Cooler temps now, ICE jerks or lurches when starting
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ssdesigner, Oct 29, 2016.
  1. Mendel Leisk
    42,354
    Yeah, for a lot of reasons the US 2 is an attractive level. Missed that.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Boozed up teenagers?
    Uh oh, slipped info the gutter again!
    Coast Cruiser likes this.
  3. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I think somebody mentioned that in one of the battery threads, but I'm not sure.
    It sure is nice that Toyota gives us an 8 or 10 year hybrid battery warranty.
    RCO and Mendel Leisk like this.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    got it.(y)
  5. first_superior_prius
    76
    115
    Michigan
    I don't know where you live in MN, but Minneapolis has an ordinance against idling. I can't post the link due to being "too new" but if you google minnesota idling laws you'll find it
    Also, the engine warms up faster when you drive it. I lived in Minnesota for 8 years and I always started the car up, let it warm up for a few seconds, and then drove. I kept the blower off for the first minute or two until it'd be ready to blow warmer air.
    If you can't stand a minute or two of cold temps while driving your car, you should move out of MN! :)
    krmcg and RCO like this.
  6. Mendel Leisk
    42,354
    I'm dead set against idling normally, but it makes no sense to drive with fogged or frosted windshield.
  7. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    One of the Prius things. Scary the first few times you feel it. I doesn't happen all the time the ICE starts when your stopped.
  8. Mendel Leisk
    42,354
    Did you have previous gen, notice similar? I'm not too sure about this "Prius thing".
    I've noticed one incident in all the time we've owned our 2010, of the shake at start up. This was after the engine had run for a few seconds, the day before. Still: our 3rd gen leads a sheltered life: almost without fail precede cold starts with a couple of hours on the block heater.
    kithmo and alanclarkeau like this.
  9. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    From the Minneapolis Anti-Idling Vehicle Ordinance website:
    6. Idling is allowed if needed to operate defrosters, heaters or air conditioners to prevent a safety or health emergency.
    7. Vehicles may idle up to 15 minutes in a one hour period if the outside air temperature is less than zero degrees or higher than 90 degrees.
    I've lived here all my life, and still don't care for the extreme cold. Most of the time you can't see out of the frosted windows until you let it warm up.
    RCO likes this.
  10. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    my generation 3 is 10 years or 150k on battery in NJ
    SM-G935T ?
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I had it once, in exactly the same circumstances, with the Gen 3, when it had been started for a couple of seconds the day before. I used to get the same with a 1995 Ford Mondeo I used to have, in the same circumstances. Now I always let the engine run through its first warm up cycle, previously with the Prius+ and now the Gen 4, where the ICE cuts out itself, before switching off and have never had the shakes since.
    #51 kithmo, Nov 1, 2016
  12. Coast Cruiser
    2,267
    2,571
    I've experienced the "lurch, jerk, shakes" several times. I just figured it's normal, weird, Prius behavior. :LOL:
    I never know what to expect from that car day to day.
  13. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Well along with the ICE being cold, so is the transaxle, so clutches and dampening are also going to react different to thicker transaxle fluid.
    Only thing I have noticed and the same was the case with the Prius C. When I let off the gas and press the gas at high speeds I will occasionally feel a bit of a jerk. Nothing more than what you would feel in a regular automatic transmission however. Then again I was going idk 90 MPH...
    RCO likes this.
  14. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Doesn't the prius C uses a CVT!
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes, much the same e-CVT as the Prius Gen 3.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Clutches & dampening in the Prius, you lost me there, please explain ?
    It would have to be reeeeealy cold to thicken the AWS fluid to the extent to make it cause juddering, it's like water thin.
    RCO likes this.
  17. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Well on transmission fluid, all I can go by is what I have experienced with automatic transmissions on a cold morning...However, the eCVT is a totally different design.
    That being said there is a clutch between the crankshaft and transaxle...this way you don't feel the car jerk when the engine starts and stops...So with the fluid and engine being cold you're more likely to feel more of a shudder....
    I am also not a transmission guy...
    However if you're interested in the engineering of the eCVT have a look at this video...
    michaud85 likes this.
  18. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Keep diggin' you're well into a hole now :rolleyes:, if you're not a transmission guy I suggest you stop now :cautious:.
    The shock absorbing clutch plate between the flywheel and the transaxle would behave no differently whether the engine was cold or hot.
    On the last 3 Priuses I've had I have never experienced a judder when the engine starts or stops normally, the only judder I have experienced was, as I said in a previous post, when the engine didn't start normally.
    RCO and alanclarkeau like this.
  19. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    The vehicle juddering on ICE startup is because it can exert torque on the wheels when MG1 is exerting torque. MG2 has to counterhold this, but it's not perfect, especially if the ICE is cold and therefore running unpredictably.
    The vehicle juddering when lifting off the accelerator and then pressing it again is because the engine's in the process of shutting down, and then it has to start again quickly to respond to your request.
    MDNHW11, RCO and alanclarkeau like this.
  20. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Suggest I stop? A wee bit rude if you ask me. Correct me where I am wrong, that's all fine. This is after all a forum, I doubt most people who offer answers, solutions to problems are experts...otherwise we would all be working for Toyota.
    I think the answer lies in the ICE in most all cases, except where a transmission is worn out or has some other issue. My guess would be that if it is cold, probably normal for the most part, could be the ICE misfiring or weak combustion on the first few strokes if it is really cold out... I never noticed anything out of the ordinary in either Prius I have owned. I will admit that my sister's Gen 2 seemed to be a bit more noticeable when the ICE started/stopped but also has 138,000 miles on it....so I would assume wear and tear has an effect on things.
    I had a 2015 Dodge Challenger which I got rid of. Transmission had to replaced on day one...brand new too. The replacement transmission worked ok but cold it shifted very firm and was slow to shift. After the car warmed up to normal temp, the car would shift smoothly. Didn't matter if it was 70 F outside or 20 F, always was sloppy shifting cold. Now, if it were an old old transmission design one could argue about valves and whatnot... correct me if I am wrong but most automatic transmissions just use shift solenoids and various electronics to shift....so what would have been the issue there? Aside it being an inferior design (I really was not all that impressed in the car, looked great...was fast and all but definitely not a car to have as a daily driver and have those sort of problems).
