Coolant in Brake fluid reservoir.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by r619, Jan 10, 2014.
  1. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    I purchased a 2008 Prius with 117,000 miles lat month. I took it to a friend's house recently. When he was looking at the car, he told me that my coolant level is low and put some coolant in the reservoir. The next day when I was driving the car I was hearing a rattling sound every time I pressed on brakes. I could not figure out what could be the reason. The sound went away after couple of days. Today I was going through the manual and noticed the place where my friend put coolant in is actually brake fluid reservoir. It looks a lot like coolant reservoir of my other car. So now I am wondering what could happen if coolant goes into brake fluid reservoir. Will it harm my brakes? It has been about 2 weeks since that incident happened. Thank you very much.
  2. Rich12
    Rich12 Member
    176
    29
    OH NOES...please tell me this is an apocryphal story. Coolant is de-ionized water (the anti-freeze part is e. glycol). Water and brake lines are a baaaadddd mix. You need to flush the brake lines today. I'll be over to help w/ tools in hand. And a bottle or two of Toyota DOT 3...
  3. Patrick Wong
    18,210
    6,517
    Yes. Any water content is very damaging to the brake system components.
    You need to immediately visit your local Toyota dealer and ask for the brake hydraulic system to be flushed with new brake fluid, and hope this does not cause long-term damage to the brake actuator pump, which would result in a nice four-digit repair bill.
    While there, you should have the 100K and 120K mile services performed unless you have evidence those services were already performed. This will include engine and inverter coolant, iridium spark plugs, and engine air/cabin air filter replacement.
    Stop at the parts counter and buy a gallon of Toyota Super Long Life Coolant, and now that you know where the engine and inverter coolant reservoirs are, top them off as needed. Don't use some strange aftermarket coolant.
    52,819
    hey, what are friends for?
  5. Mike500
    Mike500 Senior Member
    2,593
    767
    Really bad.........
    The damage may already have been done.
    Water is very corrosive to the iron and aluminum components in the brake system and very hard to get out.
    You may need two brake fluid flushes. One initial one and another further in time to remove any moisture "reabsorbed" that was not caught in the first flush.
    You need to buy these test strips to continue testing afterwards;
    That's why I'd NEVER let anyone but a dealer or myself add any fluid to my car. I'd be surprised the "friend" even used the correct anti-freeze specified for Prius.
  6. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    Is there anyway i can confirm I have coolant in my brake fluid reservior? Im pretty positive thats where he put the coolant, but not 100% sure. Should the brake fluid flush done only at dealer and how much should it cost? Patrick I was also thinking about 120K miles service. Does all the services need to be done at dealer and how much should I looking to spend?
    iPad using Tapatalk
  7. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    Some "friends" are there to mess up your life and some(PC friends) are there to help you fix it.
    iPad using Tapatalk
  8. Patrick Wong
    18,210
    6,517
    Use a coolant test strip as suggested above. However the cost of those strips is quite high, you'd might as well have the brake fluid flushed and changed anyway.
    The brake fluid flush must be done at a Toyota dealer or an independent who is trained on Toyota hybrids. An average repair shop cannot do this work because access to the Toyota diagnostic laptop is required.
    Both the 100K and 120K mile services need to be performed. The engine and inverter coolant changes are specified at 100K miles. Special Toyota hybrid training is required to perform both coolant changes. You'll probably pay a high three-digit amount for a combined service, depending upon labor rates at your locale.
    dbcassidy likes this.
  9. Mike500
    2,593
    767
    I you don't monitor the amount of moisture in the brake fluid even after the fluid change, how are you going to know that they got it all out.
    The test strips might be expensive, but it is good insurance, especially when moisture can cause extensive damage in a brake system.
  10. JC91006
    16,936
    8,647
    The brake fluid has somewhat of a greenish tint to it, but should be mostly clear, the Toyota coolant is pink. Hopefully your friend used the pink coolant to fill instead of the Green color coolant (which is not used in the Prius).
    I'm assuming your friend is smart enough to know the pink stuff is not going to mix with the clear brake fluid. Look at the fluid, does it look like it was combined with any pink fluid?
    It would be easy to tell if he added the pink stuff to the brake fluid. If he added green coolant, it would be a little harder to tell cause it would then look like dirty brake fluid.
  11. Rich12
    Rich12 Member
    176
    29
    Just suck it out with a turkey baster until the reservoir is dry, refill w/ brake fluid..and PRAY LIKE YOU'VE NEVER PRAYED BEFORE.
  12. Mike500
    2,593
    767
    If it was me, I'd fix it and sell the car. Then, I'd thank your friend.
  13. JC91006
    16,936
    8,647
    There is almost no possibility he could have added the pink stuff to it. Unless he picked up green coolant and added it to dirty brake fluid. I'd say the odds are low.
  14. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    Well he doesn't have a Toyota. He has a Volvo and BMW. But he said all the coolant are same and I don't know the color of the fluid he added. He works on his own car, so I thought he was knowledgeable and trusted him. It was within two weeks of owning the car and I had little knowledge about it.
    Turn off signatures in Tapatalk Tapatalk
  15. JC91006
    16,936
    8,647
    You want to take a picture of the brake fluid as it looks now? Post it on here.
    So odds are he added green coolant to your greenish brake fluid?
  16. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    How do I take the brake fluid out? Sorry I'm a newbie.
  17. Mike500
    2,593
    767
    If you have the test strips, they will tell you, if there is waterin the brake fluid. Ethylene glycol doesn't help, either.
  18. JC91006
    16,936
    8,647
    I mean just looking at it with the hood open...take a picture. Or you can look at it, is it dark? Brake fluid is normally clear. Dirty brake fluid will be a bit greenish.
    Remember Toyota Prius coolant is pink in color.
  19. Mike500
    2,593
    767
    Apparently and unfortunately, you thought wrong. Toyota needs a special coolant. They are NOT all the same.
  20. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    With friends like that, you don't need any enemies. :p
    I don't suppose your "friend" would split the cost of rectifying the situation with you?
    Brings back memories of a previous thread where a "buddy" said it was OK to put diesel fuel into a rented Prius. :eek:
    SCH-I535
