Coolant loss, leaking head gasket?
Discussion in 'Gen 3 Prius Technical Discussion' started by Whattheprius, Dec 8, 2017.
  1. Whattheprius
    Whattheprius New Member
    Long beach
    Hey everyone! So I put the k seal in on a Sunday. Drove 40 miles home from work. Let the car sit till Wednesday. Drove about 150 miles so far. The misfires reduced by 95%. Coolant level is holding. CEL is still on. Car seems to driving well. 42mpg and climbing. So far so good! Thanks y’all!
    Tbkilb01 and Raytheeagle like this.
  2. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Snake oil!
  3. Whattheprius
    Long beach
    I have no reason to lie. I used it and noticed a significant difference in the symptoms I was getting, no more misfires. So far so good.
    m.wynn and Raytheeagle like this.
  4. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Nothing personal, but about once a month some new member shows up here with a miracle product that just happens to cure the latest major problem that is going around. Are you surprised that these claims, always glowing, are met with some scepticism?
    amos likes this.
  5. Tbkilb01
    218
    187
    Louisiana
    There is always going to be additives and quick fixes and sometimes they work. Most times they are just temporary though. I personably hope this works for ya..but for the most part,repairing problem properly is the best fix. Are you planning on dumping coolant and refilling with fresh coolant? Again, don't get discouraged, this forum is full of drama queens and naysayers...it's worse than the social network thingy more times than not, but it's packed with invaluable info but you just got to wade thru the malarkey. There really are a few really knowledgable pri people that respond.
    amos and fanzindel like this.
  6. Goguy
    Goguy New Member
    Nor Cal
    I’m thinking about using the K-seal for my head gasket as well. A dump question but do you pour the k-seal into the coolant reservoir on the left side of the engine since there is no access to the radiator such as those in conventional engine vehicles?
  7. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Left side as you face the engine bay from the front of the car - yes.
    Does your '14 have a blown HG? Please tell your story as we're quite into data behind these turd gen engine issues.
    amos and Raytheeagle like this.
  8. Mendel Leisk
    42,293
    I'm thinking clogged EGR is a contributory factor to the head gasket failures, or even the root cause. Original poster mentioned bad EGR clogging. And then maybe the EGR clog is due to PCV dumping into the intake manifold, which brings us back to Oil Catch Can again.
    Third gen ownership marches inexorably into the "cobbling" stage, lol.
  9. m.wynn
    684
    1,230
    Queensbury, NY
    I think everyone here with an awareness of the issue is on the same page as you, Mendel. Makes you feel for oblivious turd gen owners just racking up the miles:(...
    amos, mjoo, Raytheeagle and 1 other person like this.
  10. fanzindel
    fanzindel Junior Member
    Any updates? Did it hold up?
  11. 909prius
    909prius Junior Member
    Redlands
    I just recently replaced my head gasket myself a few days ago due to having cylinder #1 misfire and losing coolant. I have a 12 Prius with 208,000 miles. So far after putting 1500 miles on the car everything is perfect!. I was skeptical on trying those sealants that you put in the radiator.
    amos and Mendel Leisk like this.
  12. oasmith
    oasmith Junior Member
    42
    22
    Hi everyone, I was going to make my own post, but this seems to sum it up for me. I have a '14 with 240k on it, and I've been noticing the coolant level go down the past few days. I'm thinking (based on this thread) that I also have a blown HG. There is some knocking when I first turn it on in the cold mornings. I did get some misfires codes for cylinders 1 and 2, but I added in a bottle of oil and no more errors. Still knocks a little. But, mainly, when it does knock I can kinda smell coolant, and like I said the coolant level is going down. Around 30k miles go I cleaned out the intake manifold and EGR pipe, but not the whole cooler. I'll check it for the creamy symptom, but wondering if this thing is doomed. I don't plan on fixing it if it's a blown head gasket. But it still runs fine after that initial start up in the morning, so maybe I can still save this thing. Any suggestions to avert a full failure? The kseal? Thanks for any help!
    amos likes this.
  13. Mendel Leisk
    42,293
    240K is a lot of miles. Judging from what you're saying, maybe time to sell it for parts. There are things that can be done, probably the most cost effective is to drop in and mod a low-mileage fourth gen engine from a wreck, they go for $1500~$2000. Maybe around $200? And that's just the part. Google "LKQ engines".
    This one is going into a Prius v, but the principals are very similar, and his previous swap was with a regular 3rd Gen Prius.
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    #33 Mendel Leisk, Oct 16, 2018
  14. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Clean the egr circuit stem to stern;).
    That’s a lot of miles in a short period of time. If the Prius is good in condition terms, I’d start pricing engine options as you may have lost the head gasket:(.
    But clean the circuit would be the next step(y).
  15. oasmith
    42
    22
    Just an update, though nothing significant. I did put that K-Seal stuff in the coolant reservoir, and the knocked seems have gone away completely in the past couple days, and it's been chilly out. But, i'm not even sure if i applied it right: I had noticed the level was below the Low line by about an inch. After adding the K-Seal, that brought it up to about Full. The next day (I had already driven about 130 miles after adding the K-Seal), i noticed that coolant had dribbled out around my tire, and i found that there had been quite a bit of bubbling and spraying of coolant out of the filler cap area. I then reread the instructions and it said that for pressurized systems to add the K-Seal right in to the hose, not the reservoir. Hm. So, i've been checking the coolant level and it seems to go up and down, and i'm always checking it after it's been off for a few hours. Anyway, i'm worried that my initial interpretation of the Low level wasn't entirely accurate. Do you guys know when the best time to check the level is? And how is it that i go from being Low, to spraying out of the filler cap? Thanks for any help!
    And Ray, ya, i know, the EGR cooler. I just really don't wanna.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Loss of coolant and highly pressurized coolant loop is usually blown head gasket.
    Getting quite common on a g3.
    amos likes this.
  17. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I can tell you from experience that sealer will get you about 3 months/3k miles. I was there in March. Mid July the head gasket failed and caused catastrophic engine failure. Start looking at Gen 4 engines in salvage yards. If you can do the work yourself, the Gen 3 head is a bolt on to the Gen 4 block. Then the engine bolts back in the way it came out.
    amos and RMB like this.
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    @Joele3 has used Kseal or a derivation thereof for over 15k miles, so YMMV;).
    Clean the circuit before it’s too late(y).
    RMB and amos like this.
  19. joe doe
    joe doe New Member
    conway nh
