Coolant Low : Both Engine + Inverter : Few Questions !
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pooka, Dec 31, 2011.
  1. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    40K Miles in about 20 months.
    Both the Engine and Inverter Coolant are at the Low Level Mark.
    a) Checked for leaks (Pink Crystals etc.) - nothing found.
    b) AFAIK my VIN is after the coolant plug TSB.
    Now:
    a) Is this normal ?
    b) My understanding is that Engine Plumbing and Inverter Plumbing is separate ? Correct ? If so there are two different leaks (if) ?
    c) The pink Toyota Coolant is same for both ?
    d) Its simple top up if I buy the coolant from the dealer? or we gotta bleed the air bubbles out / system flush etc.?
    Thanks. Any prompt responses appreciated - so that I can go at it from dealer now ! Happy New Year Everyone !
  2. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    There is no need to bleed the system after a top-off. Just fill with Super Long Life Coolant to the proper level, and don't worry about it further.
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Happy New Year! 'what temperature did you measure the coolant level at. I.e. immeadiately after driving and engine was warm or after engine had cooled down? It is normal for the coolan level to be lower when the engine is cold as the radiators will have "sucked" the coolant back in. Immeadiaitely after a drive the coolant level may be closer to the Full mark,
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    a) Normal? maybe
    b) Yes
    c)Yes
    d) Simply top up. However it is so incredibly simple to bleed air off, it is a procedure to be familiar with. And air does somehow get into the inverter pump ?? maybe thru osmosis!. :cheer2:
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    a) Depends on the temperature, if you checked it cold it may be OK. I think it should be between the hi and low marks when at normal temperature but the inverter coolant doesn't get very warm. If they are at the low marks it wouldn't hurt to add some and keep an eye on it for a while. Just keep it below the full mark when it's fully warmed up.
    b) They are totally separate.
    c) Yes both use a 50/50 mixture of Toyota's pink coolant.
    d) As mentioned above just add some. No need to bleed unless it is changed and that's at 100K miles or 5 years.
