Coolant High Temp Flasing, Clears Then returns
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ritzy4runner, May 30, 2025.
  1. Ritzy4runner
    Ritzy4runner Junior Member
    39
    Bremerton, WA
    A bit curious on this one. I was getting a random alert on the coolant temp. Would be solid, then clear. Later it would blink several times then clear but then come right back solid. with the speed around 50 mph give or take 5mph. Checked the coolant overflow tank and it was low. Added some purified water and then it cleared. Added 50/50 red Toyota coolant and filled tank to a bit over half. Seems to be doing ok but I checked the tank after overnight and it was low again. When I opened the cap there was a bit of pressure released. Topped off again and it is like the coolant is going somewhere, I can't figure out where. No leakage noted on the ground under the car, the oil is clear so no head gasket leak. Is it possible that the level in the engine was low enough that when the engine is cool there is some flow into the engine? I will check again tomorrow and add more if it is low. Just never had an issue with coolant in my prius. Any suggests on what to check for or am I missing something? Thaks
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    "...the oil is clear so no head gasket leak..." ha ha ha. That's funny!
    By the time that happens in a Prius engine, you've lost the engine.
    Are you getting misfires? How many miles are on the engine?
    You likely have a failing coolant pump impeller. Time for a coolant pump.
    The engine is overheating, and the coolant could be expelling out of the overflow tank.
    The only other places it goes if there are no leaks, in usually between cylinder #1 and #2.
    That's why you'll get knocking when it's cold.
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,691
    1,076
    South Central PA, USA
    Based on your other new thread for engine misfire codes P030x, and the fact that you have 206k miles on the car, you probably have a blown head gasket and a failing engine water pump. https://priuschat.com/index.php?posts/3539092
    #3 Brian1954, May 30, 2025
    themzlab and BiomedO1 like this.
