Coolant inverter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mohammad khaled, Jan 2, 2019.
  1. Mohammad khaled
    Mohammad khaled Junior Member
    jordan
    why does inverter losing fluid , i have filled it up to full when I arrived home it was in low level
    52,542
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Check the drainage plug
    Raytheeagle and Mohammad khaled like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    All hoses are in tact and the plastic reservoir doesn’t have a crack?
    Do you see where the coolant remnants are and trace it back to the source?
  5. Mohammad khaled
    jordan
  6. Mohammad khaled
    jordan
    Where does this locate
  7. tankyuong
    1,555
    662
    Central MO
    Under the car with an Allen shaped bolt
