Coolant tank empty?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AllenZ, Mar 24, 2014.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I just noticed this morning that the coolant tank (close to radiator) is empty. The other coolant tank level is normal. Big surprise! I thought they are connected, and coolant can flow between them.
    Do you think it has anything to do with heavy oil burning on my 2004 with 210K miles? I don't really know when it empted, because the other tank is almost full.
    Thanks!
    Allen
  2. JC91006
    16,901
    8,629
    Did you check the level in the radiator? You have to remove the black plastic cover piece (covers front side of car) to see the radiator cap. You have to check the level in the radiator if the reservoir is empty. Check if you have a leak in your water pump, likely cause of the missing coolant.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The coolant tank closest to the radiator is for the ICE, at least that would be my best guess for a 2004. The other pink coolant tank is for the Inverter/Converter. They are completely separate cooling systems.
    Have you seen any signs of leakage on the ground around the car lately? Also look around the water pump and see if you see any signs of pink crust just below the water pump. This will typically be the first signs of a coolant leak. If so then you need to replace your ICE water pump.
    If the coolant reservoir is empty you need to check the radiator and see how low this is. You will want to get some Toyota coolant and first fill up the radiator and then the reservoir.
  4. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The two coolant loops are completely independent.
    JeffD
  5. AllenZ
    640
    63
    Chicago
    So, if coolant for ICE is gone, and I drive 35 min at 70+ everyday, it means engine is overheated, oil got burned very hot... More carbon will deposit everywhere including piston rings... Hence the heavy oil burning?
  6. JC91006
    16,901
    8,629
    You probably have coolant in the radiator. Just because the reservoir is empty, it does not mean you don't have coolant in the car. You should still top it off.
    When I bought my 06, I had the same issue where the coolant was low. I also noticed the oil burning at only 120k miles....and the owner told me it was burning since 100k. Maybe the low coolant has something to do with it.
