Coolant going down - no idea of cause
Discussion in 'Gen 4 Prius Main Forum' started by Steelerfan2018, Jan 4, 2025.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,109
    6,970
    Texas Hill Country
    Inspection / Maintenance Mode
    Continuously Run Engine
    Press Start button 2 times without Brake (ignition On)
    Press Gas Pedal 2 times
    Press brake and shift to Neutral
    Press Park
    (hybrid warning light will start flashing or Maintenance Mode Message)
    Press Brake and Start button
    (starts engine, don't drive it, shutdown to return to normal)
    Cliff Notes:
    Ignition Mode, 2Gas, Neutral, 2Gas, Park, 2Gas, Start Engine
    #21 rjparker, Jan 6, 2025
    UN4GTBL and Prodigyplace like this.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Yes it does, but then he would need someone holding the brake pedal/emergency brake to keep the car from moving while another person checks the exhaust.
  3. Mendel Leisk
    42,349
    Ah yeah, that could get dangerous.
  4. Steelerfan2018
    103
    42
    Pittsburgh
    Ok - Update - had mechanic look at the car - did a pressure test and no problems.
    Can someone give me a "dummies" version of the bypassing heat exchange? Is this something a mechanic can do? What parts do I need? Yes, I googled it and
  5. Steelerfan2018
    103
    42
    Pittsburgh
    ooops - hit post too early...
    I googled it and it looks a bit confusing. I found this post 4th Gen DIY heat exchanger bypass solution | PriusChat
    When I see this picture:
    I see the new hose put on the left - what clamps should I use?
    Also - shouldn't the ends of the pipes on the left be capped?
    thanks,
    Rob
    vvillovv likes this.
  6. Mendel Leisk
    42,349
    You beat me to it. :)
    Googled this:
    priuschat gen 4 exhaust heat recovery bypass
    Then settled on this:
    For sure it'd be good to cap the pipes. For starters, there'll be a slight amount of exhaust escaping through them?
    Get coolant hose clamps, with a suitable clamping range. For example: if you push the hose on and measure OD to be 20 mm, look for hose clamps with a range something like 18~22 mm. I'm not sure they list them thus though, I have been bitten. If you for example see one that says 20 mm diameter, that's probably it's at-rest ID, and it won't be tight enough.
    amos likes this.
  7. Steelerfan2018
    103
    42
    Pittsburgh
    looking at 17410-37A00 - Toyota Parts Deal
    what part # should I get if I decide the get the whole thing replaced?
    17410-37A00 or
    • Replaced By 17410-37B52
    thanks,
    Rob
  8. BiomedO1
    BiomedO1 Senior Member
    4,606
    2,415
    Left Coast
    IMHO; Loop-in/cap the other end too. In case you fail emissions testing and have to re-establish the setup. That will keep you from contaminating your coolant, if you have to do that. Otherwise road debris will get in there and a small exhaust leak.
  9. Steelerfan2018
    103
    42
    Pittsburgh
    Update - just talked to my mechanic again - he says he did a pressure test for 30 minutes and it didn't loose any fluid. So what exactly is happening?
  10. rjparker
    11,109
    6,970
    Texas Hill Country
    I would make sure the "Exhaust Gas Control Valve" was mechanically secured in its activated (green arrows) position to reduce exhaust back pressure through this system.
    Red is exhaust flow when cold
    Green is flow when coolant is hot
    When coolant is cold, exhaust flow is directed through the Heat Exchanger by the manual thermostatically controlled "Exhaust Flow Control Valve" below.
    This exhaust divergence is only for a few minutes until the engine warms up.
    However after the coolant bypass "fix" the Control Valve stays in its cold position because coolant is no longer in its circuit.
    #30 rjparker, Jan 7, 2025
    Brian1954 likes this.
  11. bisco
    52,858
    where does your mech think the coolant is going?
    amos likes this.
  12. Steelerfan2018
    103
    42
    Pittsburgh
    when he ran the pressure test - no coolant leaked. He has no idea what's going on.
  13. bisco
    52,858
    sounds like he doesn't understand the prius system.
    UN4GTBL and Ultimate_Combination like this.
  14. Mendel Leisk
    42,349
    Just continue to monitor. It might be just a gradual drop over the years, you've topped it up, and it'll be stable now. Takes time.
    With our '10 I noticed both reservoirs down to the bottom line after about 5 years of ownership and 50k kms. Then again around 8 years and 80k, just the engine coolant was once again down to the bottom line, needed another top up. Did a coolant change on both at 10 years and been stable since. Maybe a few air pockets from the factory, working their way out.
  15. bisco
    52,858
    almost empty reservoir is the key here, i think
  16. rjparker
    11,109
    6,970
    Texas Hill Country
    First, you have a 2016 hatchback and not a 2016 gen3 Prius v correct? Big differences in the engines and coolant systems.
    Based on your early posts the reservoir has almost completely emptied at least twice in the last months. This is bad.
    So when your mechanic says it held pressure for 30 minutes he is either not testing properly or you have a runtime leak.
    About the only runtime leak that comes to mind is a head gasket leak.
    But the simple problem on a 2016 gen4 hatchback is the exhaust heat recirc system. A bypass is also a low cost diagnostic. If the problem goes away you know the issue. Low cost and fast.
    Assuming you have a good Prius mechanic he should know the gen4 coolant system.
    #36 rjparker, Jan 7, 2025
    Brian1954 and Mendel Leisk like this.
  17. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Here's the video that explained it to me. I get to watch it a lot, since a lot of people have asked the same question as you have.
    Here's another one from AMD's Car Care Nut channel he published before he opened his own Auto Repair shop while he was still in the dealers shop.
    #37 vvillovv, Jan 8, 2025
    Prodigyplace likes this.
  18. rjparker
    11,109
    6,970
    Texas Hill Country
    That video shows a no parts cost bypass which is a good diagnostic.
    I would still mechanically open the exhaust gas control valve shown in the post 30 above and also cap the loose hoses from the heat exchanger since they could leak exhaust.
  19. amos
    amos Active Member
    376
    285
    los angeles
    Any info on what % of all priuses have this issue. I have no problem with that but always checking it just to make sure. I also have this bypass hose with me in the car just in case will happen in the middle of the road. Wondering should I just rbypass?
    Than I will have to wait for a long time until heat gets to right temp? Here in so Cal with all the fires coming soon it's not really an issue. Wonder if this bypass voids any kind of warranty or smog check
  20. amos
    amos Active Member
    376
    285
    los angeles
    Is this problem more related to places with cold weather? Or is it more likely to happen if we use the heater more often?
    Here in l.a area I almost don't use the heater or else will shut off after a minute or two. Or is this not related?
