Cooling system performance for hybrid battery is low
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by onabuc, Jun 21, 2020.
  1. onabuc
    onabuc Junior Member
    loa angeles
    I try cleaning the cooling system for the hybrid battery but found out there is no filter....clean ducts and motor for dust and disconnect battery to reset message from computer....but dont know if thats gonna work. 20200620_014921.jpeg
    49,371
    was there much clogging? if not, you may have to open the battery case. you can make a filter, or buy one online.
    Jim Swart likes this.
  3. Mendel Leisk
    38,646
    You got to and cleaned the fan? If so, dirty was it? If not, you should do that.
  4. AzusaPrius
    AzusaPrius Senior Member
    1,827
    811
    I believe this is the cooling system for the inverter not the fan.
  5. ASRDogman
    ASRDogman Senior Member
    6,059
    3,252
    The plastic filter is from Toyota, about $14.
    The foam is from Lowe's. $3 or $4???? Cut to fit.
    Grit likes this.
  6. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    "I believe this is the cooling system for the inverter not the fan."
    NOPE. Says right there on the dashboard: Hybrid Battery. If it were the inverter, it'd say Check Hybrid System.
  7. Mendel Leisk
    38,646
    @NutzAboutBolts has a video on cleaning the fan; there's a link in pinned thread at top of this forum.
    Only thing: I wouldn't pull out the rear seat cushion, not necessary: you just need to reach through, remove one bolt.
    NutzAboutBolts and Jim Swart like this.
  8. AzusaPrius
    1,827
    811
    Yea ok and a lot of people on here dont know that a bad waterpump will say check hybrid system also.
  9. Ed Beaty
    334
    309
    Salt Lake City
    "Yea ok and a lot of people on here dont know that a bad waterpump will say check hybrid system also."
    Perhaps, but your point about the inverter is still incorrect. ;)
    A myriad of things can evoke Check Hybrid System...
    Raytheeagle likes this.
