Cooling fan replacement.
Discussion in 'Gen 3 Prius Technical Discussion' started by yeldogt, Jan 8, 2017.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Noticed what sounds like a slight rumble coming from the cooling fan while moving the cars this morning -- most likely the motor bearing. It's minor ... something I'm going to plan on replacing before the summer.
    Don't see it mentioned .. anyone have experience? I did a quick look inside the hood and only noticed one fan --looking at the parts online .. they all show two. Naturally -- the whole assembly needs to come out.
    Having bought an aftermarket fan assembly for one of my cars about 5-6 years ago -- and having a balance/ noise issue with it ... was thinking maybe trying to find a used motor/ fan and installing it into the existing shroud. We have owned hundreds of cars -- these things don't fail very often. Thinking a use OE part is better vs cheap replacement ... the OE from the dealer is expensive. I think it's best to get a balanced motor/fan.
  2. yeldogt
    810
    313
    NE
    I somehow put this in the wrong spot -- wanted the gen 3 Forum
  3. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    Use the "(!) Report" button at the bottom of the post and ask a moderator to move it to the Gen III forum.
  4. Tideland Prius
    16,683
