Continuous Glucose Monitor
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Sep 21, 2024.
  1. bwilson4web
    16,525
    First week results:
    • Real-time feedback - both quality and quantity of foods impacting glucose readings.
    • No extra meds - effective behavioral changes
      • compliments dietary training on good and bad foods
    • Affordable - $99/first month, $90/month subscription
      • over-counter - no prescription or insurance needed (Stelo.com)
      • add tax, no shipping cost, 3 days to deliver
    Lessons learned in first week:
    • corn - just don't, even in mixed vegetables or soup
      • fried catfish - peel off the coating and eat the filet
      • small, sweet corn muffin OK
    • plums - as bad as corn
      • will survey favorite fruits and some low-carb vegetables
    • cranberry yogurt - wash the jelly off and use just the berries
      • plain yogurt no lactose effect
    • bran cereal with 2% milk - half a cup is OK
    • sausage patty and fried, medium egg - breakfast of champions (using olive oil)
    • rolled cold cut meat and cheese - works great for meal or snack
      • thin ham, smoked gouda, and/or real Swiss
    • seafood casserole
      • layered: squash; fish filet; lump crab meat; scallops, shrimp
      • beaucoup Old Bay
      • beaucoup margarine or butter
      • bake until top is 'browned' and margarine bubbling
      • stores in fridge great for a quick, microwave heated meal
    For me, this is brilliant. I get fast feedback on what to eat and quantifies. Knowledge is changing my eating habits and helps me change to foods I like in portions that make sense.
    #1 bwilson4web, Sep 21, 2024
    52,819
    is that an arm patch?
  3. fuzzy1
    10,694
    If only we could get a feline to eat the right foods, and on schedule. A bit tough in a multi-feline household with different eating cycles. When initially diagnosed, the diabetic one could not jump up the cat tree, so the forbidden meals was placed up there. But as treatment improved his health, he was able to get up there and help himself.
    A glucose monitor did allow us to better tune his insulin dose. This image is from the second round of monitoring, and is a much better result than the first round. The better dose has allowed him to gain weight, and reduced his excessive water intake and litterbox use. We'll try a third round in a few weeks. For veterinary use, these monitors are not used full time, but just for occasional sampling.
    Images are different than in the OP because the FreeStyle Libre 3 mobile app is not compatible with our phones, thus a separate USB reader is required to retrieve the sensor data. The FreeStyle Libre 2 app would have been compatible, but that series was obsoleted, production ceased. A form of planned obsolescence with forced upgrades.
    I was pre-diabetic myself a couple decades ago. Frequent bicycle commuting after a job change, then retiring and getting out of the office and outside for more exercise, helped greatly in preventing it from crossing the threshold into actual diabetes.
    #3 fuzzy1, Sep 21, 2024
  4. bwilson4web
    16,525
    They show it going on the bottom of the arm but it has a very small, electrode. Compared to finger prick testers, insignificant. The applicator is spring loaded and handles the insert and initial adhesive seal. Then an additional adhesive 'gasket' make it water tight and solid. It is shower proof.
    Each sensor is rated for 14 days and the App keeps track. I'm half way through the first sensor and have a second ready to go. But these initial results are so good, I thought to share.
  5. fuzzy1
    10,694
    I have removed two sensors from the cat after their 14-day operating runs. The in-body sensing element is a flexible but somewhat stiff narrow strip, from memory I'd say about 1/4" long, but someone else can refine that guesstimate the next time they remove one.
    Basically a coin-cell-sized electronic device on the skin surface, with a small hole for a needle within the applicator to place the sensing element inside the skin. The 14-day operating life is enforced by the internal clock, so users can't be 'freeloaders' trying to save a bit money by squeezing more life out of it until the battery actually runs out. The manufacturers want to collect their annuity payments refill revenues.
    That said, this thing seems vastly more informative and revealing than the one-shot skin-prick glucose measuring strips.
  6. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    pre-diabetic, can't get one without a prescription, can't get a prescription unless I'm on insulin. Bass-Ackwards health system. If I could have one of these I could much easier control my eating habits, and PREVENT diabetes.
    fuzzy1 likes this.
  7. bisco
    52,819
    did you try bobs website? stelo.cm > /
  8. tochatihu
    tochatihu Senior Member
    9,967
    3,847
    Kunming Yunnan China
    2001 Prius
    Very interesting topic see also
    https://www.nature.com/articles/s41390-024-03573-x
    Bass ackwards it may be. Consider buying a non-prescription fingerstick device. Our Bob will delight in telling how longer after any meal the glucose concentration spike appears. Use that info to know when to 'take your sample'.
