Coolant temp before freeway driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Edsvfr800, Jan 8, 2013.
  1. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I am using a Scanguage and wondering if any of you other cold weather drivers have any recommendations on engine warm up time or coolant temp before hitting freeway speeds? I was thinking at least a 100 degrees for coolant temp.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You may want to use Advance (Ignition) Timing instead of coolant temp. While ICE is warming up, Advance Timing is a negative value. When it is done, it becomes positive value.
    I am guessing you want to get ICE fully warmed up before merging into the highway. This way, battery is not used during acceleration.
    Tracksyde likes this.
  3. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I'm sorry I should clarify...I'm using a scangauge e. (less features). I don't think I have advance timing.
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Interesting, there was IGN xgauge for Gen2 Prius.
  5. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    I see no reason for pre-warming. When hitting a ramp cold, neither the battery nor the engine are heavily stressed. Both strike a balance during the initial warm-up stage. All those winters climbing out of the valley just a block from my home showed how much flexibility the system has to offer.
    The highway is 3 blocks away. I fire up the engine just prior to the ramp so the engine RPM will be lower initially. Of course when you do get going, 1500 is pretty darn easy on the engine. It hasn't been a concern at all. Even dropping the pedal to the floor is restricted, a clear effort to prevent strain.
    0W-20 synthetic oil is helpful as well. It's the way to go for cold protection.
    Edsvfr800 likes this.
  6. lensovet
    2,615
    496
    Burlington, NJ
    yeah, pretty much all modern cars don't really need "warm up" cycles. just drive it. plus, since at highway speeds it will be spinning at higher rpm, it will warm up there much faster.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ok, so OP can use IGN.
