Cooling/Heating fan not working
Discussion in 'Generation 1 Prius Discussion' started by SteamRollerCC, Apr 9, 2018.
  1. SteamRollerCC
    SteamRollerCC Junior Member
    29
    2002 Prius
    Hello,
    It was some time ago that I was hit from behind by another car. There were a lot of cosmetic damages which got repaired, but since then, the fan hasnt been working. It doesn't turn on for the heater, nor the A/C.
    I checked the relays and fuses to see if that was the problem, but they're fine. I've delt with A/C issues before, bu this is the fan in general not working... so this is strange to me. What could be the problem?
    Much thanks in advance!
  2. 4priusowner
    4priusowner Junior Member
    69
    Had the same problem check out my post on the subject. 2005 blwr fix.