  9. bwilson4web
    16,525
    The shower dip is something new but not a problem as this first sensor is at its half-life. I had trouble putting the second 'gasket' patch on.
    Here is my first use:
    The original post lists the lessons learned. That huge spike on 9/16 was learning the home made, cranberry yogurt needs to have the "jelly" washed off. If using a finger prick device:
    • baseline before eating or drinking something
    • wait 30-45 minutes to get a local peak
      • some sugars are faster and others take time
    • wait another 1-2 hours to see return to 'normal'
      • not all carbohydrates are converted at the same time and rate
    tochatihu likes this.
  10. bisco
    52,819
    imagine something like this that could monitor everything in your body? i think we'll get there someday
    bwilson4web likes this.
  11. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    I wonder if by "can't get one" he means insurance won't cover it, not that he can't get one even if he was willing to go on the website and buy it. I used to occasionally buy the Freestyle Libre (competitor to Dexcom) without a prescription on diabetic warehouse for a little over $100, but that was for only 14 days. This Stelo by Dexcom is much more reasonable.
    Insurance won't likely cover it for prediabetes until their is a controlled trial showing it reduces the incidence of diabetes compared to general nutrition and exercise advice. I am a registered dietitian and Medicare won't even cover Medical Nutrition Therapy (basically nutrition consults) for prediabetes. They cover a group Diabetes Prevention Program, but the rules are so cumbersome and the reimbursement to providers is so low that very few hospital systems or doctor's offices offers it.
    bisco and bwilson4web like this.
  12. Prius Maximus
    956
    811
    Northeastern IL
    No, regardless of insurance or paying on my own, a prescription was needed. I did look up Stelo and this is new. Prior to a few weeks ago a CGM was only allowed by prescription. FDA reasoning was that it punctured the skin and inserted a needle and was therefore considered a medical device. I'm not sure how Stelo gets around this, it appears to be a 15 minute delay in the result reporting? In any case I did order a pair to try them out.
  13. fuzzy1
    10,694
    The FreeStyle Libre 3 monitors I bought for our cat a couple months ago, were $40 each.
    The CGM and insulin we use are the human versions, obtained through a human pharmacy, not veterinary pharmacy. With prescriptions, written by a veterinarian. In contrast, the syringes and skin-prick glucose monitor & strips are veterinary versions obtained through Amazon, without prescription.
  14. bwilson4web
    16,525
    Not the first time that veterinarians have provide "off label" meds and services to humans.
  15. bwilson4web
    16,525
    About to make breakfast that would normally be:
    • hot sausage patty
    • medium egg fried in olive oil
    Sad to say, I'm out of patty sausage but I have:
    • smoked kielbasa sausage
    • canned fish: sardines, anchovies, salmon
    I'm thinking sardines instead of the kielbasa but was wondering if our dietary experts might have an opinion.
  16. ETC(SS)
    7,526
    I suspect that if people can get them for cats then people can get them for people.
    $100 a month doesn't seem to be out of reach for most people, and if you cannot afford that price then I'm thinking that our "Bass Ackwards" health care system might foot some of the costs.
    Like all things.....someday soon the $3000.00 Betamax machine will 'probably' be replaced by a $10 unit that is more effective.
    HOWEVER (comma!!!)
    Thus far, despite my best efforts, I'm not in the market.
    Some people in my orbit endure semi-occasional finger pricks but only for monitoring purposes in a pre-prediabetic/insulin resistance mode.
    YMMV
  17. Zythryn
    Zythryn Senior Member
    6,411
    4,412
    These became available this year.
    I believe there are minor differences that allowed the FDA to give the OK for them to be sold without a perscription.
    Dexcom also makes one that can be bought without a perscription.
  18. bwilson4web
    16,525
    Sometimes the phone App will not read the sensor data for a while. For example, distance or other blocks between phone and sensor. When that happens, I open the "Bluetooth" system setting and "connect" to the sensor. In my case, "DX01lz" which usually wakes the App and gets the stored data from the sensor. I have seen as much as two hours of stored data while sleeping suddenly appear in the App.
  19. fuzzy1
    10,694
    The old home-town vet helped with that, for customers who had difficulty affording human-rated pharmaceuticals.
    But that isn't what we did here. We used human-rated products, acquired through human-rated product channels, for veterinary use on a diabetic cat.
    #19 fuzzy1, Sep 23, 2024
  20. ETC(SS)
    7,526
    Hope the cat leads a loong and healthy life....
    ...inside, if you live in town. ;)
    Since I'm a 'city' dweller now, and I'm limited to a dog. :(
