Controversial B mode thread :-)
Discussion in 'Gen 2 Prius Main Forum' started by mikewithaprius, Jul 2, 2011.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    In which case "60 amp braking" is the best option for maximizing regen and minimizing heat and other losses.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Yes, but not if you have to burn more fuel to get the higher SOC. SOC is not in any way an indication of efficiency. In fact the highest efficiency will be found when you don't use the battery, taking SOC completely out of the equation. Don't make the mistake of assuming more regen means better mpg.
    You need to accurately monitor fuel consumption before you can make any statement about efficiency.
    Tom
