV (your millage will vary). Most people that care have an idea of how much gas costs them a month.
    We have a computer in our car and can switch from miles to km and mpg to whatever the europeans use. Perhaps if it is important you can write to toyota to get it on the trip computer. If you want to compute g/100 miles from the window sticker, just plug 100/mpg into a calculator. No one is forcing anyone to use miles or km or any other convention.
    The issue here is whether the CR test is misleading. I am with bob that it is when comparing hybrids to ice cars.
  5. bwilson4web
    16,537
    For a Plug-in Prius (PiP) and hatchback, both vehicles use the same amount of energy to get from point A to B. But some of the PiP miles come from a power plant, the only differences:
    • cold-soak startup - there are distinct warm-up phases the car goes through each time it starts:
      • catalytic converter light-off to ~650C, takes about 45-50 seconds - traction battery help
      • engine coolant warm-up to 60C, takes about 5-6 minutes - PiP has some help
      • transmission warm-up to 40C, takes about 20 minutes - PiP power assists also warms the transmission rapidly
    • thermodynamic efficiency - capable of 38%, it falls off outside of the peak operating areas
    • transmission losses - both the PiP and equivalent hatchback have gear and stirring losses but the grid also loses energy
    • well-to-wheel - oil-to-engine or coal/gas/nuclear-to-generator have energy losses
    My understanding is the PiP uses some of the traction battery charge to offload the engine more so than the hatchback. This minimizes the fuel burned during the engine coolant warm-up thus mitigating the cold-soak, warm-up costs.
  6. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The CR test loop is through a two lane country winding road with rolling hills to simulate city driving.
    The winding road portion requires braking and acceleration, all this hurts mpg. They do not drive in actual city traffic because the condition cannot be repeated for different tests. Their test loop is actual quite repeatable as mentioned before they require driving in predetermined speed and to sit in the car for fix amount of idle time.
    It is a fair test for car to car comparison.
  7. markabele
    5,084
    1,782
    Nebraska
    Depends how you define fair. Clearly the numbers they got here show that their test is much better for more powerful vehicles.
  8. bwilson4web
    16,537
    Would you have the longitude and latitude or a Google Map URL to this loop?
  9. bedrock8x
    1,483
    137
    I only saw it in Youtube. May be you can figure out where it is located.
    This is one of them.
  10. austingreen
    13,714
    4,232
    Austin, TX, USA
    Consumer Reports Auto Test Track (Bing Maps) - Virtual Globetrotting
    I am not sure how the map will help you though. The question is really are the tests valid. Does consumer reports test more accurately what a typical driver will see. For the city portion, with hybrids it is likely that the EPA test underestimates the cold start penalty of the city portion. For the hwy portion the low speeds on the EPA test help less aerodynamic cars. For a car like the prius it likely is a wash, overestimating city, under estimating highway. The tests can be improved.
    We don't really have much of an idea what is going on in the consumer reports city test, as they have not specified speed, distance, number of stops per mile, etc. It seems to drastically underestimate city mileage. Similarly their highway test is long at a constant speed, that is quite different from user experiences except on long trips going much slower than we do in my state. It likely over estimates mileage. Since the CR seem to penalize hybrids through their methodology I find it hard to believe we should choose their numbers over the EPA. Perhaps you can add the hwy portion to the epa information. The city test? I don't think hybrid drivers drive that way.
  11. Trollbait
    12,831
    Only as long as you believe differences in air temperatures, prevailing winds, and the difference between summer and winter blend gasoline with varying amounts of ethanol have no bearing on vehicle fuel economy.
  12. bwilson4web
    16,537
    With Google Map, I can see the elevation changes in their test facility. I had long suspected there were significant elevation changes. To get that bad of mileage, they had to be going in the vertical.
    ps. 41.5159950 -72.3597160
    austingreen likes this.
  13. bedrock8x
    1,483
    137
    They have been testing car for many years or hundreds of car, they should have enough data to make corrections to these variables.
  14. austingreen
    13,714
    4,232
    Austin, TX, USA
    Any guess at validity if a chevy malibu eco gets its EPA milage on the CR tests, but a prius C gets 14% worse mileage on the CR test?
    Make & model CR overall mpg EPA combined mpg Difference
    Ford C-Max SE 37 47 10
    Ford Fusion Hybrid SE 39 47 8
    Toyota Prius C Two 43 50 7
    Toyota Prius 44 50 6
    Honda Civic Hybrid 40 44 4
    Infiniti M35h 25 29 4
    Lexus ES 300h 36 40 4
    Buick LaCrosse (4-cyl., eAssist) 26 29 3
    Honda Insight EX 38 41 3
    Hyundai Sonata Hybrid 33 36 3
    Lexus RX 450h 26 29 3
    Lexus CT 200h 40 42 2
    Toyota Camry Hybrid XLE 38 40 2
    Chevrolet Tahoe Hybrid 19 20 1
    Toyota Highlander Hybrid 27 28 1
    Toyota Prius V Three 41 42 1
    Chevrolet Malibu Eco 29 29 0
    Honda CR-Z EX (manual) 35 34 -1
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    What I meant, was Bob drove to prove the Prius can do this loop at 99.9mpg. Cherry picking results, similar to what CR does. It is great though because more of these sorts of datum points might break the prevailing myth amongst people that a N mpg car gets N miles per gallon no matter what conditions, speed, driver, or anything else.
