Convert '07 Water Pump to one from Prius C?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kohnen, Apr 23, 2012.
  1. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    A true Scot would recoil at spending $1, but I'm with you on the geek part.
    I have worked out a temperature PWM speed control circuit with time delay shut off to prevent temperature spikes on engine shut down, and quicker warm ups. Just need a pump, so I may try an in line 12v as an experiment.
    I think the thermostat should stay in so that the cabin heater would get all the hot water circulation as long as the temperature of the water was not to high to require radiator cooling.
