Coolant going down - no idea of cause
Discussion in 'Gen 4 Prius Main Forum' started by Steelerfan2018, Jan 4, 2025.
  1. Steelerfan2018
    103
    42
    Pittsburgh
    Hi all,
    2016 prius with 177k miles. Have owned it for about 6 months with no issues.
    About two weeks ago I got an oil change. The oil looked almost new (changed it anyway) but the coolant reservoir was almost empty. The oil cap etc. was all clean - no white gunk. No white exhaust either. No coolant on the driveway. No signs of coolant leak that I can see.
    Anyways, I checked the coolant again - almost empty (maybe a 1/4" in the reservoir). I topped it off.
    Anyone have any thoughts on what it could be? Car is running fine but I'm worried about it.
    Thanks,
    Rob
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    Check your VIN on the NHSTA site for a recall. There was a recall die to losing coolant in the exhaust heat exchanger. Continuing to drive the car can ruin the engine. From what I have seen here, the replacement parts tend to be backordered.
    Here is the TSB, I think. https://static.nhtsa.gov/odi/tsbs/2019/MC-10166037-9999.pdf
  3. Mendel Leisk
    42,373
    Prodigyplace likes this.
  4. Steelerfan2018
    103
    42
    Pittsburgh
    thanks for your prompt reply - just checked the vin - no recalls.
    any other thoughts?
  5. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    Search the forums. Tons of threads on this issue.
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    @Mendel Leisk can verify, but the TSB may still apply under your emissions warranty.
  7. Mendel Leisk
    42,373
    Wouldn't hurt to print out the TSB, bring it in, see what they say. Choose a day when the sales department is busy dealing with customers, and talk like Jimmy Stewart. Talk about lemon laws and loaner cars. :)
  8. bisco
    52,891
    it's not a recall, but there is a service bulletin if a customer complains.
    tsb-coolant-leakage-at-front-exhaust-pipe-prius-prius-prime.211059
    the coolant leaks into the exhayst at the exhaust heat exchanger near the cat.
    it's a big expensive job to replace the offending part, if you can even get it.
    many here opt to bypass the heat exchanger by disconnecting the lines and tying them together with a piece of radiator hose.
    4th-gen-diy-heat-exchanger-bypass-solution.234801
    #8 bisco, Jan 4, 2025
    Ben Vaughan and amos like this.
  9. Mendel Leisk
    42,373
    Toyota combined the Exhaust Heat Recovery System with the catalytic converter, so one expensive chunk.
    amos likes this.
  10. Steelerfan2018
    103
    42
    Pittsburgh
    is it OK to drive? Should I try a leak sealer?
  11. Mendel Leisk
    42,373
    God no, just research bypass. Google this:
    4th gen prius exhaust heat exchanger bypass
    Yields good results, including multiple PriusChat threads.
    Amayama has it, I'm seeing $1548 CDN, with TBD for shipping. They say they'll get back to you with shipping charge before you need to commit.
    Exhaust pipe for Toyota Prius ZVW50L - Genuine parts - Amayama
    Ben Vaughan likes this.
  12. bisco
    52,891
    see post #8. you need to replace the part or do the bypass. if the coolant gets too low, you'll blow the engine.
    fill the coolant and keep an eye on it all the time until you do one of the repairs. leak sealer won't do anything but ruin the radiators.
  13. Steelerfan2018
    103
    42
    Pittsburgh
    If I keep adding coolant = OK until I can afford to get it fixed? Don't have that kind of money right now.
    amos likes this.
  14. bisco
    52,891
    yes, just don't let it get low again
  15. Steelerfan2018
    103
    42
    Pittsburgh
    I have coolant - will check every day. I'll get my mechanic to check on it next week.
  16. rjparker
    rjparker Tu Humilde Sirviente
    11,136
    6,985
    Texas Hill Country
    No an engine is about $8k. A bypass is $50.
    BiomedO1 likes this.
  17. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    You need to check coolant level everytime before you start the car - Not just daily. Until you get an idea of how much is leaking per miles driven. @rjparker stated $8K for engine replacement or $50 to bypass the exhaust gas heat exchanger. You'll need to get it fixed before your next emissions/safety inspection, depending on what your state looks for on those inspections.
    Hope this helps.....
    amos and bisco like this.
  18. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    There was never any recall, just the TSB that explained the symptoms to look for and remedy (replace the forward CAT with the heat exchanger). You're out of the parameters for Toyota to replace it via the TSB, so you're on your own. A mechanic will not be able to diagnose without tearing into your exhaust to look for signs of coolant burn off. As long as you have unexplained coolant loss, possible poor cabin heating and maybe white smoke from the exhaust, you've got the heat exchanger leak. You don't want to run out of coolant and overheat your engine. Then you're dead in the water I'm afraid with a really expansive engine replacement.
    The easiest thing to do at this point is the bypass procedure that takes the heat exchanger out of the equation. There's a simple U-shaped rubber hose that will do the trick in the vicinity of the coolant line connections near the CAT/heat exchanger. Here's the item on Amazon,
  19. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Since checking the coolant level for a few days now, how much is it using per day?
    After you finish checking under the hood, put your prius in Ready Mode and keep the engine running
    ( turn on the defroster with heat ) or ( find the procedure to put the Gen 4 Prius in Maintenance Mode - so the engine stays running).
    Now go to the back of the car and look for smoke from the tail pipe.
    If you see any smoke, reach under the car and smack the muffler a few times to see if hear any sloshing in there, if you hear it and see it, that's coolant in there.
    #19 vvillovv, Jan 5, 2025
  20. Mendel Leisk
    42,373
    Does putting it in B also stop the engine from turning off; I forget.
