Coolant Loss
Discussion in 'Gen 3 Prius Technical Discussion' started by donzoh1, Nov 13, 2023.
  1. Mendel Leisk
    42,264
    You neglect the carbon-clogged EGR system for 150K or so. Then develop rattle, likely due to (uncompressible) coolant seeping past gasket into cylinder, due to overheating, due to blocked or uneven exhaust gas supply to the combustion chambers. Then you clean the EGR system. Is it logical to think this'll "heal" the head gasket leakage?
  2. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    This one was actually hesitating on each startup during normal driving. After adding the repair concoction, the hesitation is gone but coolant is now escaping from the reservoir cap. I may have created a mess internally but also need to make sure the cooling fan is working properly.
  3. donzoh1
    450
    153
    Lenexa, KS
    The EGR problem caused P0300 and also broke the input damper plate. I assumed the misfire condition was due to the EGR clog. There wasn't coolant loss or coolant/oil mixing. It may have caused other damage, although everything was fine for 20K miles after the EGR cleaning. If something was marginally damaged but not enough to cause symptoms, maybe that has subsequently failed more completely. Still, there are no current codes relating to any of these issues.
  4. BiomedO1
    BiomedO1 Senior Member
    4,519
    2,378
    Left Coast
    Pull the plugs and check for steam cleaned piston tops.
    You can unplug and feed power directly into the fan. If it turns on it's fine. Both fans on my CRV was dead, only indication was it would run a bit hot, fans suppose to kick on around mid-gauge - it was up 3/4 the way to hot. The AC didn't blow cold unless I was on the highway.
    Hope this helps..
    donzoh1 likes this.
  5. Mendel Leisk
    42,264
    My 2 cents: EGR clogging caused uneven and/or too high combustion chamber temps, which caused head gasket to fail, which resulted in uncompressible coolant seeping into combustion chambers. That incompressible coolant is what causes the rattles, as the pistons struggle to get over TDC, and breaks the springs in the damper plate twixt engine and transaxle.
    donzoh1 likes this.
  6. donzoh1
    450
    153
    Lenexa, KS
    I'm planning to verify cooling fan operation, verify coolant flow in radiator, and then leak down test. After that, let the Head Games begin!
  7. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    ???????WHAT????????
  8. donzoh1
    450
    153
    Lenexa, KS
    If you're asking about the Head Games comment, that means cylinder head removal and head gasket replacement. I had so much fun with the last such episode, after all.
  9. donzoh1
    450
    153
    Lenexa, KS
    After your deck chair comment, I have renamed the Gen 3 Pri-Tanic.
    Anyway, I drained the coolant and only got about a gallon. I'm thinking that's a bit low and would cause high cylinder head temps? I added new coolant and went for a 7 mile test drive. It was 35F outside and ECT was between 185 and 200 and peaked at about 3 or 4 miles. Coolant level looked the same at the end. I don't think the cooling fans ever came on either while driving or while adding coolant.
    The K-Seal instructions say you can leave it in long term or replace the coolant after a short time. The ICE is still running well with no hesitation or bobbling on startup. Also, the coolant reservoir excess pressure is gone. My recent engine block test did not detect combustion gas in the coolant but the result may have been different when the excess pressures were there. I think crankcase pressures are still too high so there's either piston ring bypass or broken head gasket. I'm leaning toward piston rings since there are no misfire codes. We will see whether there's a long term result in terms of the startup miss.
    I'm thinking one or several factors caused the coolant loss. 1. Broken head gasket either causing coolant loss directly or thru exhaust gas pressure. 2. Oil starvation after striking a chunk of freeway ice which perhaps caused overheating?
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,003
    6,894
    Texas Hill Country
    You don’t have to be Sherlock with these clues
    At 38f the fan will never come on. In the winter the fan is not a factor especially in a stop start engine. It usually does not come on at 100f ambient either unless you turn the AC on. Test by turning the AC on.
    I have changed my coolant many many times. About one gallon drained is normal. Because of this, it is difficult to remove all the coolant; you are simply diluting old with new. Same problem when trying to remove sealant, especially out of the extremely small heat exchanger tubes.
    Combustion gas testers don’t work on a gen3 hg leak that seals in seconds after engine start. Using sealer invalidates a gasses test because you have temporarily sealed the hg.
    These cars will never go over 208f even in 105f ambient after an hour of high speed driving under intense uv radiation, even when followed by high rpm climbing a steep grade.
    240f is a cooling problem, usually caused by a blocked radiator (internal or external), very low coolant or a failing water pump. A normal cooling system will not use coolant for years on end. Some 15 year old cars have never had their pressure cap off.
    Since we have used sealant and it is currently sealing a hg, it is likely doing the same in a radiator with extremely small passages.
    This test was a definitive verification of a leaking head gasket. Not recommended due to reduced cooling and heater performance. The head gasket caused misfires are gone after sealant but the root cause remains and will reappear in weeks to three months.
    Generally coolant residue around the reservoir cap is the result of the pressure relief releasing.
    #30 rjparker, Dec 10, 2023
    Brian1954 and Mendel Leisk like this.
  11. Mendel Leisk
    42,264
    Yeah I got 4.25 liters when I drained ours, majority from the radiator drain tap, and about a 1/4 cup (at most, won't bother again) from the block tap. A US gallon is about 50 cc short of 4 liters.
    I've lost track; you added some? If you want to get it out, one manufacturer of such a product recommended a flush with 50/50 distilled water and white vinegar. It may be effective with your system. If you can find any "chunks", try the solution on them. If you try that, then I'd think then at least a couple more flushes with straight distilled water, to get the vinegar out. Then, due to residual water in the system, to achieve 50/50 coolant/water, maybe try the link in my signature musing about that.
  12. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    ?? More like 215 cc. Perhaps you were thinking of a U.S. quart being "about" 50 cc short of 1 liter?
  13. Mendel Leisk
    42,264
    Exactly. :oops:(y)
    CR94 likes this.
  14. donzoh1
    450
    153
    Lenexa, KS
    Continued coolant loss at the reservoir cap was resolved with installation of a new cap. (Maybe some K-Seal got into the relief valve on the old one?)
    Anyway, I put several hundred miles on it and it ran great! In fact, it previously never did better than 42 mpg and today it was at 48 mpg with predicted range going from 440 to 560 miles.
    The hesitation/miss had disappeared several days ago. Then, it appeared again tonight with some coolant being lost past the new reservoir cap. I'm thinking the K-Seal repair was dislodged and then combustion gas pressure into a coolant passage expelled some coolant.
    I'm inching closer to head gasket replacement, although my lazy side would love to find a solution in a bottle.
  15. Mendel Leisk
    42,264
    The cars gonna drive you to drinking lol.
  16. donzoh1
    450
    153
    Lenexa, KS
    Too late.
  17. donzoh1
    450
    153
    Lenexa, KS
    Figured head gasket was compromised at Cylinder 1 because the EGR Cooler was completely clogged about 25K miles ago and trouble codes were P0300, P0301, and P0302. There were no codes recently, however, even though the ICE regularly stumbled on startup. Removing the spark plugs, I noticed the 1 and 2 pistons were wet but 3 and 4 were bone dry. I'm thinking there is a head gasket break between 1 and 2 which was temporarily fixed with K-Seal. Now, I'm ordering a new head gasket kit with bolts.
  18. donzoh1
    450
    153
    Lenexa, KS
    Also, supplying Cylinder 1 with compressed air at TDC on compression caused expulsion of coolant from top reservoir hose. That confirms gasket break at least at Cylinder 1 but I'm still curious that there are no pending or stored codes.
