Coolant warning light
Discussion in 'Gen 2 Prius Main Forum' started by Harrywalpole, Jun 4, 2018.
  1. Harrywalpole
    Harrywalpole Junior Member
    2008 Prius 182K Miles, high temp coolant warning comes on intermittently over 50mph, if I put cabin heat on it blows cold air. Coolant reservoirs levels OK, radiator took a quart , topped off this AM. Problem still there but less since ambient temp is 50d . Water pump is turning
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    If you had to add a quart to radiator then there was a lot’s of air in it. Probably there’s still air in it. Bleeding the engine cooling loop on gen 2 Prius is not easy.
    You don’t have check engine light on? If it’s there can be a fault with coolant control valve that causes the heater not to get coolant sirculation.
