Coolant reservoir trouble
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Talon45939, Feb 25, 2021.
  1. Talon45939
    Talon45939 New Member
    Colorado
    I have a third generation Prius from 2014, recently got in a car accident with it and the coolant reservoir was damaged I have managed to fix said reservoir and I’m attempting to refill and prime the radiator with coolant. What can I expect the amount of coolant going into the system to be? And are there any other things I would be aware of?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,964
    4,709
    Texas Hill Country
    Less than a gallon if just the reservoir was disconnected . Even if you open the radiator drain its usually about 1-1/3 gallon. The system will bleed itself when the thermostat opens. You will see coolant flow in the reservoir at that time.
    Generally you want to put it in Maintenance Mode while parked to circulate the coolant.
    A Toyota mechanic explains Maintenance Mode in his recent video.
    You don't need to do the Inverter, remove the undercovers or drain anything. His pump warning is only for the Inverter coolant system.
    #2 rjparker, Feb 25, 2021
