Coolant disappearing and can't find where
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Carsten, Jan 22, 2025.
Tags:
  1. Carsten
    Carsten Junior Member
    60
    Columbia, SC
    engine bay
  2. Carsten
    60
    Columbia, SC
    I'm starting to look into replacing the engine now.
    I found JDM engine depot, they say all of their engines will have 45-65k miles. Seems like there's a chance I could get one that has the same issue, one that has a OEM gasket which is apparently inferior to Feld Pro
    Hybrid pit doesn't offer a rebuild for gen 4, only gen 3, or does this not matter bc it's the same engine?
    Where should I go?
  3. Mendel Leisk
    42,365
    The FelPro would also likely blow if that’s what went in at the factory.
    Was thinking OP had gen 3 lol.
    Interesting exercise: put a 3rd gen EGR system in a 4th gen. (likely not doable, due to different programming in the two cars)
    #43 Mendel Leisk, Jan 30, 2025
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,981
    Texas Hill Country
    The hg design is not an issue with gen4. A jdm engine is your most cost effective solution.
    No they are not the same engine. Gen4 has significant improvements including cylinder wall changes to ensure consistent temperatures. Gen4 has different aux cooling and wiring harness lengths as well.
    Your problem started with longterm coolant leaks at the exhaust heat exchanger which was not immediately resolved. Engine damaged resulted. This has happened to many others; you or the previous owner were not the first.
    It would be the most bonehead move ever to put a gen3 engine in a gen4.
    #44 rjparker, Jan 30, 2025
    bisco, Prodigyplace and BiomedO1 like this.
  5. Carsten
    60
    Columbia, SC
    Thanks for setting me straight on that. I wasn't totally assuming they were the same, that's partly why I asked the question. I was just going off the basic specs - both have a 2ZR-FXE, to me that sounds like a model/part number. In my mind, since they are different, they should've changed that for the gen 4 but I'm sure there's a reason they didn't.
    But that's all beside the point, what's a good source for an engine is. HG design for the gen 4 may no longer be an issue but, it seems to me, a failing eghe which then causes engine damage could very well be, especially with a mystery engine from a JDM supplier. Thanks
  6. Carsten
    60
    Columbia, SC
    Put in new plugs a bit ago, Autolite Iridium XP. Sitting it purred but when I took it for a drive it ran rough again.
    There was also a weird smell, kind of a burnt smell but not electrical, more like plastic.
    This time got cylinder 2 misfire. I'm kinda wondering about the coils now, I'm thinking I'll get a spark tester rather than swap coils and plugs around.
  7. rjparker
    11,125
    6,981
    Texas Hill Country
    A head gasket leak on a Prius with severe metallic damper rattling incorrectly generates multiple or changing cylinder misfires. If it runs smooth most of the time while driving it is not a plug, coil or injector (before or now).
    douglasjre likes this.
  8. Carsten
    60
    Columbia, SC
    I wondered about that.
    I have spent the last 30 minutes searching the web for a guide (youtube, priuschat, physical repair manual) that will tell me step by step engine removal/install and I have found nothing.
  9. rjparker
    11,125
    6,981
    Texas Hill Country
    It is a hard day of work for someone who has a lift and all the tools. Even harder and longer on jack stands.
    This guy has decades of experience but it's tough at home. He is pulling a gen3 but the process is the same for a diy'er without a lift.
    I would pay someone experienced who has a shop a thousand to do it. Buying the power tools and an engine hoist would cost that much.
    douglasjre, Carsten and Mendel Leisk like this.
  10. Mendel Leisk
    42,365
    Or a third gen E
    Check the bottom link in my signature. (on a phone turn it landscape to see signatures)
    Also this:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    (it's in an odd place, technically appropriate, but...)
    Carsten likes this.
  11. rjparker
    11,125
    6,981
    Texas Hill Country
    douglasjre and Brian1954 like this.
  12. Carsten
    60
    Columbia, SC
  13. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I can readily think of about 10 different methodical diagnostic tests to diagnose a head gasket failure. What testing procedures have you performed to prove or disprove it?
  14. Carsten
    60
    Columbia, SC
    So far just the block test, I've got a borescope on order it'll be here next week
  15. Carsten
    60
    Columbia, SC
    Okay, if anyone is actually following this here's an update...
    Attached are some borescope pics. Cylinder 1 had a few drops of water, cylinders 2,3, and 4 had way more. All the piston tops looked about the same, maybe there is some degree of steam cleaning, I'm not sure exactly what they should normally look like.
    Upon removing the oil cap it was obviously milky inside, I should've taken a pic of the valve assembly it was very sludgy.
    I'm a repair/reuse kinda guy so I've decided to try to replace the gasket rather than replace the whole motor, of course I may end up doing that anyway. I took the cylinder head to a machinist, he will get back to me next week.
    I'm really happy with the borescope, $24 here's a link
  16. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Your engine was lubricated not with oil, but with coolant.
    Drain the liquid from the crankcase and do a chemical analysis.
  17. rjparker
    11,125
    6,981
    Texas Hill Country
    Looks like Niagara Falls in there
  18. Carsten
    60
    Columbia, SC
    And what would that tell me?
  19. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Information for deciding on a complete engine replacement without wasting time on its resurrection.
    Brian1954 likes this.