    I suggest that Bob drives the Prius around the same loop with 0 regard for fuel economy. Pretend you are Jeremy and on a mission to prove to the world that the Prius is the worst machine in the world. What sort of tricks would you pull? Drive with the e-brake slightly on, AC on max while the defrosters are on start with a 2-bar SOC, brake hard and often, accelerate pedal to the metal at every opportunity, lower the tire pressure to 30psi, that sort of thing.
    Then we can show the loop when driven by a Bob-ite gets 99.9mpg. The same loop driven by a Clarkson-ite gets ### mpg. My guess is that it will be closer to 30-35 mpg.
  16. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Seriously? Just because the test is the same for all cars does not mean it is a fair test. What kind of technology is in use does matter. What if I defined a test as driving a few miles, then sitting and idling for 15 minutes, then driving another 2 miles and idling for 15 minutes, etc. Virtually all ICE cars would show horrible results and all hybrids would do great. I wouldn't call this a fair test because it doesn't mimic what average drivers actually do.
    As it is, their test (it seems) always tends to accelerate hard and brake hard and not coast to stops, for example.
    Mike
    Trollbait, SageBrush and austingreen like this.
  17. 3PriusMike
    3,101
    2,421
    Silicon Valley
    They do tell you that they use a dynamometer.
    And they do account for air drag by mathematically adjusting the results.
    This is actually MORE accurate in that they have no cross winds, no tail winds, no head winds which happen in real driving without any tester control...every car only gets the penalty of speed induced head winds based on the Cd for the car under test.
    I suppose one could argue that different cars have different reactions to random cross winds and that should be taken into account since real world driving has these effects.
    Mike
    Trollbait likes this.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Nah.
    The dyno and roll down method to calculate rolling resistance is fine; the problem is protocol.
    • Should the test tease out regen ?
    • Should the test tease out coasting ?
    • How about partial power penalty differences between cars ?
    • Should the highway test be performed at 65 mph ? 75 mph ? 85 mph ? The G2 Prius transmission becomes increasingly inefficient at speeds over 75ish mph. Should the test expose that weakness ?
    I routinely hit around 70 mpg in my Prius vagon in city driving. Part of it is not driving in a congested city with aggressive drivers; the other part is knowing the strengths and weaknesses of my car and driving accordingly.
    Should the test assume least common denominator -- that every driver is an idiot who has either the brake or the fuel pedal mashed to the floor ? CR seems to think so.
    I would like to see
    City(moron):
    City(smart driver):
    Or even better, let the drivers drive a simulated course with pseudo- random traffic, any way they want so long as they finish the course within a prescribed time, drive legally and avoid certain proscribed behaviors. Report 3 time trials. We will give up exact reproducibility, but have an informative test instead that says a lot about the car AND the driver.
  19. bwilson4web
    16,537
    There is a feed-back mechanism in our Prius missing from ordinary cars the most automotive writers choose not to understand. Prius mileage has a direct and proportional relationship to the speed and handling. In contrast, ordinary cars have engine inefficiencies at partial power and wear out their brake pads.
    Consumer Reports is on some Jihad against the EPA mileage numbers, something that has some basis in fact. Instead, Consumer Reports have revealed how technologically backward and out of touch they are. They are trying to defend their own, undefined protocol. Worse, they have failed to present any 'basis of estimate' other than "We are Consumer Reports and we declare our MPG testing don't stink."
  20. austingreen
    13,714
    4,232
    Austin, TX, USA
    I wouldn't say Jihad. I would say fake news war against hybrids otherwise how do you explain this
    Fuel Economy - Consumer Reports
    That leads to anti-hybrid editorials like this
    How many miles per gallon does your Prius really get? - The Denver Post\
    Unfortunately for us, consumer reports isn't really mimicking real world conditions. The EPA tests can be helped, but this analysis by car and driver would have even more problems with consumer reports then the EPA
    Why Is the EPA So Bad at Estimating Hybrid Fuel Economy? – Feature – Car and Driver
    They advocate forcing hybrids to test all 5 cycles, hot and cold, and raising the speed of the highway test. Consumer reports testing does not really address the problems with epa testing at all, they simply add their owned biased tests. How many of us drive on the highway every day at 65mph. Many of us have traffic and slow down and speed up, or go much faster on trips. We deal with hot and cold weather. I don't know anyone whose city mileage in a prius is as bad as Consumer reports got on their test. Misrepresenting any set of flawed tests as accurate seems to be getting consumer reports lots of press. Unfortunately it is really a poor anti-hybrid agenda.
    A little detail of their city test
    Every turbo owner knows stomping on the gas will lead to worse mpg. If they are driving for economy they will accelerate like hybrid drivers slowly. 5%of the time they will stomp on the gas for fun, and that won't ruin gallons per year.
    Trollbait and bwilson4web like this.
