Coolant Pump TSB - Rig code?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LuvMy2010, Mar 23, 2012.
  1. LuvMy2010
    LuvMy2010 Junior Member
    33
    Wichita
    So I am nearing the end of my warranty and have been trying to get TSBs taken care of before I'm out of warranty. There is one TSB that is particularly concerning to me. It's T-SB-0143-10 for replacement of the coolant pump. From the looks of it, its just a matter of time before my coolant pump will go out, since my vin # falls within the TSB noted vins. It will be luck that 1 mile over my warranty is when it will happen. I would love to get this costly repair done before the warranty is up so Toyota will pay for it, but they won't fix it without the computer showing the code P261B- Engine Coolant Pump "B" Control Malfunction or P261C- Engine Coolant Pump "b" Control Circuit Low. Is there any way to create a situation where the check engine light would come on and the computer show one of these codes, even just for a few seconds? Then, I could take it to Toyota and they could pull the computer history, see the codes, and replace the coolant pump. Any ideas? I'm not against opening the hood and rigging something just for a couple minutes in order to pull one of those codes.
  2. Former Member 68813
    3,524
    983
    US
    I don't think sabotaging the car is the way to go.
  3. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I don't know if the forum rules allow us to tell you how...but there is a way.
  4. toyotechwv
    toyotechwv Toyota Technician
    474
    254
    Princeton, WV
    Wow, and you guys talk about dealers being dishonest.
    2 people like this.
  5. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Your post is one of the reasons I would buy an extended warranty that covered TSB's beyond the warranty. One of the weak links in consumer protection laws here in the US.... :(
  6. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Some are, but most just refuse to spend any of their own money on customer satisfaction. It's an age-old problem. They will spend Toyota's or the customer's (or whomever) money but not their own. They save their own money and don't fix our problems with our cars just because we say...they have to see it with their own eyes.
    This is a good way to be in general because most customers' diagnosis can't be trusted; neither can a mechanic from another shop. However, for those of us who know what we're talking about, and know how things work, it's very frustrating.
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    So Toyota should replace our working water pumps with a newer working water pump. Sounds like a waste?
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    There is no change in part #, so what's the point?
    TSBs are merely used as a diagnostic aid.
  9. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Well if there's no change in part number, that's different. Just prolonging the inevitable, coolant pump failure. Unless there was a running production change, or a fault in manufacturing the early units, there's no reason to get a new one now "just in case".
