Converting Prius G3 to all Electric removing ICE
Discussion in 'Gen 3 Prius Accessories and Modifications' started by smilyme, Nov 3, 2019.
  1. bisco
    52,877
    the concept is fantastic, i would love a prius bev
  2. smilyme
    smilyme Member
    112
    42
    #62 smilyme, Nov 14, 2019
  3. smilyme
    smilyme Member
    112
    42
    2009 (first demo) Prius 70 MPH Electric Mode: Ewert Energy Demo (first demo)
    from Ewert Energy Systems
    POC its encouraging that it can be done keeping all the original prius function
    in this variant of MG2 only
    Did They over amp MG2 only? or Did they access MG1 as a motor?
    MG2 only is what was done here I think
    this is not ideal compared to accessing MG1 and MG2 but very cool
    #63 smilyme, Nov 14, 2019
  4. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    If you can control MG1 & 2 independently you’re don’t need to weld, lock or mod anything
    but controlling an open sun gear can be challenging for a diy device
  5. smilyme
    smilyme Member
    112
    42
    yes i plan to control MG1 (as motor) and MG2 on G3 ( no weld like G2)
    I wonder what you mean "controlling an open sun gear can be challenging for a diy device"
    #65 smilyme, Nov 14, 2019
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I was hoping some type of reference point such as using same stock hv battery that comes with the turd gen 3, or an equation of total amp hour battery equals miles driven.
  7. smilyme
    smilyme Member
    112
    42
    it would be interesting a few km , but the batteries would be destroyed quickly if you did ,
    edit: well really interesting, what range we can access, without battery damage
    #67 smilyme, Nov 14, 2019
  8. smilyme
    smilyme Member
    112
    42
    #68 smilyme, Nov 15, 2019
  9. strawbrad
    953
    1,007
    I wish you the best with this project.
    Do you plan to use a G2 or a G3 inverter? Have you seen the extended warranty on the G3 inverter? They can fail when pushed too hard. Is that going to be a problem with your project?
    https://attachments.priuschat.com/attachment-files/2017/08/130837_Warranty_Enhancement_Notification_ZE3.pdf
  10. smilyme
    smilyme Member
    112
    42
    Thanks
    strawbrad
    I will use G3 so i can avoid welding the planetary gears
    and the combined Power of G3 is 102 kw vs 80 kw in G2
    (but i will still play with G2 inverters for other projects)
    Thanks for that link re the warranty
    "They can fail when pushed too hard. Is that going to be a problem with your project?"
    I expect i will find out but its designed by Panasonic and I don't plan to be be taxing it outside its ratings
    I will be monitoring temperature of motors and inverter
    Thank for wishes
    G2 P112
    MG2 67 hp 50 KW/500ac max 6700 RPM
    MG1 41 hp 30 KW/500ac max 10000 RPM
    -MG1 2.4 ratio to MG2 both M1/M2 Torquing
    -MG1 2.4 ratio to MG2 ICE
    -MG2 xx ratio to Drive Shaft (help)
    G3 P412
    MG2 80 hp 60 KW/650ac max 13500 RPM (403 lbf·f)
    MG1 57 hp 42 KW/650ac max 13500 RPM
    -MG1 1.014 ratio to MG2 both M1/M2 Torquing
    -MG1 3.6 ratio to MG2 ICE
    -MG2 8.6 ratio to Drive Shaft
    #70 smilyme, Nov 20, 2019
  11. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
  12. smilyme
    smilyme Member
    112
    42
    Damien Maguire 's release of the G3 logic board that he reversed engineered is also available as of Nov 2019 . He runs i think openinverter forum above.
    Although I have seen earlier G3 projects we have to credit Damien Maguire
    for placing the Gen 3 logic board controller in public domain in 2019.
    Prius Gen 3 Inverter Logic Board
    project at GitHub
    GitHub - damienmaguire/Prius-Gen3-Inverter: Open source logic board to control the Toyota Prius Gen 3 Inverter
    G2 has been reverse engineered for some time and has been public the link Rmay6635703 is great for G2 projects.
    From my post earlier I cant thank Damien enough:
    A Engineer in Ireland just recently Nov 2019 (starting 2018)
    created a replacement
    G3 inverter controller Logic board
    and has released it as public domain at GitHub
    Thank You Damien Maguire.
    #72 smilyme, Dec 19, 2019
    Rmay635703 and GG707 like this.
  13. EV Jake
    EV Jake New Member
    Vancouver WA
    Yes, one time my G2 ran out of gas, but I was able to continue driving on battery. I noticed that I couldn’t go any faster than around 40ish
  14. EV Jake
    EV Jake New Member
    Vancouver WA
    You had an earlier concern about many of the features not working when they sense that the ICE is missing. What if you developed the OBD code like this guy to bypass error codes?
  15. Soh
    Soh Junior Member
    26
    Australia
    i-Tech
    He is using an OBD reader to clear errors just before driving off.
    Interested in this specially as now you are not using a Plug in as its M1 and M2 are lesser powered and the simple G3 is a bit more easier to get a hold of.
    How far are you with your project??
    EDIT.
    Any options for using the ice solely as a battery charger. As in I would like the ICE to run only to charge the battery and disengage it from the tanssaxle.
    #75 Soh, Oct 3, 2020
  16. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    I don’t think the “transaxle” can be disengage.
    Maybe just pressing the gas pedal when in P...
  17. Prodigyplace
    12,720
    11,850
    Central Virginia
    The engine is also used to dissipate excess charge in downhill driving to avoid overcharging the battery pack.
  18. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Using the ICE to charge the battery (as in: more than you would under normal hybrid driving) is not a good idea, economy wise. The engine is still not very efficient and when charging and discharging you have losses. It is better to charge the battery from the mains and it is better to use the engine solely as propulsion.
    And no, it is impossible to disengage the ICE from the transaxle. Under normal circumstances it will not turn when the speed is below ~42 mph (on a normal hybrid, on the plugin it is a bit more), any higher than that and the engine has to turn. Not necessarily use fuel, but it must turn to prevent MG1 from over-revving.
    Attila Fekete likes this.
  19. Soh
    Soh Junior Member
    26
    Australia
    i-Tech
    Is that what happens when going down hill>
  20. ProblemPrius
    ProblemPrius New Member
    2013 Prius v wagon
    Whatever became of this project? Any updates?
