Continuous beep from sound system speakers. No error codes. Does it when warm weather
Discussion in 'Gen 3 Prius Main Forum' started by Tom Stacy, Dec 28, 2023.
  1. Tom Stacy
    Tom Stacy Junior Member
    Orlando
    2014 Prius. I get continuous hi pitched tone from sound system speakers, after driving about 5 miles. Usually on hot days. Happens sometimes on cool days. Doesn't always happen. Will shut off when driving sometimes for over a half hour. Resting in shade makes it go away. Sound comes through the speakers even when the audio is turned off. No error codes. Mechanic is stumped. Any experience this too? Help please
  2. GG707
    GG707 Member
    62
    26
    athens
    Excel
    Then maybe some door don't close completely? While drive and/or reverse if you open the door the buzzer starts making the sound you refer... So maybe it is one of the 4 doors or the rear hatch slightly open (anyway not locked in position) and while driving with the slightest movement it activates the buzzer...
  3. ASRDogman
    ASRDogman Senior Member
    8,061
    4,086
    Did you resolve this issue?
  4. Tom Stacy
    Orlando
    I resolved the issue. I swapped out the radio with a used on I bought on eBay for $150. Problem solved. Easy job.
