Coolant leak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dunggah, Jul 1, 2015.
  1. dunggah
    dunggah New Member
    SF Bay Area
    So after taking a look under the hood, I see some pink residue around the area where I think the engine water pump is. However taking a look at the reservoir, the fluid levels seems to be filled to the brim. Obviously, something must have leaked for the pink residue to show up, which doesn't look like much at all. Should I just continue to monitor the coolant levels or is there a rush to bring it to a mechanic?
  2. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    With the engine cool, check your coolant level at the radiator cap (you need to pull the black plastic front engine bay cover to have access) and make sure it's topped off there. The radiator level can drop to a certain extent without affecting the level in the reservoir. If you're not seeing sign of a large leak, it's probably just weeping. No huge emergency, but I'd get it taken care of at your earliest convenience. An overheat could lead to a warped head and head gasket issues. If you monitor both coolant level in the rad and the water pump itself, you'll be fine.
    Pretty easy DIY, too, if you're so inclined.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    very easy water pump replacement. buy a name brand or better yet a Toyota water pump, not some cheap reman from Indonesia, or you'll be doing the job twice.
