Coolant detected in exhaust
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by The Professor, Feb 23, 2023.
  1. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Finally fixed!
    Took about an hour and a half for them to install the new exhaust. In the end, Toyota paid for the exhaust and told the dealership to charge warranty level labour (which is around 30% less). I had to pay for that reduced rate labour, two gaskets, some coolant, new coolant hoses, and the reversal of the bypass. This all came in at £240.
    I asked why new hoses were needed, and they said it's because the existing ones wouldn't reach the connectors on the new exhaust's heat exchanger. I wonder if this has been redesigned and the connectors have moved.
  2. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    That is great news and thank you for the update. (y)
    Encouraging for us UK people who do not seem to be covered by the US TSB.
  3. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    My neighbor recently acquired this 2017 Prius as his new daily and he may deal with the mysterious leak. He'll take it to the dealer next week when he returns from a trail trip. The new brake pads and mud tires are getting installed on to his Wrangler today and they'll off tomorrow. I'll pass this thread to him later.
  4. BiomedO1
    BiomedO1 Senior Member
    4,641
    2,435
    Left Coast
    It's always a good idea to check fluid levels every fill-up on newly acquired cars - to get an idea of it's current leaks and seepage.
    JohnnyPR likes this.
  5. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    Yeah, all fluids are fresh.
  6. Dennis B
    Dennis B New Member
    Got the car back yesterday, new CC and some gaskets. Drove 60 miles round trip to work. No coolant lost in the reservoir that I can notice. I a might put a mark with a sharpie ? I did notice some coolant on the garage floor this morning, I’m sure there is some residual still in the nooks and crannies underneath.
    The whole repair was under warranty, so I am hoping to close the chapter on this. I will update any further problems.
    FYI- today is exactly 6 weeks from the day I left it at the dealership.
    #46 Dennis B, May 19, 2023
    SFO and BiomedO1 like this.
  7. Marcius
    Marcius Junior Member
    69
    So Cal
    Three Touring
    Trying to diagnose and find a new engine coolant leak on our 2017. My wife backed out of the garage, and I noticed maybe two tablespoons of coolant on each side of the passenger wheel. The underside of that one fender was all wet with coolant, too. The reservoir was only about 1/4 inch below the FULL line. Only a splash of coolant topped it up. From the top of the engine, I see no signs of leaks. I need to change the oil this weekend, so will look more. And, of course, I can smell burning coolant in the garage. Does coolant in the areas that I mention sound like it could be this dreadful exhaust pipe problem? I don’t mind keeping an eye on it, but it sounds like if I let something like that go, then the cat converts could be ruined?
  8. Mendel Leisk
    42,383
    This is rear passenger wheel?
  9. Marcius
    69
    So Cal
    Three Touring
    No, it's the front passenger wheel-well. (Oops.)
  10. Marcius
    69
    So Cal
    Three Touring
    After more research, I think I'm realizing that the cat converter is just part of the long exhaust pipe that gets replaced when there's a leak in the heat transfer system; and its's not so much about the cat converter getting ruined. I'm still hoping that my leak is something else minor.
  11. Marcius
    69
    So Cal
    Three Touring
    Today, I changed the oil, and did a coolant drain/refill (inverter & ICE.) Everything's super clean all around the engine bay; and all the exhaust pipe connections are clean. The water pump looked clean all-around, too. However, I never found the 'weep hole' on the WP. Is there one? Maybe my mirror skills aren't so good. But, I still have a feeling that the heat exchanger is leaking ever so slightly -- only because I smell coolant in the garage from time-to-time. An interesting note, when I was bleeding the ICE, I noticed that the reservoir goes down 1/4 inch when the heater's on; then it goes back up 1/4 inch when the heater's off. Also, ICE bleeding was a breeze when you fill, burp, fill again, burp again, then fill before running the engine in 2WD Inspection Mode (aka Maintenance Mode.) Burp, I mean squeeze the radiator hoses.) One weird thing, my engine turned off the first time I put it in Maintenance Mode. The second time, it stayed on. Somehow my wife got a lot of water on only the front passenger wheel-well, and I swear it smelled like coolant -- the garage did, too. I'll just keep an eye on it for now.
  12. bisco
    52,915
    i don't think there's a weep hole on the electric pumps.
    coolant in the front wheel well seems more like a hose leak
    Marcius likes this.
  13. Marcius
    69
    So Cal
    Three Touring
    Thanks. Maybe there's a hose hidden behind the plastic wheel-well, but not visible in the engine bay? If I get another (what appears to be) a coolant puddle on the garage floor, and/or if the level goes down in 1 to 2 weeks, I'll start tearing it apart.
  14. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    FWIW The ICE coolant reservoir is directly above that wheel well. Any chance the source of your leak is that?
  15. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Is it possible that these under the vehicle puddles are just condensate from the AC system drain tube?
    Mendel Leisk and Doug McC like this.
  16. Marcius
    69
    So Cal
    Three Touring
    The wife drove it about 80 miles today, and just got home. The level hasn't moved, and the garage doesn't even smell. The wheel-well is totally dry. I'm starting to think that when she took donations to Salvation Army on that smelly/wet wheel-well coolant day, she ran over a puddle of it in the back alley of that place. I have to leave it at that. Thanks everyone for your time, I learned a bit about the Prius, and if my exhaust heat transfer system ever breaks, then I'm throwing a bypass hose in there.
  17. Nico3d3
    Nico3d3 Junior Member
    37
    16
    Quebec
    Just as I was experiencing something similar, I saw your post. I have a Gen4 (2017) and, lo and behold, I found my coolant level to be really low while I was refilling windshield washer fluid. At least, it wasn't low enough to trigger a MIL. I was monitoring it monthly since it was already on the low side. I bought a bottle of pink Toyota coolant and I filled it to to max line but, it looks like I'll be in touch with Toyota dealership soon. I found the TSB on the Internet. In USA, it's under Federal Emission Warranty, I think it's the same in Canada. Only way to know is to call them. I don't think the head gasket is involved since I never found any coolant in the oil.
    #57 Nico3d3, May 23, 2023
  18. Dennis B
    Dennis B New Member
    I continued getting coolant under the car and took it back to the dealer. They said it had a leaky hose and clamp. I pressed the issue, and asked if I would be expected to change one hose at a time? The service manager reluctantly agreed, they replaced several hoses and clamps. This go round I was provided a loaner for 6 days.
    FYI: Tomorrow will be 7 weeks, since I took it to the dealership.
  19. Tideland Prius
    16,684
    Thanks for the link to the TSB.
    Our 2016 is exhibiting signs of low coolant (and the reservoir is nearly empty). Dealer is looking at it now and thinks an exhaust repair is needed. But first, they’re determining the source of the leak (if any). It seems like this TSB would cover the exhaust repair? (Currently being quoted $2,000 CAD)
    @Mendel Leisk thoughts?
    Edit:
    Many thanks to @The Professor! You saved us $2k. They agreed it’s under that TSB warranty. (No idea why that wasn’t brought up in the first place since we do have a lot of Prii in our area).
    #59 Tideland Prius, Jun 5, 2023
  20. Mendel Leisk
    42,383
    Sounds like a dealership dropping the ball. :confused:
